Question about Asko Dishwashers
My ASKO 1253 dishwasher sometimes floods for no aparent reason. I have run the cycles with covers off & it will run fine. All hoses etc are free flowing. Flooding is random & hence the dreaded intermitant problem. Any hints?
Cerfer39
  • 709 Answers
SOURCE: Water flooding out
Hi KellyW,
The dishwasher drain hose may be clogged.  When the dishwashr starts up can you hear the water running into the Sink faucet drain. If not inspect the hose that attaches to the Sink Drain for restrictions.  Also in the bottom of the dishwasher you should have a filter.  If this filter is clogged you cannot expel water.  Clean the filter.
Posted on Oct 23, 2007
SOURCE: anti flooding system
yes I will for $14.99 !
Posted on Aug 28, 2008
Nzero
  • 78 Answers
SOURCE: Asko dishwasher D1876
unblock your filter. unplug all hoses and electrical cords. tip unit up and clean the filter out. should stop all your problems
Posted on Sep 01, 2008
rickzilla
  • 706 Answers
SOURCE: Dishwasher flooding
When you say that you tried other solutions.. it's hard to know which you've tried and which you haven't so I will suggest some basics first.. ( if you've tried them, then disregard)...
Have you checked or addressed the following:
  1. Cleaned the drain filter
  2. Checked the drain hose for crimps or restrictions
  3. Sure the drain system ( such as your feed thru the garbage disposal isn't clogged or restricting flow)
  4. Checked your water pump for an obstruction or you can determinbe if it is actually pumping
  5. The feed and returm hose ..to anf from the pump are not clogged, pinched or restricting flow.
These are the basics that you should have examined or confirmed aren't causing the problems you are seeing. One other as well.. are you sure your water inlet valve is completely shutting water from leaking in and over-filling the system? Check these items and you should be able to diagnose where the problem is.. Hope this helps you,
Posted on Sep 21, 2008
  • 423 Answers
SOURCE: asko dishwasher 1253. water sitting
If the water is clean, no odor and is less than one inch of water, this is normal for almost every dishwasher made. The water lubricates the gaskets and sump assembly.
Posted on Aug 11, 2009
ASKO Model 1253 Built in Dishwasher - not draining/pumping water on any cycle
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Aug 27, 2011 | Dishwashers
Our Asko dishwasher slowly fills with water after it has finished washing, this happens over a couple of hours. Asko model 1253.
Check the inlet water flow to the machine. Clean the strainer attached to the junction of the rubber hose and the machine.
The strainer is submerged in the machine body. Pull it by hand and clean. It is small in size.
Sep 22, 2010 | Asko Dishwashers
Asko D3230 dishwasher pump will not turn off, with main switch on
This is a anti flood activation. It is a safety device (polystireen float and micro switch at the base of the washer) that keeps the drain motor running due to water leak / spill detection. Dry the water and rectify the leak (normaly pipe or clamp leak) and this should solve the problem.
Mar 26, 2010 | Asko 24 in. D3250 Built-in Dishwasher
All the lights stay on after a cycle completion even after I siphoned all the remaining water in the filter sump.(After opening and closing the door. ASKO model 1585)
Hello, the reason for the light flash error is the unit either didn't drain properly, overfilled somehow or has a leak which is filling the "overfill basin" ( it's designed to, that way it doesn't get to your floor...in theory ). Check your drain hose by removing it where it connect's to your home plumbing via under sink pipe or food diposer/garberator. You'll also need to remove the lower access panel, or kick plate as it is sometimes referred to, and absorb the water in the basin before it will run a cycle...or wait a few days for enough water to evaporate from the basin ( shut off the power/breaker before doing so ) then look for evidence of a leak. Check at the fill valve, (to the left) the drain pump, (slightly to the left-center) as well as the circulation pump & hoses, ( it is much more difficult to see...directly behind the big gray main sump assembly). That should get you moving forward. The Asko can be a challenge to work on if you've never worked on one. That is why I usually suggest calling a pro, preferably an authorized Asko servicer. It may save many unessasary part's being changed as I see too often with these. Hope that help's, good luck. macmarkus :)
Feb 28, 2010 | Asko 24 in. 1585 Built-in Dishwasher
My Asko dishwasher is not draining. Code F2
drain plugged, hose kinked or discharge pump bad
Jan 19, 2010 | Asko D1976 Built-in Dishwasher
Dishwasher flooding
Sep 21, 2008 | Asko D1716 Built-in Dishwasher
My Asea 1502 Dishwasher gets most of the way through a cycle then stops with lights flashing. It is empty of water. What is the problem?
Further to my problem with my 19 year old ASKO ASEA D1502 Dishwasher .
I found a Use & Care Guide online at the ASKO site:
http://www.asko.com.au/downloads/manuals/
(It is an 8MB PDF, only 20 pages scanned)
The manual says flashing lights in the combo I had indicate heater fault.
Manual has good test procedure and I followed that and it showed that the Heater is OK.
Machine works through full cycle but flashes at the end.
It is an old machine so I suppose I just live with it unless anyone has any suggestions.
Apr 23, 2008 | Dishwashers
Asko D1796F1 builtin...lights are on but no one is home
Our Asko D1796 dishwasher has the lights on the panel working as usual but you can't select a cycle and it won't turn on. We unplugged the pipe. If we turn it off and wait for 12+ hours we have gotten it to work twice.
Mar 02, 2008 | Asko D1796FI Built-in Dishwasher
Dishwashers Logo
192 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
