Question about Garden
Craftsman 2 cycle leave blower will not start
New plug .025 gap new mixture 3.2 to 1 gal of gas will not start
  • Anonymous Apr 19, 2009
    has new spark plug set at .025 , new gas mixed 40 to 1 its gitting gas , even checked muffler , not stopped up , seams to have comp.won't even try to start.
  • 202 Answers
Check your owners manual. If it calls for 32:1, you need to add a bit more oil to the gas you have mixed. Put a few drops in the tank as well. You should not have to clean out the fuel system. Will not be the reason your machine does not start.
Most of the small outdoor power equipment that I have used takes the following to start:
1. Prime 6-8 times, or whatever the manual calls for.
2. Choke the carb to full choke.
3. Pull starter rope. It may sputter and die.
4. After it sputters and dies, put the choke on 1/2. Pull a time or 2 more and should start. Run like that 10 seconds or so, then take choke all the way off.
Posted on Nov 01, 2009
  • 5 Answers
That fuel/oil mix ratio should be 32to1 or 32 ounces gasoline to 1 ounce oil. You will have to make up a new mix and probably clean the fuel system and the spark plug before it will start.
Posted on Oct 01, 2008
2 Suggested Answers
  • 48 Answers
SOURCE: craftsman 2 cycle leave blower will not start
how much compression - you need a min of 90 lbs if you have that then it sounds like a carb prob
Posted on Oct 17, 2008
Need gas mix
check age of gas. Cannot be more than 30 days old.
Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.
Jun 03, 2012 | Craftsman 25cc 2-Cycle Gas Blower/Vac
Need gas mix solution
Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil).Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.
What is the problem when my 27cc craftsman weed wacker starts but doesnt stay running
Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.May need to clean or replace carburetor.
May 29, 2012 | Craftsman 27cc 2 Cycle Crank Straight...
My craftsman 200mph/430CFM 25cc leaf blower will start and last for about 5 mins. on half choke and then die out and not start. It cant be put on run or it will die right away.eplaced spark plug. Still...
May 12, 2012 | Craftsman Garden
My craftsman 32cc leaf blower won't stay running
Check age of gas. Cannot be more than 30 days old.
Nov 06, 2011 | Craftsman 4 Cycle Blower/Vac
I have a Craftsman 2-cycle blower/vac and its only 3 years old and have changed out the spark plug and fresh mixed gas and still won't start. I need some help anyone know?
Check age of gas. Cannot be more than 30 days old. Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage. May need to clean or replace carburetor.
Sep 18, 2011 | Craftsman Garden
Won't start
May have moisture in the fuel. Try draining the old fuel out, put in new, add Stabil, or some other fuel stabilizer, clean & gap plug. Should start.
Oct 31, 2009 | Craftsman 4 Cycle Blower/Vac
Oct 13, 2008 | Garden
Garden Logo
907 people viewed this question
Top Garden Experts
EugenesDIYDen
EugenesDIYDen
Dennis Key
Dennis Key
john h
