Question about Garmin Nuvi 610 GPS Receiver
Nuvi 310 faulty internal speaker
Thanks so much for the prompt reply to my problem- I did as u suggested and I get sound clear and unbroken and clear voice instructions when headphones inserted but nothing when not. This makes it impossible to use as a bluetooth receiver for my phone as well as not being able to hear the directions. It was purchased at end of March this year so should still be under warranty. However as I am in Australia I am finding it impossible to find a Garmin Centre here to take it to. GME in australia no longer handle them as they advised me today. so I was wondering if u knew anywhere here i could take it for repair as sending it overseas is very cost prohibiting and worrying for me. It is a garmin nuvi 310 Australian version
Many thanks and kind regards
Robyn- batgirlxxx56
  • 1 more comment
  • dustyjoe Mar 10, 2009
    No sound from my internal speaker Nuvi 310
  • Anonymous Mar 12, 2009
    same problem on my NUvi 610
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    Hi Robyn,
    Yes, Garmin's headquarter's is in Kansas, US and I am in the US as well. The farthest Nuvi I worked on was from the UK. Garmin's website has a link for an Australia contact. See below. Unfortunately, I don't know of a local shop in Australia where you can get it repaired. Since it's under warranty, you shouldn't have to pay for the repair. I'd call the number below and see if they can help with the shipping or at least pay for the shipping back to you. - Jim
    http://www.garmin.com/garmin/cms/site/au...
    Australia
    Hours of Operation
    Monday – Friday: 8:30am – 5pm EST
    Email Product Support
    Australasia.Support@Garmin.com
    Phone
    1 800 235 822
Give the salesman some good oral sex.
Hope this helps!
Posted on Oct 20, 2008
Tip
No Sound or Garbled Sound on a Nuvi Series GPS
I've seen many posts of "No Sound" or "Garbled Sound" for the Garmin Nuvi Series. This is a common problem with the Nuvi.
In order to troubleshoot this problem, we need to determine if it's a hardware or software issue or a setting issue.
No Sound:
1. Try the obvious. Is your volume setting turned up?
2. Is the sound muted with the mute button?
3. If your Nuvi has a FM transmitter, is it selected to "FM" or "Speaker"? The "FM" setting will mute the internal speaker. Setting it to "Speaker" will send sound to the speaker.
Garbled Sound:
1. Does the sound seem to be better at lower volume settings?
If you still can't hear audio or if the sound is garbled, then we now have to determine if the internal speaker is defective. The easiest way to do this is:
1. Plug a set of headphones into the headphone jack. Now try listening to the sound. Listen for the touchscreen beeps, MP3 audio, voice directions, etc. Try adjusting the volume using the headphones. If you can hear sound through the headphones and it's clear and not garbled, then your internal speaker is defective.
The headphone jack is not only a jack but it's also a switch. When you plug in your headphones, the audio amplifier of your Nuvi is switched from the internal speaker to the headphone jack. When you unplug the headphones, your Nuvi's audio amplifier is reconnected to the internal speaker.
Now, if you can't hear audio through either the internal speaker or the headphone jack, you may have a different problem.
1. The internal audio amplifier (hardware) is defective.
2. There is a software problem. You could try resetting your Nuvi with the reset button or perform a factory reset. The software problem is more likely if you can hear MP3 audio or touch screen beeps but not speech.
The internal speaker has a voice coil. The voice coil is nothing more than a thin piece of long wire, wrapped around a magnet, numerous times. If you can't hear any sound, it is very likely that this coil is "open"; meaning that the wire has broken inside. If the sound is garbled, this is an indication that the speaker is mechanically defective and not reproducing the sound as it should. The speaker has a "diaphram" that moves in and out as it reproduces sound. If the diaphram has been damaged, it can't move in or out like it should and reproduce the sound clearly. There is also a possiblity that the voice coil has shorted windings, meaning that instead of it being a long piece of wire, it's now shorted to its adjacent windings and is electrically shorter now. Again, this can impact the reproduction of sound.
So, why did your speaker go bad?
1. It's possible it was defect in the manufacturing process and failed prematurely.
2. You might have had the volume up too high. I recommend using the lowest volume level possible. High volume levels put greater stress on the diaphram and may overheat the voice coil.
3. A speaker is an electro-mechanical device. It's subject to being damaged if you happen to drop or jar your Nuvi and/or operate it outside of its normal operating parameters.
What's the Next Step?
If your Nuvi is under warranty, I strongly suggest that you contact the manufacturer and tell them what happened. Tell them all of the steps you have gone through to confirm that the speaker is defective. If the warranty is still in effect, they should repair or replace your Nuvi.
If your Nuvi is out of warranty, try calling the manufacturer anyway. You have nothing to lose. Maybe they will replace it anyway.
If you have no sucess with the manufacturer, you will need to take your Nuvi to someone who is qualified in repairing your Nuvi.
I hope this tip has been helpful to you. Feel free to contact me if you have further questions or require further assistance with this problem.
Best wishes,
- Jim
http://www.sharcnet-usa.com
on Oct 01, 2008 | Garmin Nuvi 350 Car GPS Receiver
Tip
No Sound or Garbled Sound on a Garmin Nuvi GPS
No Sound:
Garbled Sound:
Best wishes,
- Jim
on Sep 30, 2008 | Garmin Nuvi 660 GPS Receiver
I've updated my map for garmin nuvi 310 through malfreemaps but it did not work well. The map did not display as detail as they preview. I also lost the guidance voice. And my car picture keep off the most...
It sounds like you may have wiped out the Garmin internal maps with the malfreemaps and they aren't compatible with your unit. You'll have to send it in to Garmin to have them reload the units software and maps.
Oct 14, 2009 | Garmin nuvi 310 Car GPS Receiver
Everything works fine on the unit no problem until
if this side of it works then the FM transmitter is faulty
Check that the sound has not been MUTED
plug the earphone into the socket to see if any sound is heard. The socket is also a switch that takes sound from internal speaker to ephone and reverse.
If no sound is hear in either FM or normal mode your unit is faulty and needs repair
Jul 24, 2009 | Garmin nuvi 250W GPS Receiver
Tip
No Sound Issue on the Garmin Nuvi Series
No Sound:
Garbled Sound:
Best wishes,
- Jim
on Sep 30, 2008 | Garmin nuvi 350 GPS Receiver
Sound Breaks up on my GPS if I raise Speaker over medium
Try listening with headphones rather than the internal speaker. If you can hear the sound in the headphone jack clear with the volume all the way up, then the internal speaker is bad.
- Jim
Sep 25, 2008 | Garmin nuvi 350 GPS Receiver
360 Sound lost
Try listening with headphones. If you have sound there, then your internal speaker has gone bad.
- Jim
Aug 18, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Garmen nuvi 660
If you can hear audio through the headphone jack but not the internal speaker jack, then the speaker is bad.
This is a problem I have seen many times before. I will be posting an article soon on how to replace the internal speaker, however this is not a repair that just anyone can do.
You have to have skills in dissassembly & soldering.
- Jim
Mar 21, 2008 | Garmin Nuvi 660 GPS Receiver
Viewsonic Monitor sound problem
Hi check the sound cable hasn't fallen out or come loose from the back of the monitor. After this reinstall the drivers for the monitor you will be able to download them from viewsonic if still not working then the speaker jack or speakers are faulty.
Hope this helps
Thanks J
Jan 20, 2008 | Computers & Internet
Garmin Nuvi 610 GPS Receiver Logo
158 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
