Question about Samsung U900 Soul Cellular Phone
Replace screen can you please tell me how you take the original screen off to replace it with a replacement
  • marie7126 Oct 02, 2008
    Hi i have cracked the screen I have found replacement one but can remove the old one!
  • 35 Answers
This website has all the info on how to disassemble the U900 and put it back together you can also buy the LCD and Case from them if you are in the UK.
http://www.formymobile.co.uk/u900disassembly.php
Posted on Apr 17, 2009
Tip
I went with this replacement screen when i cracked my original, I've also...
I went with this replacement screen when i cracked my original, I've also replaced my wifes iPhone 5 LCD screen so I've had some experienece.
Right off the bat, you need to take your time when replacing these. Any one thing can go wrong and thats where I feel a majority of the bad reviews for this product stem - people dont know what they're doing, rush it and cut, crimp, bend, or break something.
You will need to remove things from the original screen like the metal backing, clear plastic camera hole, rubber piece for ear slot, wire mesh for ear slot, grounding tape (attached to original screens metal backing), etc. Any decent youtube video will tell you this. If you want your replaced screen done properly, do this. You will need to add a straight edge blade to your tool arsenal, doesnt need to be sharp but a box cutter blade is ideal for working the screen out of the housing (just above the headphone jack is the place to work the blade in between the housing and the screen). Then use the provided plastic tool to work around the edges to fully remove the screen.
I wont lie, even with experience, after putting my new screen in, I had blue lines show up initially, I went back to the screen connections on the motherboard and rechecked them. After loosening the metal plate a bit the screen worked fine. I tightened it way too tight, drive them in so they're snug, not like they're keeping the wheels from falling off your car. You will also need a work area to keep track of all the little pieces, if you have parts left over you did something wrong. Also, when fitting the screen back into the housing, run your fingers down the side touching the screen and housing, with slight force, do not push on the middle of the screen!
What I didnt know - restart your phone after completion to ensure the finger print reader on the home button works! This thing is very sensitive and any loose connection will botch it. Not realizing this and figuring I did something wrong, I spent way more time then i shouldve troubleshooting... All I needed was a fresh phone restart and finger prints worked like a charm. PROVIDED this was my original home button, that was attached to my original motherboard. IF YOURE REPLACING YOUR ORIGINAL HOME BUTTON FINGER PRINT ID WILL NO LONGER WORK!
This apple replacement parts worked like a charm for me, and for $30 thats pretty awesome. Becareful, watch a couple youtube videos, and good luck! Apple IPhone LCD Screen Digitizer Assembly Replacement Parts Wholesale
on Apr 10, 2017 | Electrical Supplies
Tip
Specifications of Apple iPhone 7 LCD Screen
Compatible with: Apple iPhone 7
For Apple iPhone 7 LCD Screen and Digitizer Assembly with Frame Replacement - Black
This item includes the following parts:
1. LCD Screen;
2. Digitizer Touch Screen;
3. Front Frame;
Note: Please test the functionality before installation.
Specifications:
Screen Size: 4. 7 inches
Resolution: 750 x 1334 pixels (~326 ppi pixel density)
Display Type: LED-backlit IPS LCD, capacitive touchscreen, 16M colors
Protection: Ion-strengthened glass, oleophobic coating
Type of Connector: Buckle
Features:
• This iPhone 7 Screen Replacement includes the components as mentioned above, it does not include the small parts.
• The Apple iPhone 7 LCD screen and digitizer assembly with frame replacement is original and brand new.
• The Apple iPhone 7 screen replacement is available in Black.
• This iPhone 7 LCD Assembly is 100% brand new and original, and each product of Rootmi Goes through strictly inspection before shipping out.
• This LCD screen and digitizer assembly with frame replacement is compatible with iPhone 7 only. Please do not confuse it with other version. For Apple iPhone 7 LCD Screen and Digitizer Assembly with Frame...
on Apr 06, 2017 | Electrical Supplies
I can getting power but nothing pops up on the screen please tell me what I can do to make it work??
Is it the original power supply? If not, does the voltage and amperage match the original? Try without the battery. If it doesn't work, replace the power supply.
May 16, 2014 | Computers & Internet
Installed New RAM in laptop. Led works but screen is blank.
Welcome to the wonderful world of laptop ram
There are many different makes and configurations of Ram and unless the replacements are exactly like the ones that are in the machine all bets are off.
If it says Samsung on the original chips then you need to source a Samsung replacement.
You cannot just buy "Ram" from anywhere and have it work, you may get lucky but !!
go to www.crucial.com and type in the details of your machine they will tell you what is compatible and more important what your motherboard is capable of running.
If you search using your own machine then their diagnostic tool will check you machine out and give you a report
They are a brilliant company who have never let me down yet
Jul 01, 2009 | HP Compaq 6730s Notebook PC KS128UTABA$422...
Acer 6920g had a cracked screen...ordered a new one..doesn't work
racist maybe? hah. just kidding. but you should check to see that the connecting part of the screen (where the screen connects to the "computer") and see if there was anything loose (due to shipping) or if there are any anomolies in the chinese screens as compared to the original korean one.
(also, i was wondering if you could PLEASE tell me how to remove the screen, i know there is the keyboard bezel, but how do i remove it?)
Jun 10, 2009 | Acer Aspire 6920 Notebook PC
Touch screen no longer works
once the ribbon connector is broken you will need to replace the clamp, tape will not hold the 4 prongs down
Aug 16, 2008 | Nintendo DS Console
Mother board dead
Hello how are you. Please give me ome detailed information the make and model of the computer. i will help you with this. Easy. This is what I do for a living.
Thank you hope to here from you
Feb 10, 2008 | Intel Motherboard
Blew the fuse in the cigarette adapter
I got replacement fuses at Radio Shack.
Dec 05, 2007 | Lowrance Iway 500c GPS Receiver
Samsung U900 Soul Cellular Phone Logo
128 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
