Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Drain pan oder
We have been w/o power for over 2 weeks due to hurricane Ike and the drain pan stinks to high heaven. How do I clean this? I can't get it out.
Thank yous
  • Anonymous Nov 05, 2008
    My drain pan is not flat. It has wells and the only access is located behind the huge metal covering on the back of the refrigerator. It's a Kenmore top freezer model. It stinks horribly and I can't access the pan to clean it out.
  • 409 Answers
you will have to start by removing the kickplate. which is the panel under the doors. it's held on by 2 screws. remove the screws and remove the kickplate. you should have no problem pulling out the drain pan then. you can clean it with bleach no problem.
Posted on Sep 30, 2008
How do I clean the drain pan? Why in the world would anyone make a fridge that has a non-removable - and even a non-accessible drain pan? It stinks after awhile and it does need cleaned - even if jus
The "cover" is removable. Once the cover is removed, you can gain access to the pan and remove it for cleaning. The removal process can be a little tricky, but it can be done.
Dec 19, 2014 | Refrigerators
Washing machine rubber on door is leaking can you help me
Try cleaning the glad on the door and the rubber inside. Also pull the rubber back and make sure you don't have a sock or under garment stuck in there keepin your washer from draining. Other than that it's probably the drain that is clogged. That's easy to fix but stinks to high heaven. Let me know if u need to drain it I will tell ya how. Hope it's a sock.
Feb 07, 2011 | Washing Machines
My Samsung refer RS2630AWW stinks. Can't find source of smell. No drain pan under unit. Any ideas?
In any refrigerator there may be stinks due to lack of cleaning drops of ice cream,buttermilk and milk or any cool drinks which by mistake rest in cooling compartments.
Solution: Remove power. And also empty your fridge. Now with little soap watered cloth(wet) clean indoor compartments all. And Within 5 minutes clean with dry cloth. Keep open the door on sun shine. or in heat room. After 4 to 6 hrs, reuse it. No smell will be there. It's advisable to do this type of cleaning once in 3 months at least. Helpful?
Jan 22, 2011 | Samsung Refrigerators
I have an odor cause my fridge has been closed with no power
yes drain pan is located in the back on top the compressor....10:1 solution of water and bleach is good enough to clean it with....kills mold and mildew....also remember that if the fridge lost power and found cause a stench inside, could be held by the plastic....ive been using dryer sheets in my units to help with odors. may take a few weeks...but a new dryer sheet a week helps.
Jun 12, 2009 | Refrigerators
Can't get to drain pan for cleaning, whirlpool fridge
You can not acces the drain pan. Por 1/4 cup bleach in the defrost drain hole.
Two days later pour 1/4 cup vinegar in the defrost drain hole.
Mar 19, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Odor coming fromback panel
you can also use bleach let it sit there for a couple of days so it will kill bacteria and odor the smell is all the meat and blood that drain down to the pan
Oct 17, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Don't know how to remove drip tray
hi there,
the drip pan is usually accessible through the front behind the kickpanel. the kickpanel is attached with 2 screws. if you remove the kickpanel, you'll be able to pull out the drain pan.
Oct 02, 2008 | Refrigerators
Freezer not freezing
Check to see if the fan motor in the freezer is running. Most likely it is not circulating the cold air Also make sure the defrost drain line is clear and has drained out. A frozen sheet of ice will restrict airflow also
Sep 28, 2008 | KitchenAid Superba Architect KSCS25INSS...
Order in drain pan
its supposed to have water in it heat from the compressor evaps the water you may poor a little bleach in it to kill the algae or bacteria to help with oder
Jan 15, 2008 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
192 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
