Question about Crosley 24 in. CDU600 Built-in Dishwasher
Dish washer problem
I have a crosley cdu 600 v under counter dishwasher.When the rotary dial timer/cycle switch is activated , the switch stays in place,the dishwasher sounds normal and the inside of dishwasher stays dry.The dial does not revolve on its own power and water will no longer enter dishwasher.
My phone is 229-769-5489 and my e-mail is keepergag@hotmail.com
Thanks Mike
    Genius:
  • 1,036 Answers
Please check the water supply is turned on before proceeding.
If it is, the supply to the internal water valve needs to be checked, and the valve for correct operation.
The machine will pause untill it has enough water in it - no water , and it won't advance.
Check out the water supply side of things to get it going again.
Thanks for using Fixya
Posted on Jan 09, 2009
Soap dispenser does not open during washing
Dishwashers have a soap dispenser located on the inside of the door. When the timer cycle calls for the soap to be emptied into the dishwasher, it either sends electricity to a bi-metal switch that opens it, or it mechanically opens the soap dish. On many dishwashers, a plastic actuator arm mechanically links the timer to the detergent cup. When the timer reaches the proper time in the cycle, the timer activates a lever that opens the detergent cup. If the linkage is broken or defective, the cup stays closed after you've closed it. Check the link and repair or replace it, as necessary.
The detergent cup itself can become clogged with old dried detergent that prevents it from opening. Sometimes just cleaning the cup takes care of the problem. If not, you probably need to replace the entire cup assembly.
Dec 07, 2017 | Dishwashers
My kenmore 665 started pumping hot water without ever turning machine on
You might have a bad water valve, or a bad timer (especially if this dishwasher uses a mechanical timer - one that has a rotary dial in front).
Feb 24, 2015 | Kenmore 665
Hi my classique dish washer won't open,it is full with dishes ,how can i get in.thanks
f your Dishwasher is stuck in a cycle check the following
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. see the diagram attached.God bless you
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace timer/electronic control board.
Apr 05, 2013 | Dishwashers
My dish washer keeps running...for hours. It usuallt stick when the dial is at the 7 on a clock. Today we got it to continue through the whole cycle but now it does not drain. Any suggestions?
It sounds like a problem with the timer mechanism itself. Make sure there is nothing restricting the dial from turning (sticky gunk behind it, etc.).
Aug 19, 2010 | Kenmore 24 in. 16302 Built-in Dishwasher
Dishwasher will not start cycle.
OK so you have power, your door interlock switch is working, the intake solenoid is operating.
The issue is that the cycle does not start. This would indicate that your timer is not advancing. The timer tells the machine what to do, when, and for how long. It is not advancing and is stuck at the start of the wash cycle (fill with water). This is not a big issue as a timer is usually easy to replace.
I don't know what type of machine you have so I don't know if is a mechanical or a digital timer.
If mechanical dial type you can simply tun the dial and see if the cycles change. If so for sure you timer is the issue. You simply remove and replace.
Digital is harder to check but from what you say it is most likely your timer.
Shut the breaker off.
Remove the screws from the door frame and from inside the door. Gently remove the control panel. The timer is a simple unit to remove. Unscrew it and disconnect the power supply. Go get a new one from your local parts supplier. Installation is the reverse of removal.
Hope this helps, if so please rate this answer.
Mar 20, 2010 | Dishwashers
It won't begin the cycle. The counter works but
Door not latcning or faulity door switch. fauilty timer or motor. dosent fill float switch faulity or stuck open or clogged inlet valve.
Nov 20, 2009 | GE 24 in. Profile PDW7800 Built-in...
Dish washer stck in wash cycle
The reason for your dishwasher to be pausing in wash cycle because it is not heating, most d/w timers will lose power to the timer motor until the wash tub has reached a desired temperature, if it’s not heating the water it will not advance, although it still could be the timer itself but most likely a faulty heater element or thermostat, does the timer advance at all? If so where timer dial pauses (gets stuck) open door and check water temp (just feel) and close door give it 10Min's or a bit more and water should get a lot hotter (anywhere from 45°c to 75°c) note if it is hot fill water may be hot but not hot enough to trigger temp thermostat to activate timer, if your handy and can see its not heating try to check the Resistance of thermos and heater.
Thank You for contacting Fixya.com
Aug 09, 2009 | Electrolux Dishwashers
Machine not functioning
HI, this is a damaged timer device. the mechanism has failed and , it is unable to correctly initiate the proper washing cycle. simply replacing the timer/control will fix this issue..
Jun 03, 2009 | Maytag Dishwashers
Water is not coming into my Maytag dishwasher.
Is the door open or unlatched?Make sure the door is completely closed and latched. On models with a dual-digit display, the control displays "- -" during a cycle if the door is not latched. Check for obstructions (spoons or utensils), that may be interfering with the door operation. A lower dish rack that is installed backward will also cause incomplete door closure. The lights for cycles selected will flash if the door is opened while running a cycle.
Is there power to the dishwasher?Check your household electrical box to see if a fuse has blown or if the circuit breaker has tripped. If the unit has a plug-in power cord, make sure it is plugged in.
Does your dishwasher have a rotary timer knob?The cycle selection must match the position of the timer knob. Turn the timer knob to the beginning of the preferred cycle. The timer knob should click when you reach the start of the cycle.
Is the control lock option activated?
The indicator light next to the lock graphic will illuminate when the controls are locked. Press and hold the Heated Dry option (button with lock icon) for three seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.
Is the delay start option activated?To cancel the delay and cycle, press Start/Cancel twice.
Is the water shutoff valve turned on?Make sure that the water shutoff valve is turned on.
Mar 03, 2009 | Maytag 24 in. MDB6600A Jetclean II...
Dishwashers Logo
176 people viewed this question
Top Crosley Dishwashers Experts
Andrew Taylor
Andrew Taylor
majorbean
Level 1 Expert
southside773
Are you a Crosley Dishwasher Expert? Answer questions, earn points and help others
