Question about Sony PlayStation 2 (PS2) Console
PS2 cannot read disc error
Hello, i keep getting this message when i put a game into my PS2. i took the cover off and blew out the dust with an air can. i wiped the lens with a qtip. what else can i try? thanks!
Get new one
Posted on Sep 30, 2008
Turn on my PS2 and I get a read disc error. Can I have the directions to fix this?
Disc Read Errors (DREs)
The PlayStation 2 was infamous for the number of disc read errors that occurred. There are a number of causes for this problem and a number of fixes:
  1. Clean the disc: Dust or smudges from fingerprints can cause disc reading problems. Use a high quality cleaning cloth and remove all smudges from the disc by lightly wiping outward from the center hub. Do not use a circular motion.
  2. Clean the disc drive: If not the disc itself, dust buildup in the drive is often the culprit. For the tech savvy, you may remove the disc drive, and gently clean the assembly with a cleaning cloth. For a less intrusive approach, use a can of compressed air, and attempt to blow the dust out from the vents and the disc tray, though this may also cause dust to settle where it is not desired.
  3. Repair the disc: If your game disc is scratched, it is sometimes possible to recover the disc with a disc repair kit.
  4. Ensure proper venthilation: To avoid overheating, make sure that your PlayStation 2 is placed in a well ventilated area, and that the vents are not obstructed.
Aug 18, 2011 | Sony PlayStation 2 (PS2) Console
I was just wondering, IF the PS2 can play games that have been edited on a computer/laptop (e.g. 4-disc PS1 game put onto one disc), and not edited as in the actual game disc being edited, but put on a...
Your system needs a mod chip to play games on a disc that was not created by Sony.
Most ps2 games are DVD's only some are cd's.. All of the ps1 games are cd's so if you burnt it onto a dvd its not going to work.
Oct 06, 2010 | Sony PlayStation 2 (PS2) Console
When you put in the dics, and on the screen says not reading disc
Disc read errors are mainly due to weak or dirty lens you should try cleaning lens first.
When your PS2 lens is covered by dust it wont allow laser to read disc so its better to clean your PS2 lens first,if problem still exists then your PS2 lens is weak and you will have to take it to Sony repairer for service.I recommend all of PS2 owners to keep their PS2 at dust free environment.
Watch this video it will help you to learn how to clean your PS2,its easy you can do it at home.
Wish you good luck and hope cleaning lens will solve your problem. Thank you!
Dec 05, 2009 | Sony PlayStation 2 (PS2) Console
Disc read error
Disc read errors are mainly due to worn out lens or dirty PS2 lens.Clean your PS2 lens to get rid of this problem if your lens is dirty.Watch this video it will help you to know how to clean your PS2 lens.Watch it carefully.
Remember to keep your PS2 in Dust free environment if you don't want your PS2 lens to get dirty.
Thank you!
Nov 25, 2009 | Sony PlayStation 2 (PS2) Console
Play station 2 disc read error?
Disc read errors are mainly due to worn out lens or dirty PS2lens.Clean your PS2 lens to get rid of this problem if your lens isdirty.Watch this video it will help you to know how to clean your PS2lens.Watch it carefully.
Thank you!
Nov 21, 2009 | Sony PlayStation 2 (PS2) Console
My PS2 will not read my discs
remove the cover, take out the two tiny philips head screws from the cover on the drive and clean the lens with a q-tip dipped in rubbing alcohol. Do this gently! use compressed air to remove the dust collected inside the unit and then reassemble.
Jan 07, 2009 | Sony PlayStation 2 (PS2) Console
Disc Read Error message...
You could try flashing the firmware..just a shot in the dark, but what the heck, you got nothing to loose. Instructions can be found at the PS2 website.
Oct 22, 2008 | Sony PlayStation 2 (PS2) Console
Sony ps2 read disc error problem
Now this is strange PS2 hangs up..............!!!wHich pS2 u have.........???slim or the old fat one.........???As far as disc read errors are there, u should clean ur lens by using some lens cleaner CD or do it manually[for fat one] urself it not a big deal........becarefull while opening the cover....clean the dust on lens with the tissue or any other light material......the problem can also b with ur disc change that also...........
Sep 17, 2008 | Sony PlayStation 2 (PS2) Console
Ps2- disk cannot be read is it just scratched?
hello try cleaning disc and lense..if disc has scratches .ones that go straight across disc are not to bad but if they follow disc in a circle ,lens will follow scratch as it is reading.when cleaning disc use a cleaner as any thing else will scratch..also try another game to see if your lens is okay .they can fail for no reason.
Mar 03, 2008 | Sony PlayStation 2 (PS2) Console
PS2 problem
It's likely the lazer lens is out of alignment or requires replacing. Did your dvd cleaner also have a lens aligning part to it, you normally go through a spoken instruction(go to track 2 etc), as cleaning is sometimes not the only required solution.
Jan 08, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
22 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
