15" HD Widescreen LCD Television ( flat screen) On the remote, the chanel changer does not work
  • rogame Oct 01, 2008
    i have no camera to do this, but the technical support from yhe company told me how to fix it
  • 1,011 Answers
check all of your remote buttons.
u can use your phone camera.. just keep the remote sensor infront of your mobile phone camera so that u can see the sensor through your camera. now press each button one by one .. for ok, working buttons, you can see light emitting from sensor . your battery should be new or healthy
ask freely more question, if confusion
dont rate it until u fully satisfied with solution and it works
Posted on Sep 30, 2008
Closed caption is on and neither the remote nor the menu setup options for cc are working. I tried resetting to factory settings but no help. Advice?
Search Results
    [PDF]Instruction Manual
    TFTV1525 ... If this equipment does cause harmful interference to radio or televisionreception, ... The LCD panel used in this television contains millions of thin film transistors that ... 15. or cable system during a lightning storm or when it is left unattended and ..... There are four options lised under the Closed Caption menu.
    COBY TFTV1525 INSTRUCTION MANUAL Pdf Download. > ... > Coby Manuals > Flat Panel TV > TFTV1525
    COBY Electronics TFT LCD Widescreen Television Instruction Manual. ... Cobyelectronics 15" widescreen lcd hdtv/monitor specification sheet (1 page) ... Operation is subject to the following two conditions: • This device may not cause .... Direction &OK While working with the system menu, press the direction buttons to ..
Jan 13, 2016 | Coby TFTV1525 15 in. LCD TV
Elonex xv-s telvision no remote control cant find sourse to connect playstion without box is picked up automatically when switched on. it on scart connection
37" Elonex Widescreen HD LCD Television (Black) - Aria ...
Buy 37" Elonex Widescreen HD LCD Television (Black) - HDMI, 1366x768, 1200:1, 8ms Product Name: 37" LCD TV Model No: LT37V1 Main. ... 49~61KHz; FrontControls: Power, Source, Menu, Channel Up, Channel Down, Volume Up, ... Have you tried it with a HDMI connection as I can't seem to get mine to work with my ...Missing: playstion
[PDF]Operator's Manual - SunBriteTV
6) Do not install near any heat sources such as radiators, heat registers, stoves, ....Water-Resistant. Wireless Remote. Control. Model 3230HD. TV Installation .... If youcannot achieve that ... to both your DVD player and Composite's S-Video connector ....Connect an HDMI cable to the HDMI output of your Playstation 3.Missing: elonex
Jan 12, 2016 | Televison & Video
My 15' LCD widescreen television does work there
POWER supply in the unit===question is if a 15 inch is it going to be economical to even fix it? Many sets in this size are really not intended for repair.
Apr 29, 2012 | Coby Televison & Video
I would like to find the hd channel on my tv model le32r8
After tune in any chanel.Check ur tv remote display button on the remote control.Any tv channels play in 1080i modes are in HD channels.
Aug 17, 2010 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Screen goes dark after few minutes
check your LCD inverter maybe there is loss connection or some parts damage from inverter.
May 05, 2009 | Polaroid TLA-01511C 15 in. LCD Television
Not working
Ok the problem was in the set up had to let it run through all the analog chanels and then through the didgital ones. After that it worked great. Thanks for the infoI read this on you sight so I tried it worked so were good.
Nov 23, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Flicking chanels by itself
It either has a sticking switch (usually caused by using cleaning solutions on the screen) or the power relay is faulty or the remote control is faulty.
Take the batteries out to check the remote.
Thanks guy9
Jul 05, 2008 | Samsung LE32R41BD 32 in. HD-Ready LCD...
This user manual should help!
Jan 13, 2008 | Televison & Video
Picture is not centered on monitor leaving a 2 1/2" black border on Philips LCD
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Nov 13, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Subtitles disappear below bottom of screen
Check to see, what format the television set that widescreen etc. this may be all that's wrong with your set. If the problem persists the vertical height needs to be adjusted.  Most likely through the service menu, if units under warranty you can call Akai.  For further structures.
Oct 24, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
