Question about HP Photosmart C6100 All-In-One Printer
Printer failed printer does not switch off/does not print
  • twhitela Dec 19, 2008
    My printer keeps powering on and off. The only way to shut down is to unplug it.
  • 234 Answers
Unplug the power cord from the All-In-One as well as the power outlet leave it unpluged for atleast 1Min time..
Plug the power cord directly to a wall outlet without surg protector. (if possible connect it to a different power outlet)
Before connecting the power cord to the All-In-One press and hold the # and no 6 button and then insert the power cord, do not release the keys
until you see a message a reset (if the screen goes blank then release the keys and turn the power on)
Then check and see if you are able to make a color/Black copy
Good Luck
Posted on Sep 30, 2008
Hp 8500a910 all in printer continuous now printing message and wont print
The foam padding under the print head slide rail had lifted slightly catching the underside of the print head, which in turn causes the alignment to fail.
Nov 11, 2014 | HP Officejet Pro 8500 A910A Multifunction...
Printer is paused wont restart
it may be that you have a corrupt file in the print queue, a quick fix is possible - switch the power socket OFF, disconnect the PC/Network connections.
power on the printer, it should have had time to clear the memory now, see if the machine is able to print a menu page or config sheet ( open menu enter the information menu- print config sheet:)
if the printeris able to do thiswith no network connections you have eliminated the printer from the problem. next switch on and log into your PC, still disconnected from printer, open print queue and delete all documents from the queue ( your not deleting the files ( just the print requests)) once this is done then reconnect the printer and send first a windows test page ( confirm working connections first ) then attempt to print the failed file - if it fails in the same manner - the file was your problem.
Mar 16, 2014 | HP OfficeJet V40xi InkJet Printer
Printer stopped printing for no apparant reason?
Check all conections, if you have software installed for it, try usi g that to check it, usually printer software has diagnostics built in. If tyat fails disconnect it restart, then swktch off reconnect, switch on
Mar 12, 2013 | Dymo LabelWriter 400 Turbo Thermal Printer
Switching the printer on, it cannot print. the message was failed to print the document
-Restarting the computer and printer.
- Checked the USB cable.
-Check the printer spooler service is on( write "services.msc" on RUN, then check printer spooler is ready)
- Insert the printer cd and reinstall.
- after install restarting and print test page
Thanks and Regards
TRinoj
Aug 06, 2011 | HP Deskjet D2660 All-In-One InkJet Color...
I have canon s 300 printer sr no FAYS 12715 some how it does not take paper and green and subsequent yellow light blinking
here are some error code list for you for your s300 printer.
Got this from slayo.com
hope this list will help you find answers to your questions. Goodluck!
ERROR CODE LIST
Error codes are displayed on the monitor of the host computer connected to the printer. For error
code display, keep the status monitor open.
Error Code
Error Corrective Action
1000 Paper out error Load paper, and press RESUME button.
1200 Front cover open error Close front cover.
1300 Paper jam error Remove jammed paper, and press RESUME button.
1401 Head ID error Replace print head, as it has failed.
1403 Head temperature sensor rank error Replace printer, as it has failed.
1405 Head EEPROM error Replace print head or printer, as one of the two has failed.
1700 Waste ink near-full error Replace printer, as it has failed.
5100 Carriage error Replace printer, as it has failed
5200 Head temperature rise error Replace printer, as it has failed
5400 Printer temperature rise error Replace printer, as it has failed
5B00 Waste ink full error Replace printer, as it has failed
5C00 Purging operation error Replace printer, as it has failed
5800 EEPROM/NVRAM error Replace printer, as it has failed
6810 EEPROM print head information error Replace printer, as it has failed
Operator Call Error
Orange lamp
2 times Paper out error Load paper, and press RESUME button.
3 times Paper jam error Remove jammed paper, and press RESUME button.
6 times Print head not-installed error Install print head.
7 times Print head error Replace print head, as it has failed.
8 times Waste ink near-full error Replace printer, as it has failed.
Service Call Error
Toggle blinking
2 times Carriage error Replace printer, as it has failed.
4 times Purge error Replace printer, as it has failed.
6 times Internal temperature rise error Replace printer, as it has failed.
7 times Waste ink full error Replace printer, as it has failed.
8 times Print head abnormal temperature rise error Replace printer, as it has failed.
9 times EEPROM error Replace printer, as it has failed.
10 times EEPROM print head information error Replace print head or printer, as one of the two has failed.
Sep 11, 2009 | Office Equipment & Supplies
Printer won't print. I have two printers the
switch the drum and toner units to rule out a faulty product (i've seen them fail without a warning or light message)
Apr 13, 2009 | Brother HL-2040 Laser Printer
Lexmark T630
If you are using the Postscript driver, switch to one of the PCL drivers. Either PCL or PCLXL.
If you are using PCL, switch to a different driver.
If all of the above fail, send me a Print to File so I can debug it.
(janddgasrepair@verizon.net)
Don
Apr 07, 2009 | Lexmark T630 Laser Printer
Printing problem with Lj1020
I would suggest logging onto the companys web site and downloading the newest driver.
And see if there are any update locations for your printers software.
Sounds like a bad driver or printer software corruption.
Also check on your menus to see if there is a way to clear or reset the printer memory.
You most likely have some file corruption.
Dec 07, 2007 | HP LaserJet 1020 Printer
Lock switch
Hi muffin, Turn off the machine, open the document cover, and then release the scanner lock switch. You'll see it. Any other problems let me know. Peace, Dude
Nov 24, 2006 | Canon PIXMA MP830 All-In-One InkJet...
HP Photosmart C6100 All-In-One Printer Logo
69 people viewed this question
Ben Johnson
