Question about HP Computers & Internet
When I go to turn on my laptop the lights flash but nothing happens. It has to be plugged in constantly as the battery life is really bad and so as soon as it is plugged in all the lights flash and it won't turn on.
    Problem Solver:
  • 5 Answers
If you have a cd on the cd rom same times hapen.
Posted on Oct 02, 2008
Battery light flashes and nothing else happens
Yes, the socket broken loose could be your trouble and is common as we are not careful when we insert the plug all the time.
Apr 19, 2012 | Computers & Internet
I have a fujitsu e8410 which will not start up properly, when i push the start button it shows power but then the fan comes on and the cap num and shift lock leds flash and nothing else. can you help?
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Mar 31, 2012 | Computers & Internet
I have a HP/Compaq 6510b laptop computer and it will not turn on...I have the charger plugged in and the only thing happening is the green light periodically flashes...Is the battery bad?
IF the battery is bad the charge lndicator on the laptop will flash (But not periodically) it will be a constant on-off-on-off..... Best check would be to remove the battery completely and use the adapter/charger power supply only. If it still does not turn on then you either have a bad power jack connection or a more serious motherboard problem. Also is the green light flashing on the adapter/charger or is it the charge/battery indicator on the laptop?
Feb 17, 2011 | HP Original HP COMPAQ 6510b 6515b 6710b AC...
Flashing Charging Light on AC Power
shortage on the motherboard, needs new motherboard.
Mar 09, 2009 | Toshiba Tecra 9100 Notebook
Compaq laptop won't turn on
Take out the battery completely and only hook up the adaptor and see if it turns on then. If it turns on then your battery is bad. If you try both adaptors and get the same flashing lights then the motherboard is bad.
Feb 04, 2009 | HP 435768-001 - Compaq Presario C300...
Green battery charging light flashing and computer won't start
Have you tried removing the battery and replacing it again?
Oct 30, 2008 | IBM ThinkPad T22 2647 Notebook
My laptop won't turn on
Charlotte
Can you remove the battery? If so pop it out and leave it out for a couple of minutes then pop it back in and see what happens.
Regards
Nick
Oct 26, 2008 | Lenovo ThinkPad T61 Notebook
Powers on Immediately poers off
This could be a bad memory chip or slot problem. remove the memory and try one chip at a time in each slot. If this doesn't work then the problem will most likely be in the power management system on the motherboard. This will require professional diagnosing in order to track down the exact problem component.
Aug 27, 2008 | Dell Inspiron 5160 Notebook
My battery has stopped charging, and the battery charge light flashes green, then yellow. Is it the battery or charger?
I'm assuming you mean the battery of a laptop. Laptop batteries have a shelf life, which is shortened if the laptop is constantly plugged in the wall. By the same token, if your laptop is constantly plugged in the wall, you don't really need a new battery. (They cost upwards of $80)
Jul 16, 2008 | Computers & Internet
Gateway mx6030 laptop won't turn on
Hello there:
hopefully you got the right adapter for the machine and if so and still no lights or nothing you can try to hold in the resetr button on the back of the machine and turn on the power at the same time and see what happens if still nothing i would look at getting the machine serviced by a authorized dealer
you may have a bad board or the internal cmos battery is dead or there is a loose connection somewhere ok?
best regards michael
Apr 09, 2008 | Gateway MX6030 Notebook
Computers & Internet Logo
27 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
