Question about Sony DDS SDT-D11000/ME DAT Tape Drive
Unlocked tapes recognized as locked
The unit sees unlocked tapes as locked. It also kicks tapes out without even reading them- a lot.
  • 661 Answers
This is probably due to a stuck microswitch in the tape drive unit as the locked tag presses a microswitch when loaded it is possibly these microswitches that are failing, as one of the switches detects if a tape is loaded and the other detects is a tape is locked, so problems with these switches would mean that it cannot detect if the tape is loaded properly.
Posted on Sep 30, 2008
How do I unlock my amazon prime account?
need to notify amazon about account information --on wrong site this is fixya a repair forum
Sep 06, 2017 | Amazon Computers & Internet
Why doesn't phone recognize SIM card?
your phone is carrier locked. it weill not accept a sim fromanother carrier unless it is unlocked/ sim unlocked.
Aug 29, 2015 | Blu Cell Phones
I cannot use scanner Lide 25.. because show error : "release the lock switch,detach the I/F cable and reconnect" How solution?
Sounds like the scan head is locked. This is usually done so you can transport the scanner without bouncing the scan head out of alignment. Look under the scanner and you will see it. Make sure it's in the UNLOCKED position. You may need to power the unit off/on to reset it or restart your computer to get a fresh attempt at the scanner.
Mar 05, 2011 | Canon CanoScan LiDE 25 Flatbed Scanner
I was waiting inside our 2011 Toyota Sienna for my husband to return. Without me doing anything, the car locked and unlocked 14 times in total. I grabbed my tablet when this all started and kept a record...
I would contact a dealer locally and see if they can check the system for fault codes . many times when we have key fobs in our pockets they get activated just walking from the buttons getting depressed by other things in the same pocket .
Cell phones even make what some refer to as B U T T calls .
Mar 16, 2017 | Toyota Sienna Cars & Trucks
Doorlocks keep locking even when out of the
Dave, it would appear that at one point one of the manual locks were forced either to unlock or lock and has now repositioned the nuetral point at a different location on the locking rod, hence, sending false readings to the control unit to either unlock or lock, I would try this, close all doors and manually lock them see which lock lever look unlike the rest in that position, this will be the culprit and have to be reset on the rod behind the door trim panel. This advice is as best as I can give without manually seeing the car. Drive safely
Jan 19, 2010 | 1999 Pontiac Montana
Change batteries and sd card locked displayed, new batteries and new unlocked card installed
there is a small plastic lock switch on the left side the down position is locked if it is reading locked in either position try putting a small piece of tape over lock area
Aug 26, 2009 | Canon Cameras
My Visioneer 8650 flatbed scanner with auto document feed gives a message when I try to scan a document, telling me to move the switch on the bottom from the "locked" to "unlocked" position. The lock is...
Actually a very common problem. Try the following:
1. Power down then re-power up the scanner.
2. Try slightly moving scanner. Sometimes a small change works to fix.
3. Change one of your scan setting to flatbed scan (not adf). Do a test scan under this setting. This will usually kick start scanner unit to unlock.
4. Last resort, by does also work...give it a medium slap on the side, sometimes unjams the scanner light.
5. Super last resort, power down over night, it almost always works the next day. (could be that lock up is heat related to scan lamp, dont know but just a guess).
Excellent scanner, so worth the effort to try these fixes.
May 22, 2009 | Office Equipment & Supplies
94 Chevy Camaro-won't start
I would say you would have to take off the inside door panel and remove the mechanism and security switch to see why it is jammed in a locked position, even though you have unlocked the door the electric switch {maybe rusted} is still signalling a lock position, the switch may be located on the actual key barrel, but same check to see why its not moving into an unlock position.
hope this helps.
Apr 26, 2009 | 1994 Chevrolet Camaro
Sd memory card is locked and wont unlock
Hey rpl2125,
It sounds like you covered your bases, but you could try putting a piece of tape over the write protection switch and see if this works. If the tape doesn't work then there is most likely a defect in the memory card and you are going to need to replace it, and I would contact the manufacturer to see if it is under any warranty, and if it is they will often just send you out a new one.
Sincerely,
Allan
Go Ahead. Use Us
May 14, 2008 | Cameras
Xerox Phaser 6250 fuser issue
I was stressing out to change the fuser. But, your directions were as simple as A-B-C. Thanks a lot!!!! It worked
Sep 02, 2007 | Xerox Phaser 6250DP Laser Printer
Sony DDS SDT-D11000/ME DAT Tape Drive Logo
176 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
