Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA d52w20 will not come on
Hi: Recently my tv shut off. I checked the power coming into the unit. The light in the front comes on for 10 seconds then it goes out. It does not flash. I replaced three caps on the flyback board on the advice of one of the folks on here but I still got nothing. I checked for loose or broken solder connections and ribbon connections and I checked the voltage coming from the power supply which is 24vac. Still nothing.
During the 10 seconds there is a sound in front of the tv that sounds like the tubes are warming up but I never get a picture and then the green light goes out.
HELP !!
What is the problem with the set?
Thanks Mike
  • 2 more comments
  • rorksb Sep 30, 2008
    Hi: Recently my tv
  • michampagny Oct 10, 2008
    How can you test the flyback board to make sure that this board is in fact the problem?
    Thanks
    Mike
  • michampagny Oct 14, 2008
    Is there any way I can double check to make sure it is the flyback before I purchase one?
    Is there anything to check that may narrow down the cause of the set not working?
    Thanks
    Mike
  • vlu_reyes21 Nov 25, 2008
    i see the cp114 capacitor on the motherboard, i cant see the cp 150, where it is place?
  • RCA Master
  • 8,617 Answers
Sounds likje the flyback those sets are famous for the flybacks needing replacement.They dont always blink 3 times when the flyback fails, often they justrefuse to power up.
Posted on Oct 01, 2008
  • Sonny Berry
    Sonny Berry Oct 10, 2008
    There is no way to test a flyback unless you have a flyback ringer, but thats an exspensive piece of test equipment. The flyback for your model is very inespensive.You may also want to check the tops of the two capacitors CP150 and CP114 to see if the top is domed instead of flat. A domed top indicates the capacitor is defective.
Green Screen, No Sound, Shuts off after 10 seconds
Almost certainly the green picture tube is shorted. This is a very expensive repair; probably not worth doing.
Apr 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 HDTV TRIES TO TURN ON 3 TIMES BUT WONT POWER UP
remove all the electrical wire connections from the back of the tv .remove the power plug from the electrical outlet and wait for two minutes and replug the wire and then ckeck.it should work.
reply.
Oct 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w20
it should if you can get one most have been on back order. the board with the ihvt on it is the one to replace
Feb 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA rear projection TV power light blinks for a few seconds but
Look on Deflection board If cp150 capacitor is puffed up on top it is bad there is 3 caps to replace cp150(,2200uf 16v ) cp114,cp120.(220uf 35v). The SSB board can also shut set down.
Jan 04, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA big screen model# D52w20, Chassis# ITC222
Nine times out of 10 the problem is 3 capacitors cp150 2200uf 16v cp111 330uf 35v cp114 220uf 35v look at cp 150 if cap is bubbled up on top it is bad capacitors should be flat on top.
Oct 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 TV not coming on
you may need the AC line filter board which is the small board on the right side of the chassis closest to the front of the TV. If you need more info please let me know.
Sep 09, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA TV Will Not Power On - Powered Off Suddenly
Theses sets had 2 problems pip mod or most of the time Flyback Transfomer bad.
Jul 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Power issue
Same thing, comes and goes; there are times that it would not come back on for 10-15 minutes... any ideas
Jul 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
My rca model P60752EB does not turn on.
this particular rca also know as a itc222 chasis has a safety shutdown cuircit.. if it detect any problem. high voltage. over current over voltage ..one of 20 problems. it will shut down. if the unit tries to come on that idicates its more than just a fuse. first question u ask is after the set been unplug for 30 minites then plug back up does the set come on or try to come on does the led light flash on the front. does it try to come on 3 times then shut down. there is special diagnostic equipment techs used to read errors recorded in the processor.
Feb 01, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
(((((Help))))) Power On problem!!!!!!!!!!!!!!!!
Mine has the same problem.  No solution yet.  Hope you get an answer that is an easy fix.
Oct 28, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
97 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
