When a programme is selected the washer just goes into a drain mode(nospin cycle though).ive changed selector switch can the only problem be with the main module or is there anything else i can try before spending alot of money for it to turnout to be something else?
It could be that the pressure switch is not clicking off and will only allow the machine to drain the pressure chamber could be blocked take the small pipe off the pressure switch and blow down the tube to see if clear and blow into the pressure switch to see if it clicks it might reset if no click faulty pressure switch no joy let me know
tried that still no joy when any programme is selected it just goes on 15minute cycle drains for a couple of mins then stops.
Im going though my service manual and notes to see if anything can be done I use a computer to plug into the machine module system to get fault codes its difficult to sort out without being there
is your model a actva smart if so it has a built in fuzzy logic in the control module it controls all the motor movements and water levels so it is possible that it could be the module it also might be able to reset it but you will need to plug it into a software programe on a computer no simple fix you will have to way the cost up between spending a bit moor money on the machine or buying a new one
