Question about Gateway 7330GZ Notebook
MY GATEWAY LAPTOP SCREEN WENT BLACK AFTER 20 MIN OR MORE
MY GATEWAY LAPTOP LOOK GOOD AND I USED IT EVERYDAY BUT NEVER TURN IT OFF. SO ONCE AWHILE MY SCREEN WENT BLACK AND ALL THE POWER ON EVERYTHING NORMAL. THE SCREEN IT DARK . AND I UNPLUG THE POWER CORD THEN PLUG IT IN BACK AND I CLOSED THE LID THEN OPEN. THEN THE SCREEN CAME ON. SO WHAT THAT MEAN>>?? HELP CNJFB...
  • cookies4478 Nov 06, 2008
    we have a gateway can use it for about 20 sometimes only 15 minutes then it black screens. we close it for about 5 minutes sometimes the picture comes back up sometimes it does not. when it does it maybe last another 5 minutes then black screens again. what can we do to stop this? laptop is only 1 yr old.
Look for cracks in the hinges. It is a big problem with the Gateway 7330GZ.
Posted on Oct 14, 2008
HP Pavilion F1503 only displays a split second?
well, its a 2003 LDC 13 years old ,
its bad
the monitor itself of the power pack to it is bad.
you can test it on any PC< or laptop made
if its dead on all , then its dead.
what more needs saying,
older LCD monitors had old CCFL, lamps. that love to fail
newer are LED back lights that last for ever. it seems
so up grade?
seems your back light is dead
ever do the flash light trick
shine it at the dead screen see good data
yes, then the CCFL is DEAD< (or its power supply ,deep inside)
fixed may but would never do a 2003, not now.
lots of used good LED for sale,
Mar 09, 2017 | HP Pavilion F1503 15" LCD Flat Panel...
My webcam for my emachines laptop, (E627) will either open up and close right away, or the screen will be all black. It happens once in awhile, and it will be okay after awhile. It's been like that a lot...
Try reinstalling your webcam driver using the drivers cd that came with your laptop. If you no longer have the cd, you can download the drivers here:
http://support.gateway.com/us/en/emac/product/default.aspx?tab=1&modelId=1814
Apr 07, 2011 | Computers & Internet
Black Gateway screen Help
I had a problem starting up from the black screen. I went the route of restoring the laptop not know of a possible "common" problem. The following is what I used for my system restore to get my laptop running, perhaps by following the steps to change the bios it might also fix your problem. If anything it doesn't hurt to try at this point.
URL: http://forums.techguy.org/hardware/582490-freezing-during-full-system-restore.html
do these steps to disable SpeedStep in the BIOS Setup Utility and then run System Restore again on your computer.
1. Turn on the computer and begin pressing the F2 key in one-second intervals. If you perform this step correctly, you see the BIOS Setup Utility menu. If Windows loads normally, repeat this step.
2. In the BIOS Setup Utility, press the RIGHT ARROW key to select the Advanced menu.
3. On the Advanced menu, change the Intel SpeedStep setting from Enabled to Disabled.
4. Press the RIGHT ARROW key to select the Exit menu.
5. On the Exit menu, select Save Changes and Exit
6. Restart the computer and run System Restore.
7. After completing the restore, download and install the Critical Update for Windows XP (KB885626) package from the Microsoft Web site.
8. Once the KB885626 package is installed, re-enable Intel SpeedStep in the BIOS Setup Utility.
Jul 07, 2010 | Gateway 7330GZ Notebook
While downloading a Cd to listen to on my laptop
That places the PC in "Standby". Simply press the power button on your laptop.
Jan 03, 2010 | Gateway M305CRV Notebook
Screen is black
The cable is dislodged or you have a failing lcd.If you want to repair this yourself.Check online for a replacement cable and a Lcd too.Then you will have to open the Lcd Bazel to remove or check the cable.Make sure when you attempt this there is no power attached ,battery and Ac Adapter.
Good luck
Nov 02, 2009 | Gateway 450ROG Notebook
I'm betting that you need a new "Inverter" board, especially if it's a Gateway 450ROG.
There is an inverter that Gateway used in several models that has a known defect.
Inverters are relatively inexpensive ,and easy to replace. You could ven do it yourself if you have a little skill at disassembly / re-assembly. Tell me the model number of your laptop and I can help you more
Apr 10, 2009 | Gateway 40G / 40GB for laptops /...
Gateway laptop 7330gz
Some possible causes
--Some laptops have a function key that can turn off the screen when you have an external monitor running. Check your documentation to find out.
--The lamp burnt out.
--Cover switch (when you close laptop) is stuck/jammed/loose.
Sep 15, 2008 | Gateway 7330GZ Notebook
Black screen on gateway 450sx4 laptop
sounds like ,audio card went died or mite be screen has shorted out try hooking it up an orther screen and see if it boots up if so either viedo screen card or screen it self
Jun 02, 2008 | Gateway 450SX4 Notebook
Gateway laptop
Doesn't sound too good - Could be a bad ram chip (right on the bottom of the laptop under a panel - try removing one or the other chips) or possibly bad motherboard (which is definately not worth it on a several year old gateway machine if you could even find one)
Let us know if the ram does it.
Dec 27, 2007 | Gateway M305CRV Notebook
Gateway 7330GZ Notebook Logo
427 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
