Question about Garden
Instructionmanual universal brushcutter & trimmer head model tc002
4 Suggested Answers
  • 1341 Answers
SOURCE: Do I need Special grease for Brushcutter/Trimmer shaft
No grease is grease but there is sillicone used nowadays as it just looks clean to use. Now check if it does use some kind of oil in the system.
Posted on Aug 03, 2009
barterjoe
  • 344 Answers
SOURCE: I have a Toro trimmer/brushcutter
I would recommend talking to Zach at www.arcolawn.com he is super helpful. He can look it up and send you parts fast.
Good luck
Joe
Posted on Apr 08, 2011
  • 100 Answers
SOURCE: i want to fit an edger to my brushcutter
only if your model is designed for attachments and that is one of them
Posted on Oct 25, 2012
How do I replace the upper drive shaft on a Ryobi RBC430SEC brushcutter?
I couldn't find this model on google, but when replacing drive shafts in most brushcutters we used to slide the cutting head / gear assembly off the bottom of the shaft, remove the circlip holding the drive shaft if there was one, slide out the shaft from its square hole in the clutch at the motor end. If the shaft was broken we'd slide the motor part off the shaft to get the broken part of the shaft out.
Nov 10, 2014 | Garden
I purchased an 8 inch heavy-duty brushcutter blade for my Ryobi 30 cc four cycle powerhead how do I attach it to the string trimmer head
You can't use the blade on most string trimmers unless you have a brush cutter style then you would unscrew the trimmer string head and attach the blade with the adapter that came with the unit.
Oct 23, 2014 | Garden
How to change heads on stihl fs 81?
There should be a hole in the gear box for a pin. Insert something in that hole to hold the shaft from turning and unscrew the head. I believe it is reverse thread
Jan 01, 2013 | Stihl String Trimmer Brushcutter Service...
Spear & jackson brushcutter sbc33n1 manual
how do I take the strimmer head off and fit the brushcutter blade on my SBC33n1?
Jun 29, 2012 | Garden
Need diagrams on how to wind line onto brushcutter spool model mtd pro bc230c-rs
Howdy Geoff,
There are basically 2 basic types of spool heads that are wound. This link will walk you through both types. Once you've successfully wound it once, it's not too difficult. http://community.homedepot.com/t5/What-s-New-in-our-Garden-Aisles/Replacement-String-Trimmer-Head/m-p/151/highlight/true#M4
Coach Dave
Oct 27, 2011 | Garden
I have a makita backpack petrol strimmer fitted with a line head can i fit a brushcutter blade instead i donot have the full model No it is a 41cc engine it is an early model
Hi Doug,
There are adapters for just about every combination of trimmer, brush cutter blade, grass gator, etc. you can think of.
One of the most handy purchases has been a non specific arbor adapter set. Not only does it have 2or 3 each of the most common nuts in both left and right hand thread, it has inserts that keep every blade, flail and brushcutter I've tried dead center.
It even came with a diamond shaped one for a skillsaw blade that I tried with my Ryobi 4 cycle. That thing turns thorny blackberry vines to powder.
So the answer is yes.
Best regards
Aug 14, 2010 | Garden
How do fit a hedge trimmer attachment to a rbc 40 sb brushcutter ? thanks
This unit was not made to have interchangeable heads. Ryobi makes a hedge trimmer attachment for some of its units that are quick connect.
Otherwise, you may buy this attachment and see if you can interchange the head from the brushcutter to the hedge trimmer. You may find it more work than you want to tackle.
Sep 26, 2009 | Ryobi Garden
Garden Logo
152 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
