Question about Kenmore 72802 Gas Dryer
Kenmore Elite Dyer Model # 11071082000
Our kenmore dryer is not giving off heat using the SELECT BUTTON such as the Cotton/Towels button or the NORMAL button. But if we sellect the TOUCH UP button and press START in a few seconds you will hear a clicking sound and the ignitor will glow and soon the gas valve opens starts giving off fire or heat but will only last less than a minute and the fire is gone. By the way, I opened the access door that's why I was able to see the ignitor glows and gave heat for few seconds. I tried to check if there is a scorch on the ignitor but can't see it unless it's taken off. I tried to start it again for a few times but the same result. Please help... Thanks!
  • 3 more comments
  • bayanko Oct 01, 2008
    Can you give me a diagram or images on how to replace the two little coils on the gas valve. Thanks again.
    I already replaced the 2 coils but still the heat will only last for a few minutes. Any suggestions which parts should I try to replace this time. Please help. Thanks
  • bayanko Oct 03, 2008
    Yes,I did clean the venting and even changed the aluminum vent with a new one but still the gas valve shut off in a few minutes (< 2 minutes). And when it shuts off I will restart it again but to no avail because this time it will not fire up anymore. Thanks again.
    I checked the back drum seal and it's okay but still flame cuts off. Thanks
  • bayanko Oct 07, 2008
    After I replaced the the thermistor and the high element thermostat the dyer works now. We made about 6 loads already and its seems working fine now though I'm still observing it. Thanks for all the suggestions and adviced I do appreciate all the help that was given to me.
  • 943 Answers
Hi. thanks for the question. the problem you have is with the coils ,on the gas valve. 2 little coils . replace them. thanks the appliance doc
Posted on Oct 01, 2008
  • 2 more comments
  • john gagnon
    john gagnon Oct 01, 2008
    no. sorry .but i can tell you how. You said you saw from the access door ,ok the 2 coils are right there. small black round coils one with2 wires the other with 3 wires , held in place by a metal bracket held down with 2 star screws . remove the bracket remove the coils .replace them thanks the appliance doc
  • john gagnon
    john gagnon Oct 02, 2008
    Hi did you clean the venting to the outside thanks
  • john gagnon
    john gagnon Oct 03, 2008
    Hi .did you check the back drum seal. it has to seal ok there . try the dryer without the venting on and see if the flame still cuts out.
  • john gagnon
    john gagnon Oct 04, 2008
    one more suggestion the air dudt where the lint filter goes into . remove and clean thanks
Kenmore gas dyer, model 11170092991. Won't start. Control panels lights work. when "start" button is pressed nothing happens
Hi
If your dryer doesn't work or start please check the bellow link to troubleshoot your problem :-
http://www.repairclinic.com/Dryer-Troubleshooting?red=Dryer-Repair-Help#itdoesntworkatall_electric
Please get back to us if you have further query else please accept the suggestion.
Feb 02, 2011 | Kenmore Elite Oasis 7808 Gas Dryer
Kenmore Elite Smartheat Quiet Pak 9 won't start. Light turns on and off inside drum when door opens/closes, but no lights come on on the outside display.
My Kenmore Elite dryer keeps beeping..just going through the end of cycle alarm-high,low,off...anyone have any suggestions?
May 30, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore elite home dyer won't heat up
Here's the tech manual, but you're going to need an ohm meter for testing. Here's the Tech manual https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%203979621.pdf
Good luck.
Apr 14, 2009 | Dryers
Decreasing Timed Cycle Setting in a HE5 electric dryer
I think you need to cancel and restart to change the time to less.
Jan 14, 2009 | Kenmore Elite HE4 Electric Dryer
My dryer wont stay on.
you have a bad microcomputer or as some calls it (even heat board) thats needs to be replaced / if you cant find one contact me with the complete model number from the sticker inside door area and i will see if i cant help you with one / larry
Dec 12, 2008 | Kenmore 63942 Dryer
Kenmore elite dryer model #110.63952102 start button wont stay on everything else works
I have the same problem with my Kenmore Elite dryer (model#110.74992300), and I replaced both the motor and heater relay and the problem solved. You can get the relay from www.mouser.com for $3 each. The model for the relay is T9AP1D52-48. You may want to open up the dryer to verify the relay model, it is printed on the relay.
Sep 20, 2008 | Kenmore Elite 20972
Kenmore 67082 "PF" power failure code
Check your circuit breaker. Reset it even if it doesn't look tripped. It is a dual switch and sometimes you can't tell if one of them is tripped. Then try it. When you reset the breakers leave them off for about 10 minutes before turning them back on.
Dec 24, 2007 | Kenmore 67082 Electric Dryer
Model 11060052991 kenmore elite dryer
For heat issue I had replaced the heat relay switch a year ago and that worked. For the start button holding issue I replaced the motor relay switch and the dryer is fine again.
Nov 25, 2007 | Kenmore 63942 Dryer
Kenmore 72802 Gas Dryer Logo
216 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
