Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
TV WON'T TURN ON
Tv just won't turn on- hit the power button and nothing happens. I have the same problem. Model d52w20. Light comes on for 10 seconds then it goes out. That's it. I tried replaceing the three caps on the flyback board and checking for soldering issues as well. Also, I checked the power coming from the power supply and I read 24 vac.
What id wrong with it?
Thanks
Mike
  • michampagny Oct 06, 2008
    Ya. Thanks. I have the Yellow pages and I can find a tv repair person if neseccary. Please do not respond unless you an answer for me. Your just wasting my time and yours.
    Thanks
    Mike
    Scholar:
  • 116 Answers
The hv-splitter is bad. This part has high failure so replace the splitter and R721u.
Check the pin output transistor and associated capacitors. Usually the area around the transistor is discolored from excessive heating of the transistor. Also check the other active components in the pin ckts.
Posted on Oct 06, 2008
    Genius:
  • 1,011 Answers
Dear sir/madam,
try to restart the micro is programed to try to restart the set
if i were going to start looking check your horizontal output transistor see if its shorted and there probably will be a damper diode shorted and a box cap swollen.
Thanks
good luck
    President:
  • 2,712 Answers
1. Try this - hold the menu button down for 10 seconds. TV should power up; you will have to turn off front panel buttons on menu.
2. You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and re-plug to AC power and redo the cabling. Switch on the TV and see if it works..
3. Powering down the set or putting it in standby may have allowed the power supply to cool. Weak capacitors often go out of spec when they cool, thus preventing a section of the power supply from firing up properly again. There is a simple trick...just warm the back of the TV with a hair dryer for 5-7 mins after you have unplugged the TV. Look for the little areas of holes in the back panel of TV. Use these as your guide at where to use the hairdryer, but don't hold the dryer too close (say 5-6inches away). (Make sure the dryer is on High heat). If the TV doesn't turn on after you have heated it up (like it tries to come on but then turns off) you need to unplug the TV again, this resets it. And repeat those steps till it works. Resetting the TV after it fails to turn on is the key. Also, just leave the TV on. Don't turn in off. Since it is LCD, it doesn't take much power...only a few bucks extra a month for your utility bill.
4. If you want to go in for a long term solution, you can easily replace the whole power board. You can find spares and service manual from here:
http://servicemanuals.vstore.ca/
They also provide free online assistance as you attempt a DIY to help you repair the set.
Hope that helps!
  • RCA Master
  • 19,396 Answers
If you want to proceed you need the repair and service manual for your TV, so that you can follow the troubleshooting diagrams and find the defective part.
I do not have schematics for your model so I won't be able to follow you from here.
Sure the problem can be the power board, the deflection board or the flyback transformer, but this parts must be tested to locate the fault. And top test them you follow diagrams on service manual.
Posting as an answer just "TV has a problem with flyback transformer" or "change the power board" will be useless.
You can get the service manual here: Service Manual D52W20, D52W20YX1
Once you got it you can come back to us for assistance in testing , locating the problem, and finding replacements.
Thanks
  • 10,594 Answers
TV have problem in deflection board and its available at Parts Store on $167
If you suspect its power board, its also available at Parts Store on $260
Posted on Sep 30, 2008
    Sergeant:
  • 320 Answers
This is major problem.. This common problem in every RCA tv. So you better call a person who can repair the TV. Even i am doing a research on this issue.. You can use our Fixya service to know the nearest service center by entering the location ZIP code at the starting of the page.. i believe the problem is a part called a flyback part#259296.. To know more, please click on the below link..
Thank you........
Phillips 27PT5445/37 TV won't turn on
Sounds like a power supply issue possibly bad caps. You can get replacement power supplies from www.tvrepairworld.com just hit the contact us button on their website to leave a email with your model number if you dont see your model listed.
Aug 05, 2012 | Televison & Video
I have a 2003 sony kp51ws500 television and there's a timer on the tv and it won't turn on. A red light blinks 6 times then nothing happens. I unplugged, I hit the reset button, nothing happen
read the instruction manual and see how to operate.
if the timer is for to sleep, the problem will be the IC associates with him, you must see the block diagram and w.diagram. and tracking the signal.
go to www. retrevo.com and download the diagram. God bless you
Jul 31, 2012 | Sony Televison & Video
TV won't turn on. red light blinks twice and nothing happens
This is an error code of some fault inside. Kindly call in a qualified service technician.
Jul 25, 2012 | Magnavox 32MF301B LCD TV
TV won't turn on power light flashes 10 times
Switch off the TV from remote, then switch off the on/off button on the TV, remove the plug pin from the power outlet. Cool off for 48 hours and then retry. If nothing works, better refer it to a qualified service technician.
Jul 18, 2012 | Panasonic Televison & Video
Red light comes on but power button won't turn it on
Please confirm actual brand and model as it is not clear what set you have
Mar 11, 2012 | Televison & Video
Projection screen HD tv wont turn on, when you push the power button the light turns on the tv clicks and then go right back off the picture never comes on. This all happens in a matter of seconds.
That sounds exactly like a burnt bulb issue to me which is easily replaceable. But without the exact model of your TV I won't be able to know for sure. If you could comment with the model of your TV I can do some more research for you.
If this helps please give a positive rating.
Jul 01, 2011 | Mitsubishi Televison & Video
I have a D52GW12 tv. During a storm a couple days ago there must have been a power surge. I have managed to get the TV's power light to blink but it won't turn on. How do I reset the Tv or fix the...
Unplug from the wall and hit the power button on the tv. The light may come on dim then fade out or you hear a click. This means it has built in surge protection. Plug it back into the wall and you should be good to go if nothing burnt up.
Jun 21, 2011 | Televison & Video
TV will not Turn On.
same thing,tv won,t come on,unplug the tv, nothing at all,just yesterday my tv was fine, this is the first time this has ever happen
Mar 13, 2009 | Samsung HC-P4363W 43 in. TV/DVD Combo
Power on/off
that is a common problem with this rca's check the convergence board for a short circuit
more likely is a transistor or an convergence ic
caypianan@yahoo.com
Jul 18, 2008 | RCA HD52W58 52" TV
My RCA D52W20 will not stay on
Clicking sound is power relay engaging. If all systems are not functioning properly, unit will shut down to prevent further damage and/or fire hazard
Apr 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
155 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
