Question about Car Audio & Video
My car is cr-v 98 but since i replace new battery, my cd player & radio is not working anymore,but every time i turn on the radio it says enter your 5 digit code numbers. But i don't have the code.
    New Friend:
  • 161 Answers
OK this is what i would do in this situation: get the model number of your stereo (usually located on the top or bottom of the unit) and the make and either go online to a tech support or call the company directly because what the 5 digit code is is an anti theft system so if anyone steals your stereo they can do anything with it because it locks itself out.So thus if you can contact the company and get the passcode youll be in the green and have a stereo again :)
~jarrid~
Posted on Sep 30, 2008
Is there a way to install a aux input on a crosley cr-9 juke box radio? Thanks
You would have to break into the cassette player's audio output section. By finding where the audio joins the main amp of the unit. You couldn't do it via the record input section as that uses a different pre-amp which would not be compatible with CD. Once you find the point where the cassette audio joins the pre-amp section of the main amp, you should be able to take a link, from a pair of phono sockets that you will have to mount somewhere on the unit. If you don't use the cassette anymore than you can disconnect it. If you do want to use the cassette then the best bet is to also install a switch that will switch between the two. You will not be able to have both cassette and CD wires linked to the same pre-amp input. As one will vastly reduce the volume of the other. Which is why you would have to install a switch between the two.
May 02, 2017 | Crosley Audio Players & Recorders
Replaced battery,turn radio on, get code message, enter 5 digit code and radio works. Turn radio off and back on and get code message again
Fix Honda Radio "Enter Code" lockout after dead battery ...
? 1:51
https://www.youtube.com/watch?v=epnMePibIQA
Nov 12, 2013 - Uploaded by EpicReviewsTech
Yesterday the battery died in our Honda- and after the hassle ofreplacing it I thought all was well- until ...
Radio reset code in 5 minutes for a 2001+ Honda CRV CR ...
? 5:27
https://www.youtube.com/watch?v=b0GNkf-BDXs
Mar 21, 2013 - Uploaded by Zawbone
Note: sometimes you can find the code sticker in the glovebox. ... trick should work for 2001 and newer Honda ...
Honda CR-V Questions - How a i found radio code - CarGurus
www.cargurus.com > Questions > Honda > CR-V
CarGurus
Jan 17, 2016 | 2003 Honda Accord
Hi i have a Honda Accord 2006 SE. It has a 6 disc CD changer and it had been working fine. Suddenly now i am seeing CR ERR message and CDs dont play anymore. Whenever i turn on the CD player it says CD...
Personally I would just replace the radio. In dash changers go bad easily and are basically just a problem waiting to happen. The average life span of an in dash changer is about two years.
Sep 15, 2011 | Car Audio & Video
I was told that you needed some code to change the battery. Is this true?
thats if your radio is an anti theft type you need to enter a code to get the radio working again please read your owners manual info should be there hope this helps
Jul 31, 2010 | 2003 Honda CR-V
Car stereo w/ Lanzar amp
check rca wiring to the amp 2 c if it got pinched then try swapping radio with a known good unit if it still happens try swapping amps. or try un hooking the amp then chrank radio up n c if it still doz it if not its the amp.
Sep 26, 2009 | Lanzar 4CH 1000W VIBERANT AMP Car Audio...
My car battery died.when i put in a new my cd player stop working
If your radio is still working, then your power is OK. The Sony CD changer gets its power from the Sony Unilink cable. It is possible that it passed a power spike down to your CD player while hooking up your battery cables.
I just had a CDX-757MX just die a few days ago myself. My radio, amps, and other changers are still working. Could be an unfortunate coincidence.
Sep 09, 2009 | Sony CDX-454RF 10-Disc CD Changer
98 Accord V6 EX CD/Radio no sound despite correct code accepted
check the wirings of your speakers and then check the settings on your radio.
Jun 09, 2009 | 1993 Honda Accord
Honda CR-V 2004 locked CD player and clock
Your CR-V radio comes with a code card. I had the same problem - searched every where - till I found the "Anti-Theft Radio Identification Card" in my papers. If you can't find it you have to contact Honda
Jan 13, 2009 | 2004 Honda CR-V
'03 Honda Accord won't recognize CD player after battery replaced
I have a crv also. the audio system has an anti-theft mechanism, to deter thieves from stealing your cd player/radio. you need a code to turn your unit back on, usually a four or five digit code, that should have been provided when you bought the vehicle. If you don't have it, the unit will come back on after, and only after a full, uninterupted hour of driving.
Dec 22, 2008 | 2007 Honda CR-V
Error 7 on 2005 Honda CRV Radio
I had the same issue with the radio code error lock on a 2005 CRV. I was unaware of the code procedure and had locked the radio in the "ERROR E" mode. I was able to unlock the radio by pulling the #9 back up fuse located in the fuse box in the engine compartment. This reset the radio to CODE which then allowed me to input the 5 digit number which I had in my glove box along with my owner's manual. I am happy to report I now have a working radio/ CD player.
Nov 08, 2008 | 2005 Honda CR-V
Car Audio & Video Logo
76 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
