Question about Compaq Presario R3000Z Notebook
Compact Presario R3000
Sometimes when i press the start/on button it will not start up
Rundll32.ex
to answer your question use the find function(right click on start button and choose explore)
in upper right panel, type in rundll32.exe and it will show you where to find it
May 20, 2012 | Compaq Presario R3000 Notebook
How do i turn on my wireless capabilities on my presario compaq laptop
hi
press the wireless button until it shows your wireless device enabled
Dec 09, 2010 | Compaq Presario R3000 Notebook
I have a presario R3000 notebook. just like to ask if the fan for ventilation underneath is working in a certain temperature. or it will automatimatically running when i plug in.. can some one help me....
There are several models of this notebook depending on the processor. Some only have one fan, otehrshave two. When operating the fan should start running. I have the higher spec R3000 and my fans start soon after the machine is turned on and sometimes throttle down if I have no activity. Upon starting to use it, they soon start again. Considerable hot air will come out the right back and side.
DO NOT block the air intake(s) on the bottom of the unit !!! You can burn up the processor.
Sep 25, 2009 | Compaq Presario R3000 Notebook
Black screen on mu compaq R3000
You can try:
reseating / swapping the memory
booting the computer with the battery out.
You probably damaged the motherboard with the drop.
There are a few other things you can try too, but let's try the easy stuff first.
Jun 17, 2009 | Compaq Presario R3000 Notebook
Restart problem
make sure you have no disc in a drive no usb sticks or any removeable storage!!!Then try again.
May 31, 2009 | Compaq Presario R3000 Notebook
Compaq Presario R3000 dim screen but not dark
Sounds like the auto-dim in the BIOS is set too low. Fortunately the Compaq R3000 allows you to adjust the brightness right from the keyboard. Hold down the [FN] function key while tapping the [F8] key will brighten the screen, while [FN]-[F7] will dim it. The settings are different for running on AC power and battery, so you must do each individually.
Dec 31, 2008 | Compaq Presario 700 470024-192 Notebook
No wireless connection with laptop Presario R3000 (anymore!)
If your volume buttons don't work either this should help. Place your laptop on a table and press down on the lower right of the computer(under the arrows near the microphone and headphone symbol) or clamp down on the battery compartment (center). The blue light on the corner should illuminate, if it's off press the network button while putting pressure(the indented one on the right front edge) you shoud hear a double ping sound. I put a thick felt pad between the battery and the computer andnow everthing works. I know it sounds really STUPID but it works.
GOOD LUCK
Richard.
Apr 15, 2008 | Compaq Presario R3000 Notebook
Laptop wont power up.
LS-120 SuperDisk drive help Next, connect the power and boot the computer and install the software ... as the computer beeps or pressing and holding CTRL as the computer is booting up.
Good Luck, Read and folow instructions/Please dont for get to Vote/Thank You.
Dec 25, 2007 | Compaq Presario R3000 Notebook
Compaq Presario R3000Z Notebook Logo
52 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
