Question about Sony Cyber-shot DSC-W50 Digital Camera
How do i use sony digital camera as a web cam?
How do i use my sony digital camera DSC-W35/W55as a web cam???
  • kasey1975 Oct 15, 2008
    got the camera but not the manual? I need to know how to use this camera how can I download it
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sony Master
  • 102,366 Answers
Take a look at this.
Posted on Aug 14, 2012
4 Suggested Answers
SOURCE: HOW CAN I USE SONY DSC-W35 AS WEB CAM
my save this problem,and my sony DSC-W35 is not use to webcam
Posted on Mar 06, 2009
  • 11967 Answers
SOURCE: SONY DSC-W35
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 05, 2010
  • 102366 Answers
SOURCE: how can i use sony
Unfortunately you can't. The DSC-W35 is designed to store images (and incidentally videos) to memory, not to stream live videos to another device.
I know that wasn't the answer you wanted to see, but there it is.
Posted on Sep 03, 2010
I want to change the language of my cam from japanese to english sony dsc-w35
Press MENU to display the menu. Press cursor-right, select Settings (toolbox icon), press cursor-right again. Use the cursor keys to select the "A" icon and press the button at the center of the cursor pad.
Apr 12, 2011 | Sony Cyber-shot DSC-W35 Digital Camera
How can i use sony w35 digital camera as web cam ?
Sep 03, 2010 | Sony Cyber-shot DSC-W35 Digital Camera
W35 as webcam
no you cannot use this camera as a web cam
Feb 05, 2010 | Sony Cyber-shot DSC-W35 Digital Camera
Can i get a free manual for sony cyber-shot dsc-w35 digital camera?
yes there is a manual where u can download online for that model....check this website than just download the manual...hope this is what ur looking for..
http://esupport.sony.com/US/perl/model-documents.pl?mdl=DSC-W35&region_id=1
Sep 13, 2009 | Sony Cyber-shot DSC-W35 Digital Camera
How can i use my dsc-w35 as my web cam
hi..
u cant use ur camera as a webcam... it doesnt suits for any other model...
thank u
rate me!!
Jul 15, 2009 | Sony Cyber-shot DSC-W35 Digital Camera
Nov 18, 2008 | Sony Cyber-shot DSC-W35 Digital Camera
Switching b/n internal and memory stick
If they mendted it and you still have the problem. Then they did not do a proper job- did they? So send it back with full detail of the last repair ans tell them to do it properly at their own expense
Aug 01, 2007 | Sony Cyber-shot DSC-W35 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
79 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
