Question about Lexmark Wheelwriter 3 Typewriter
Wheelwriter 5 We have a Wheelwriter 5 typewriter. Everytime I try to type nothing appears on the paper? It moves back and forth with ease with no problem. The ribbon and correctabe ribbon looks fine. I've taken the ribbon out and snapped it back into the typewriter. No words appear on the paper when I type. Nothing! Do you know what the problem is?
  • koc1 Mar 18, 2009
    where do you get the plastic cap?
  • Lexmark Master
  • 3,594 Answers
You probably need the plastic cap that is on the proint solenoid, they are available but a little tricky to install.
DickyO
Posted on Oct 02, 2008
  • Dick O Reilly Apr 06, 2009
    The caps are available from us for 20.00 includes shipping and instrucions.
    Cleveland Business Machines
    2327 St. Clair Ave.
    Cleveland, Ohio 44114
    216-242-0027
    DickyO
Why doesn't my new corrector ribbon/ink ribbon work? The wheel advances-nothing shows on paper.
Put in a multi-part form, type if the carbon is OK the problem is with the ribbon. Look at the ribbon if there is an impression on the ribbon but no ink transfer the ribbon is very ols, if there is no impression then the ribbon isn't lifting. THere ix a 2" black gear on the right side of the printer it should move easily if not wiggle it back and forth they get tooth for tooth with the drive gear.
DickyO
Oct 10, 2014 | IBM Wheelwriter 6 Typewriter
IBM Wheelwriter 6 typewriter. The print wheel does not move when typing and acts as if in stencil mode
From your posting it sounds like you have cracked plastic print solenoid cap. We sell them for 20.00 with instructions.
DickyO
216-269-3918
Apr 29, 2014 | IBM Wheelwriter 6 Typewriter
Print head moves left and stays horrible noise
The problem is either something is interfering with the carrier movement OR the carrier homing sensor is broken/defective. First, turn off the power and manually move the carrier to the right side frame, check for foreign objects in the machine (pens, pushpins, paper clips etc.). Put some oil (10 weight) on a cloth and clean the chrome shaft that the carrier travels on.(by the rubber cogged belt). This is a common problem. If the sensor itself is the problem, take to a repair shop.(not common)
Nov 24, 2009 | IBM Wheelwriter 30 Typewriter
Paper doesn't load properly in typewriter
The platen shouldn't be too hard to remove; what you describe could be caused by the residue of labels which can be removed by lighter fluid or pure alcohol.
If removing it appears too difficult, try putting a broad stripe of one of the above across the width of the paper and then try again moving it side-to-side.
Jan 29, 2009 | IBM Wheelwriter 30 Typewriter
Right Margin
First with the T/W off move carrier back and forth checking for binds or anything binding the carrier if there are no forgien objects try a little WD40 on the shaft that the carrier slides on. DickyO
Oct 14, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 3
You probably have a broken plastic cap on the print solenoid plunger, they are available but a little tricky to install.
DickyO
Oct 07, 2008 | IBM Wheelwriter 30 Typewriter
IBM Personal Wheelwriter typewriter
Check chrome carriage rail, make sure is clean with a slight amount of oil such as 3 n1. move printer back and forth, does it move smoothly. Also could be a bad on and off switch they do go bad I stock them just for this reason. Some times to get to work drip a small and I mean small amount of WD40 down the orange or red switch to allow it to get into switch contacs.
Jul 18, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 5 (Setting the Margin back to 5"
Sounds like you don't know how to set l. margin or you have some debris in the typewriter. Turn it off and see if the carrier will move back and forth by hand, if so turn it on 7 return to l. margin press mar rel key, backspace to where you want the margin and press l. margin key.
hope this helps
DickyO
Jan 15, 2008 | Lexmark Wheelwriter 5 Series II Typewriter
Wheelwriter 6
You may need a ribbon motor or motor board, however on the older wheelwriters sometimes the gear mesh gets sloppy and gears jam tooth for tooth. Try moving the ribbon lift gear/cam on rt. side of the carrier by hand with the machine off if it won't move that's the trouble. Wiggle it back and forth and it may free up.
Dec 20, 2007 | Lexmark Wheelwriter 6 Series II Typewriter
Lexmark Wheelwriter 3 Typewriter Logo
135 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
