Reset computer on 2006 Jetta with TDI
Check "Coolant" Light is on and the coolant is fine
rockitman187
  • 2559 Answers
SOURCE: locate engine temperature coolant sensor on jetta TDI 2004
Posted on Jan 08, 2009
dealt_soul
  • 296 Answers
SOURCE: im receiving a check coolant
No the light is linked to a sensor. There is a coolent sensor that tells you that the level is low. It sounds like the sensor has gone bad. And the sensor is located in the coolent tank. If it is bad from my understanding you have to replace the whole tank. But take a paper clip with the engine off and disconnect the wire harness from the sensor and jump the wires and see if the light goes off.
Posted on Jan 20, 2009
  • 11 Answers
SOURCE: 2006 vw jetta tdi service engine light reset
With the key in the ignition (but not turned), press and hold the Odometer Reset Button on the right hand side of the panel. While still holding that button, turn the key (although not far enough to start the engine) and then press and hold the Minute button on the left side of the instrument pane(if pressing doesnt work try turning the knob clockwise until service light has gone off and skip the pressing)l. Release both buttons at the same time.
Posted on May 30, 2009
j_del
  • 1586 Answers
SOURCE: VW passat coolant warning light on
There's a level sensor plugged into the bottom of the coolant reservoir. Unplug it and clean the contacts with electrical contact cleaner. If that doesn't do the trick, replace the sensor.
Posted on Dec 01, 2009
TDISLine
  • 1874 Answers
SOURCE: need exact location and picture
The exact locations and picture of Engine Coolant Temp (ECT) sensors on 2004 VW Jetta TDI:
1. ECT sensor 1 placed on cylinder head:
2. ECT sensor 2 placed on the left bottom side of the radiator:
Posted on Sep 22, 2010
Jetta 1.9 TDI 2006 the cooling fan comes on five minutes after starting
sounds about right if in heavy traffic or hot day
the air con one comes on with air con
engine cooling fan on sooner than normal
things to check
check coolant level
replace thermostat
fan relay or resistor
check coolant hoses and clamps for leaks
faulty thermostatic fan motor switch
Nov 03, 2016 | 2006 Volkswagen Jetta
I want to replace cooling temperature sensor but I can't locate where it is? I have a Haynes Repair Manual book but it is not clear. My car is Volkswagon Jetta TDI 2000. Does anyone know please give me...
COOLANT TEMPERATURE SENSOR THREADS INTO A COOLANT PIPE NEAR THE COOLANT OUTLET.LOOK AT SMALL COOLANT PIPES AT RADIATOR.YOU WILL SEE A SENSOR WITH WIRES CONNECTING TO IT.WITH COOLANT COOLANT HOSES CONNECTED TO IT.COOLANT TEMPERATURE SENSOR IS BETWEEN TWO COOLANT HOSES CANT MISS IT.YOU HAVE TO SQUEEZE CLAPS ON HOSES WITH PLIERS IN ORDER TO REMOVE HOSES FROM COOLANT SENSOR.
Apr 13, 2011 | 2000 Volkswagen Jetta TDI
2003 vw jetta oil light came on and went off the car has oil in it. today the oil light came on and the temp gauge went up and came back down and the car started ticking. it did this twice within a few...
Check your coolant level and condition. If you havent' replaced the coolant in a while then change it. You can drain it from the bottom of the radiator plug. You may also want to change your oil and oil fiter.
Aug 17, 2010 | 2003 Volkswagen Jetta TDI
Check engine light is on...what will reset it? I have cleaned air filter, filled coolant, added one quart of oil..but no difference in the way the car runs..which is fine. this might be the sensor problem...
Have the code read at the local Auto Parts store and repair the fault causing the light to come on. It is most likely the O2 Sensor that needs replaced. Once it is replaced you can have the fault codes reset and the light will go out.
Jul 06, 2010 | 2003 Volkswagen Jetta TDI
Dashboard says STOP check coolant???
The Coolant Level sensor in the reservoir has detected a low level of coolant. Add some to the round coolant bottle at the right rear of the engine compartment
Jan 13, 2010 | 2002 Volkswagen Jetta TDI
I have a 2003 volkswagen jetta, no owners manual, outside temps have been really cold, below the temp gauge a temp light comes on and a chime sounds, temp gauge runs fine, had a friend ck coolant, it...
does it do this first thing when its cold out ?? if so, fill the coolant res to the max line when cold, if light still comes on, it could be either the coolant leven sensor (my guess) or the temp sensor for the engine- these are known to go bad every few years
Dec 11, 2009 | 2003 Volkswagen Jetta TDI
What does this warning light symbol mean?
the 'comb' is a thermometer,it's the 'hot'light,indicating high temperature of coolant.check coolant level,check for leaks.
Oct 12, 2009 | 2001 Volkswagen Jetta TDI
Check eng light came on '05 jetta tdi
it should be near a coolant hose or your water pump
Jun 19, 2009 | 2005 Volkswagen Jetta
I have a 2003 VW jetta tdi
You've lost engine coolant somewhere, and need to fill the engine back up with the VW special G12 coolant.
Then find the leak, which will be in one or more of the following places -
Water hoses to heater core, including any other coolant carrying hoses in the engine compartment
Radiator hoses
Plastic manifold bolted to side of engine which is known to leak (have replaced on an '01 VW Beetle, and an '02 Jetta, both members of our family in the past few years.).
Overflow reservoir cracked
Radiator leak.
Reply back what you find. If the engine got too hot, you may need to have the thermostat replaced.
Feb 03, 2009 | 2003 Volkswagen Jetta TDI
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
