Question about Samsung RS2534 Side by Side Refrigerator
REFRIGERATOR SIDE NOT GETTING THAT COLD
THE FREEZER IS WORKING PERFECT but the other side is working but not that cold
  • sgao43 Nov 11, 2008
    same problem same model
  • littlerestli Nov 22, 2008
    we already replaced the motor, now fridge side still not cold.Reading at 55 on panel
My side side stainless samsung fridge and freezer not cold
Posted on Nov 17, 2008
They are junk so many problems with mine . when down 4 times
just 2 years old.
Posted on Oct 16, 2008
HVACRH20
  • 237 Answers
SOURCE: refrigerator won't get cold
You likely have a defrost cycle failure. The freezer's cooling coils need to be frosty and cold so the air that the fan pulls over them can cool the fridge section. If the defrost cycle fails, the coils freeze up to a block of ice and air flow suffers (fridge is about 55 degrees F). The freezer stays cold only because there's a block of ice in there now... sometimes that cold "sinks" to the bottom and only the food at the bottom stays frozen (and can even freeze food at the bottom of the fridge compartment while the rest is warm). To be sure, you'll need to take the rear interior panel off the freezer back wall and check the coils to see if they are frozen solid. If they are then there's a defrost cycle failure. If they are showing a nice white frosty pattern evenly all over the coils then that's normal and maybe the evap fan (right above the coils) is not blowing air up properly or is not working at all. That fan should run if the compressor is running, etc. the only time it doesn't run is during an actual defrost cycle. Once you find out what condition the coils are in it should be simple to direct you further on the problem.
Posted on Jan 06, 2007
  • 19 Answers
SOURCE: my freezers works but my refrigerator
make sure all your fans are turning. maybe try to remove the knobs and see if you can turn them without the knobs, possibly they could be stripped.
Posted on Apr 22, 2009
  • 24 Answers
SOURCE: Refrigerator does not get cold - GE side by side
In my GE side-by-side refrigerator (model number GSS20IEMDWW), there is a motor-controlled flapper door between the freezer and fresh food side. Cold air from the freezer side cools the fresh food side when that flapper door is open.
It is located at the top of the fresh food side on the dividing wall between the fresh food side and the freezer. If this is blocked with something (large left-over container, soft drink bottles, etc), it _may_ be enough to prevent sufficient cooling of the fresh food side.
Of course, there may be a more serious problem with the flapper door mechanism or the control unit that signals the flapper door to open/close.
The vegetable and deli drawers may have a small opening (manually controlled with a wheel or a slider of some sort) that connects those drawers to the freezer side, thus explaining how those areas are still functioning as expected.
Posted on Jul 28, 2009
  • 66 Answers
SOURCE: why does freezer get cold but not refrigerator side?
Check the freezer temp (available in most grocery and home improvement stores). The temp should be between 0-10 degrees F (not just barely below freezing).
You can also try to find a solution on www.repairclinic.com or click here.
Posted on Aug 13, 2009
heatman101
  • 43501 Answers
SOURCE: refrigerator and freezer not getting cold side by side
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on May 25, 2010
Have a side by side, the refrigerator side has now become a second freezer, adjusting thermostat has no result, the freezer side freezes perfectly
The controller that regulates the amount of cold air blown from the freezer to the refrigerator is not functioning and allowing too much cold air to enter into the fridge compartment.
Mar 20, 2015 | Refrigerators
My refrigerator is not working on my samsung tyhe freezer does work perfectly just need help with the product
On some refrigerators there is a chute that lets cold air from the freezer section into the refrigerator side. If this fails to open than the refrigerator will not chill.
Also a refrigerator low on charge will act like yours.
Oct 22, 2014 | Samsung RF263AEBP - 26 cu. ft. French Door...
Hello, the refrigerator side is not cooling, but the freezer is working perfectly. Our fridge is 26 cu instead of 25.6
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 11, 2011 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
The freezer section is working perfectly fine but the refrigerator is not getting cold. It has worked before.
heatman101
May 21, 2011 | Refrigerators
The fridge compartment in my Samsung side by side fridge is not cooling, yet the freezer side is perfect. Any ideas?
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 21, 2010 | Samsung Refrigerators
Samsung Side by side Fridge not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Feb 10, 2010 | Samsung RS2556 Side by Side Refrigerator
Jenn-air JCD2289ATW Freezer perfect but refrigerator is warm
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 12, 2009 | Jenn-Air JSD2789GES Side by Side...
Top freezer develops ice on left bottom side.
it has to be connected other wise its true that ice will get collected.because the compressor will give its coldness in refrigerator so the cold air of freezer will also get collected in refrigerator side, because there is no ice dispenser connected.connect the icedispenser.
to make it proper.
Apr 01, 2009 | LG Refrigerators
Samsung RS2534 Side by Side Refrigerator Logo
311 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
