Question about HP Photosmart 735 Digital Camera
Charging flash stays on and i cant take a picture what can i do?
Is there any way to solve this problem? Please help
  • 1 more comment
  • trumpat Dec 05, 2008
    Have the identical problem. Even tried to turn the flash off but get the same "charging flash" indication when attempting to take a picture.
  • Anonymous Dec 22, 2008
    i have the same problem. when i turn the camera on, the flash symbol on the bottom left corner of the screen continuiously blinks. and when i try to take a picture its says "charging flash". i dont know what to do
  • Anonymous Jan 04, 2009
    i have the same prob. i have tryed it all. new batts. new card. give it time. can you help thanks.
Hey, I have the same problem. Try turning the power on and while the lense is focusing out apply some resistance with your other hand. Normally the lense will retreat and you will have to power up again. The problem seems to be associated with the opening and closing lense. You may have to repeat this fix each time you power up but it eventually seems to cure itself. I have taken dozens of pictures since I figured out this fix.
Posted on Jan 11, 2009
Turn off the camera. Take out the memory card. Wait 20 - 30 seconds and put in fresh batteries. Then try it. It worked on mine.
Posted on Oct 21, 2008
Help me solve this problem. - my camera stays "charging flash" and cannot take pictures
Posted on Oct 05, 2008
ZTE sequent wont charge anymore .
Hello:::::
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jan 11, 2013 | ZTE Cell Phones
Please help me...my nokia 5130 has a problem...when i am openning music player or radio the not enough memory box is always appearing...and my calculator lost...and also the opera mini,i cant open....and...
download the flash software for your phone try googling for it...
or you want it done from somebody...visit nokia care and tell them to flash it for u..
ur problem will get solved
Sep 05, 2010 | Nokia 5130 Cellular Phone
No flash. pictures are dark
My Kodka M530 is only taken dark pictures, I cant get the flash on, and if I get it on it still wont stay on. The pictures still coming out dark
May 18, 2010 | Kodak EasyShare M530 Digital Camera
What does charging flash on photosmart m537 mean?
The flash gun needs to have a high charge available before it can flash - this can take a few seconds to charge fully ready to give off a full flash "flash" As batteries get older and uncharged - it takes longer to reach the correct charge on the flash
Hope that helps
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 31, 2010 | HP Photosmart R707 Digital Camera
Camera will not stay booted up
It seems that the Milli Amps on your rechargeable batteries are to low you will notice on each battery it will show the amplitude purchase a higher amplitude.
May 12, 2009 | Kodak EasyShare DX4330 Digital Camera
My Sony Cybershot DSC W55 "7.2 mega pixel" does not flash. Error code E:91:01 ?
Please RESET your camera , go to Menu > Initialize > OK
If problem still exist you need to replace flash unit in camera.
Let me know if you need further help.
Jan 28, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Finepixz20 digital camera
That is actually the exact same thing I am experiencing but mine has grey lines on the display window. I was able to take photos to a grey screen connect it to my comp...low and behold my pics showed....I am furious....need some answers as I will never hear the end of it from my daughter.
Grrrrr
weelassy
Oct 20, 2008 | Fuji FinePix Z10fd Digital Camera
Charging flash
i get the same problem!
i take a picture and the flash is too bright, the picture turns out white.. then it takes a while to take another one because it says charging flash..
Jun 07, 2008 | HP Photosmart R725 Digital Camera
My digital keychain
They probably designed it that way. I have an MP3 player in the form of a USB Flash Stick. When I plug it in it stays on also. The thing is that USB provides 5 volts of electricty when you plug it in. The picture keychain probably dosent use all of that for charging so any extra is used to power the keychain while you charge.
Hope this helps
Thanks for reading!
May 02, 2008 | Tao Spectare digital picture Remote...
Wont hold Charge
When you charge the battery what does it do? Does the red light flash or stay solid? If it stays solid while it's charging then you should be ok. Casio doesn't recommend using any other brand of battery with their cameras because we don't know how they will react. I would say try a regular Casio battery and see if that solves your problems. I know that means a little more money but a lot of times I have seen that solve the problem right away.
Apr 09, 2008 | Casio Exilim EX-Z55 Digital Camera
HP Photosmart 735 Digital Camera Logo
161 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
