Tv shuts off immediately after turning on
Using remote or tv switch
  • 6 more comments
  • Anonymous Oct 01, 2008
    television shuts off after turning on
  • harley2009 Oct 01, 2008
    tv shuts off after turning on
  • drwillierock Oct 13, 2008
    I have the same problems
  • Anonymous Oct 30, 2008
    shuts off right after i turn it on.
  • Anonymous Nov 28, 2008
    same **** here too
  • Anonymous Dec 05, 2008
    TV Shuts off
  • ajbailey79 Dec 09, 2008
    turn on all3 lights blink and turns off
  • Anonymous Jan 03, 2009
    ugh so annoying
    Problem Solver:
  • 19 Answers
Does it shut off shut off, or is there audio present after the lamps shut off? When you shine a light to the screen do you still see picture kind of?
If still see picture, it's inverter/power supply or CCFL bulbs itself. If no picture, completely off, it's DEFINITELY the inverter/power supply.
Posted on Dec 08, 2009
TV shuts off with volume control
Improper signal frequency goes to the TV from the remote control. Check your remote control for fault. Gopakumar Gopalan Google
Mar 23, 2014 | Samsung PN58B550 58 in. Plasma HDTV
Remote controller sony tv eventually turns on the sony trinatron but shuts off immediately
Hi, Try putting new batteries in remote. Make sure nothing is in the way of remote sensor.etc.. plants or something on table, kids toys... "?? Clean Sensor on TV and on remote with soft lint free cloth.
May 28, 2013 | Televison & Video
The tv immediately turns itself off after i try turning it on. it doesnt matter if i use the remote or turn the tv on manually. It just makes the noise as if its turning on and then immediately switches...
Hi, The TV is shutting down because there is an internal fault, there is more likely a panel that needs replacing or a few faulty components.
It's more than likely repairable.
If it's under warranty contact your dealer for repair or replacement.
Feb 10, 2011 | LG 60PS60 60 in. Plasma HDTV
We have a jvc dvd combo. Whenever we turn it on it almost immediately turns off on its own.
If you set up a remote other than the one it came with then you can only do it for ONE of the devices...not everything in the Combo. If it's a TV/DVD combo, then your remote is sending a POWER ON beam twice. (one for the tv and one for the dvd). What ends up happening is that the 1st beam turns on your tv and the 2nd beam shuts it off. To reslove this, don't program the DVD to work with the remote. Just turn it on when you want to use it
Nov 16, 2009 | JVC Televison & Video
check first for the contact point of your control panel button maybe the tact switch is shoted specially when your always using remote control for function operation.second check power supply for leak capacitor or change in value,check also the photo coupler for leak test or change in actual.
Aug 01, 2009 | Mitsubishi VS-5043 50" Rear Projection...
Pioneer PDP435PG inadvertently reprogrammed by Casablanca remote.
Some ceiling fans have jumpers that can be moved to select a different frequency but you have to be sure both the remote and the fan receiver are set the same. Other than that, you may have to use some creative control. For example, I can turn on my TV by pointing the remote at the wall opposite the TV
Mar 29, 2017 | Pioneer PDP-4350HD 43 in. Plasma...
Panasonic CT36SC13 remote or front power button will not turn off
Solution1:
a)Inside the tv there are microswitch CH+- Vol +- power, menu: when the ones are faulty," tv tends to behave at its own", change them, of course before to buy'em, unsolder th'em and try with the remote, tv has to work with out'em.
Apr 08, 2009 | Televison & Video
Assistant
is this electricity pocket plugged up to a timer ? or take the tv back to the shop... lost the receit just look for the same tv on computer
Feb 20, 2008 | Toshiba 28N33 28" TV
Samsung TXM2756 TV shuts off when turned on
Make sure the set cannot "see" the remote to rule that out. Then, look for an HV problem with regulation to be the next thing to check out....accordianman
Oct 20, 2007 | Samsung TXM2756 27" TV
Standby light is on, but power switch does nothing
The FPA (Front Panel Access) lock is on. This allows you to prevent kids from using the set when you are not there and disables the buttons on the front of the TV. The set should turn on with the remote only, and then you can go back into the menu and turn off the FPA, also called child lock.
Aug 04, 2007 | RCA 27F530T 27" TV
Televison & Video Logo
773 people viewed this question
Top Televison & Video Experts
