Wall thermostat has no reading.
A new digital thermostat was installed two years ago by a pro. Worked fine until I tried to fire up the furnace for a "test run". I noticed there was no reading (Ambient temp)on the face of the stat? No on/off switch available on stat (dial). Checked the switch on furnace and reset breakers, still no reading. Took face off stat and its hardwired so no batteries to replace.
This is a gas furnace only, no a/c.
What is going on??
  • Heating & Co... Master
  • 1,711 Answers
You must check for voltage at the stat. If voltage present with no display the stat is bad. No voltage, you gotta find out where it stops.
Posted on Jun 29, 2017
pierre1811
  • 144 Answers
SOURCE: Code 32 when wind blows
Hi and welcome to Fixya. I believe that the wind is affecting the draft. What I would recommend is to install a cap on the flue that is similar to a weather vane in that it rotates to block the wind from creating a downdraft in the flue. Some times depending on the direction and strength of the wind it will come up over the roof peak and then down the flue. A regular fixed cap may work too. You should be able to purchase one at your local hardware store. Please let me know if this was helpful. Good luck.
Posted on Jan 25, 2009
longbranch1
  • 16 Answers
SOURCE: We have an older model (58SG100251) installed in the attic. With the thermostat set & turned on nothing happens. A new blower motor was installed last year.The t/stat is a ritetemp digital. I,ve c
Possible fan relay is defective, does outside unit come on ?
Posted on May 21, 2009
  • 55 Answers
SOURCE: First time using the AC. Won't go on. Heater works.
lower temp setting lower then outside temp should work
Posted on Aug 06, 2009
james3751
  • 614 Answers
SOURCE: i bought a new honeywell digital t stat, now i
Tou may ahve a two transformer system. On the sub base of the tstat there is tterminals rh and rc they come with a jumper wire between them. Remove jumper. Hook the two wires from your heat to rh and w. Hook the rest of the wires Red rc yellow to y green to g and blue or black to c. Thats it . Keep in touch and I will walk you thru this. Rus
Posted on Dec 16, 2009
koolbreezes
  • 540 Answers
SOURCE: why does my furnace gas valve keep going bad
Check the ground wire to the gas valve or the wire in the middle of the gas valve that says mv--pv, and that is a ground..
Posted on Dec 19, 2009
Thermostat sometimes doesn't turn furnace on
Hello Kathy, The first thing that I would do is change the batteries in the thermostat. One or more may be weak and not turn on your furnace. I would put in Alkaline batteries. If that doesn't help, maybe a new thermostat is in order.
Feb 27, 2014 | Hunter 44550 Programmable Thermostat -...
Honeywell RTH2300 says Heat On, but furnace isn't running.
Your tstat is not the problem. I've not yet worked on an oil furnace. I'm way down south. But either way, if your tstat was calling for heat(heat on), and you pushed a reset at the furnace, more than likely that reset is a safety. OK to reset, but now what ever that safety is preventing from happening, has failed and can not be reset until repaired. The reset should be an automatically opening switch upon unsafe operation. And manually closed to "reset" the safety. That safety is connected to something that is not working properly. Hope this helps!
Mar 02, 2017 | Honeywell prgrammable thermostat RTH2300B
We installed White Rodgers 1F81-261 thermostat and Bryant Plus 80T furnace about 2 yrs ago. They worked fine, until now. We tried to set the thermostat to 70F when the room is ~66F. The thermostat...
Does the display seem a little dim? If so replace the batteries. Anything else may be a furnace issue not the thermostat. Look at the furnace and see if you can view any error codes on the circuit board
Oct 31, 2013 | White Rodgers White-Rodgers 1F85RF-275...
Relatively new wall furnace suddenly stopped working.
if you are by passing stat at the gas valve and it is still not working,i would assume a bad control valve.
Jan 13, 2010 | Heating & Cooling
The furnace wont turn on even though it says it is
not all digital thermostats are compatible with the manufacturers circuit control boards in the furnace. Hunter has had this problem several years ago. Other than that you may have miss wired the unit. usually the furnace is used as backup heat (during defrost) or emergency heat if your heat pump konks out. Are you switching to emergency heat for a furnace call?
Nov 24, 2009 | Hunter Fan Company 5/1/1 Programmable...
I had a 14 seers Trane installed 18 months ago. The thermostat goes blank and the system doesnt come back on until I flip the breaker or disconnect power to the ac.
try replacing the batteries in the thermostat on your wall. probably has 2 AA's this may fix it if not may have bad or old wiring from tstat to main indoor system. when you had a trane installed did they change the air condition components only(likely) or did they put in new furnace, new wiring, new t-stat, a full install?
Sep 11, 2009 | Ruud Central System Air Conditioner
GDS80904BNA Goodman furnace only cylces off for a minute
Sounds like your repair man ripped you off. He should have stood behind his work.
1. I would try to clean the flame sensor located just below the burners. It is connected to "one" wire (Not the two wire) clean rod with sandpaper.
2. The old and thermostat could have a had a bad heat anticipator. if the new t/stat is not digital the heat anticpator on the T/stat needs to be adjusted. slide the small adjuster arm under the cover to about .6 or .7 and see if the solves the problem. if the t/stat is digital it should be preset from the factory.
3. last resort have a service man check your pressure swith. could be a slow inducer motor, blocked or bad vacum line, or a restricted drain or flue pipe.
Mar 02, 2009 | Goodman GDS80904BNA Open Flame Heater
Lennox Gas Frunace fires goes out, fires goes out, fires goes out
Check your thermostat anticipator setting. If you dont know how to do this don't try on your own or you may damage your thermostat.
Dec 12, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
