Smelly clothes Creda Simlicity 1000 W200FW. Clothes smell after washing. Suspect partial blockage in machine pipework but I am told it appears to empty ok.
  • mikesimons Oct 02, 2008
    Thanks tresilla - Problem is not mine but my daughters. See is using liquid and will follow your advice and try power. The problem does seem to be worse when washing is left in the machine after the cycle has finished which seems to point to your second suggestion that it is to with the drain layout. Unfortunately I am not able to examine this at the moment but will do so as possible. Thanks again.
    Mike.
    President:
  • 1,462 Answers
Two things
are you using liquid detergent? if so, change to powder
is there a water barrier in the drain? if not, you are getting the smell from your drains
Posted on Oct 01, 2008
Smelly water & not going into spin
Try cleaning out the pump access port. It is at the front of the machine.
All sorts of stuff gets into these pumps on front loaders. A partial clog will go what you describe.
If you use a mesh laundry bag it will keep this from happening
Mar 23, 2014 | Bosch Washing Machines
BOSCH MAXX WFO 2062
Have you checked the outlet pipe that the machines pipe discharges into ? Sometimes these get filled up with sludge etc and may siphon back in smelly water at the end of a cycle. You could also see where the pipe drains into the sewer system , see if there is a local blockage.
Jan 08, 2014 | Washing Machines
Smelly cloths and on the fast wash did not rinse well
check the drain pump motor. if partially blocked it will restrict the outlet. Open the thumbwheel and remove the lint. Chech the 2 pipes for any blockages
Aug 21, 2010 | Electrolux AWF1220 Front Load Washer
The washer won't spin dry. It fills and empties but the clothes are soaking wet.
If washer is spinning but clothes are wet suspect a partial blockage in the outlet pipe. This will cause the water to drain to slow and leave some in the outer drum while spin occurs but this ends up back in the clothes.
Feb 25, 2010 | Washing Machines
Creda W200FW No: 45177606 washing machine have removed the PCB from a Creda W200FW washing machine and lost the info as to which plug goes where. Some are keyed and will only go on one place but some will...
Hi
I will try to help as best I can
  1. double red plug onto1x2 2
  2. double black wire plug onto 1x9 2
  3. blue black wire plug onto 1x11 2
  4. then 6 wire plug onto 1x5 6
This hopefully will solve your problem.
Please rate my solution.
Thanks.
Nov 11, 2009 | Creda W100FW Front Load Washer
Bad smell in Simpson Eziset 550
pour a few litres of vinegar in the machine on low level of water and do a wash with no clothes in it. should clean tub and drain hose
Sep 06, 2009 | Washing Machines
this could be one of three things:
are you using different washing powder i.e. non bio. sometimes these extra soft washing powders can make your clothes smelly if left for more than a couple of hours.
are you connected to water mains or a well. well water often contain manganese and iron which can discolour and leave a smell too.
last it could be the wash programme cutting short.
Aug 26, 2009 | Washing Machines
WHIRLPOOL DUET FRONTLOAD WASHER
I had similar problem, the front door seal can trap small items,socks,handtowels. I didnt figure this out for some months, each load of clothes had a foul, mildew smell, Check door seal for trapped clothes, run intermittent cycles with bleach only, no clothes, be sure to leave door open when not in use to air out , this will reduce smell.
Nov 27, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Creda machine won't agitate with clothes in it
Your load is prob to heavy for the older washer. it just doesnt have the power to handle it no more. time to replace it, sorry.
Jul 30, 2007 | Creda W120VW Front Load Washer
Washing Machines Logo
100 people viewed this question
Top Washing Machines Experts
