Question about HP LaserJet 2420 Printer
Attention light flashing- says replace black cartridge
Have replaced black cartridge and attention light still flashes. The only way to get it to print is to open the top cover and close it. The printer then checks itself and retrieves data, then prints. Have to open the top plate every time to print.
  • 1 more comment
  • DrakonisLuna Nov 14, 2008
    Same problem except opening and closing top cover has no effect. The message implies that this is a color printer which it is not. The error message is not listed anywhere for this printer. HP provides no help.
  • stackjlm Apr 01, 2009
    jallejar, what is the gobutton on an HP laserjet 2420dn? I have the same issue with the attention light flashing replace black cartridge.
  • Anonymous Apr 27, 2009
  • 47 Answers
Try reset the printer. Turn off powerswitch, press gobutton, turn on powerswitch while pressing gobutton. hold approx 15sec and release the button. The printer will reboot. Clean the cartridge contacts and HV pins in printer.
Posted on Nov 22, 2008
I still waiting for solution.
Posted on Jan 28, 2009
Attention light flashing, showing - 10.92.00 cartridges not engaged
10.92.00
The black cartridges are not engaged correctly.
? Open and then close the front door.
? If the message persists, make sure all
the print cartridges are seated correctly.
? Clean the contacts on the memorycontroller
PCA.
? Make sure that connectors J302, J303,
J304, and J305 on the memorycontroller
PCA are seated correctly.
Also make sure that connector J1020 on
the DC controller is seated correctly.
? Replace the memory-controller PCA if it
is damaged.
? Check the gears on the print-cartridge
drive motors. Replace defective motors.
? Replace the DC controller.
Jul 08, 2011 | HP Office Equipment & Supplies
I was printing several pages & it just stopped working. the ink button & on button flash. Changed the ink cartridges but still get the same blinking with no printing. Turned both the computer...
Press the Ink Cartridge Replacement button and check the flash pattern of the control panel lights:
ERROR and POWER lights flash at the same speed = replace black cartridge
ERROR light flashes twice as fast as the POWER light = replace color cartridge
Jun 04, 2010 | Epson Stylus Photo 1280 InkJet Printer
Light with the triangle flashing - printer stopped
That means ATTENTION, you are either out of toner or have a paper jam.
Feb 18, 2010 | HP LaserJet P2015 Printer
How do i get the cartridge out
Press the fontb1.gif maintenance button. The print head moves to the black or color ink cartridge replacement position, the fontp.gif power light begins to flash, and the fontb1.gif error light begins to flash or remains on. When both cartridges are out of ink, the print head moves to the black ink cartridge replacement position first. After replacing the black cartridge, press the fontb1.gif maintenance button again to switch to the color cartridge replacement position.
Oct 20, 2009 | Epson Stylus C40UX InkJet Printer
Attention lights are still flashing orange after I have replaced the black ink cartridge
You can try to remove internal batery for one hour and put back. Then it will reset self.
Jul 11, 2009 | HP Deskjet F2210 InkJet Printer
Kodak5500aio printer will not print
You will need to replace it. There is almost no way around it.
Mar 28, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Flashing light indicators for replacing ink cartridges.
If the light is flashing no matter the speed, remove the cartridge and inspect it. If it is low you may still be able to print some more, but if it's small ink well is empty you will not be able to print even in black only until you replace the cartridge. Hope this helps.
Mar 16, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Hp lj 2500 flashing yellow light
The yellow-print-cartridge
light is blinking, and the
printer stops printing.
 The print cartridge is
empty or missing.
 The printer cannot
detect the print
cartridge correctly.
1. Reinsert or replace the print cartridge.
2. If the print-cartridge light is still blinking but the
Attention light is not on, turn the printer off and
then back on.
3. If the problem persists, repeat the above steps
with yellow print cartridges until the error is
resolved.
4. If the problem persists, replace the printcartridge
E-label reader, which is located on the
pressure assembly of the print-cartridge
carousel.
Jan 09, 2009 | HP LaserJet 2500L Printer
Attention Light Flashing
Unfortunately, HP didn't make this indicator very descriptive. Their product specification page for this printer states that the blinking Attention light, "indicates that the printer media input trays are empty, the print cartridge door is open, the print cartridge is missing, or other errors".
You've already changed the print cartridge and the light is still blinking, so you should take a look at the other conditions described such as an empty paper tray, open door, and so forth. You also will want to look for a paper jam or carriage jam. These are two very common errors that will result in a blinking Attention light.
HP.com does provide a web page that describes a specific problem associated with a blinking Attention light:
Job Stuck in Queue
See if any of these suggestions work out for you. If not, post back your results along with anything else that you've learned about the problem. Good luck.
Oct 08, 2008 | HP LaserJet 1020 Printer
HP LaserJet 2420 Printer Logo
311 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
