Wiring diagram/schematic for kenwood (KR-11000G)
Hi, I am replacing the 4 amp transistors in this kenwood and I think that when I re-soldered the connection terminals , I may have gotten the color codes messed up. Is there any way you can find a schematic for this receiver??? The three colors of the wires are all the same, black, blue ,yellow. Any help would be most appreciated. Also, should I bypass the relay and wire direct to solve any more problems with these transistors?
  • 979 Answers
SOURCE: KR-X1000 Power Problems
Sorry, no freebies from what I see online. But, when you power up, does it play before it shuts down? This will help me formulate a better answer for you...accordianman
Posted on Oct 25, 2007
  • 319 Answers
SOURCE: problem with playing my Kenwood KR-X1000
Unit apparently has problems. Check/replace batteries in remocom
Posted on Aug 14, 2008
docjohn174
  • 943 Answers
SOURCE: Maytag dryer MDE4000AYW change 3 prong to a 4 prong
HI thanks for your question. the red to red black to black white to white green goes to the fram of the dryer. thanks hope i was helpful. please rate my answer.
Posted on Oct 12, 2008
  • 75 Answers
SOURCE: Color code for 4-pin Cobra M75 CB Mic
here is the link that i used
hope it helps
http://www.dxzone.com/cgi-bin/dir/jump2.cgi?ID=8197
Posted on Jul 03, 2009
SOURCE: Wiring for Bosch Hologen Fog Lights? Wiring
Look on the relay for the terminal numbers.
Terminal 30 goes to the battery positive.Red Wire
The two terminal 87 go to the fog lights.Black Wires
Match the color wire with what you have on the relay connection for the rest of the wires.
Terminal 86 should connect to your low beam headlight.
Terminal 85 should go to the fog light switch.
The fog light switch should connect to the terminal 85 and the other terminal on the switch will connect to ground.
Posted on Feb 04, 2010
How to troubleshoot a kenwood kr 5600
These older tuner/amps have protection relays that when latching, are distinctly audible. Does the relay engage after approx. 10 seconds after turn-on? If not, check your speaker wires and/or speakers for issues. With all speakers (and wires) disconnected, the relay should still latch after turn-on. If not then you have an internal problem...likely a older pre-drive transistor that's bias is incorrect, which in turn causes bigger problems downstream.
Jun 01, 2014 | Kenwood Audio Players & Recorders
I have a Cobra 21- 23 channel CB and the wires pulled out of the plug. The mike wire has red,yellow black,blue,whiteand a ground. My plug has only four prongs to solder to. What four colors do I use?
Hello there
Here is the diagram for you
Cobra 29LTD, 29LTD ST, 29WX ST
Documentation Project
CBTricks.com
TIPS:
You need to have Acrobat Reader version 5 or newer installed to view the files with pdf_1.gif icon.
If the files with jpg.gif or gif.gif icon will not display see the Site FAQ for help on printing, viewing and using this information.
Click Picture to See Close-up
DIAGRAMS
Page 1 to 11
Page 12 to 34
29LTD
29 LTD Classic Schematic Diagram pdf_1.gif(Courtesy of Rick Jackson)
Mic Wiring
Stock
1- Shield
2- Audio
3- Transmit
4- Receive
Astatic (4 wire)
1- Shield
2- White
3- Red
4- Black
Astatic (6 wire)
1- Shield & Blue
2- White
3- Red
4- Black
Yellow NC
Daiwa EM-500
Cobra CA Series
1- Shield & Black
2- Red
3- White
4- Blue
Galaxy DC-521S (4 wire)
1- Shield
2- Yellow
3- Red
4- Black
Galaxy CB-660EI
1- Shield & Black
2- White
3- Red
4- Blue
Sadelta
1- Shield
2- White
3- Brown
4- Green
Turner
1- Shield & Red
2- White
3- Blue
4- Black
Yellow NC
Nov 17, 2009 | Cobra 29 LTD CB Radio
Vintage Stereo Connection ???
Hi spanky
Where to start :) I am excited thinking about them :p You got 2 totally cool pieces of classic vintage gear there in the C2 and the Marantz. I have a C2 preamp myself (gathering dust but wont sell it cos its excellent) and the marantz would be totally cool to have(but then I am a little biased towards 70's vintage marantz). They ruled the roost in HiFi amps throughout that decade.
Because they are both integrated amps, you could use them as standalone systems with a pair of speakers, and just plug your favourite gear into them. If you just wanted to run up a nice sounding HiFi, I would sell the kenwood gear and just keep the Marantz. The Kenwood kr1100 has the edge in power, so if it is grunt you are looking for use that. Because vintage sound is all about stereo, you only really need an integrated amp to get great results.
the specs are
# Kenwood Model Eleven G (KR-11000G) Receiver
120W per channel min RMS, both channels driven, at 8 ohms from 20 to 20.000 Hz with no more than 0.03% total harmonic distortion.
Dynamic power output 440W at 4 ohms
Power bandwidth 5 Hz to 70.000 HZ
Frequency response 5 Hz to 100.000 HZ -1.5dB
Signal to noise ratio 115dB
The marantz is a little lower in power at 75rms a channel, but will have the sonic edge in vintage sound over the kr1100. Look them up on ebay and you will find that they do have some value to collectors and people seeking nice tone. There is an 1152 for sale here for AU$900
Best bet is to fire up the 2 integrated amps,and see how they are going. Run them for several hours to be sure there is no strange noises and crackles. Then decide if you want power or finesse.
You could also run both amps from the C2 preamp by connecting to the Amp in connections to the rear of the integrated amps.
happy to talk to you more about it, hit me with a Fixya if my advice was helpful to you. I would keep the marantz, use that and sell the rest and buy some nice speakers:)
regards
robotek
Jul 20, 2008 | Audio Players & Recorders
Kenwood KR-4010 (late 70's vintage) with signal to IF amp but no output
Don't bypass the relay contacts. They serve to disconnect the amp stages from the speaker if a DC condition is present, and in doing that, save your speakers form damage. Check for a DC offset condition on the junction of the emmitter stabilizer resistors to the STK0040 on each channel. They will be 0.47 ohm power resistors(2 per STK) connected to pins 3 and 8 of the STK. Anything substantially greater that 100mv here generally indicates a blown STK. Don't bother to change both, but just the one that is faulty. Another common problem for this age of amp. The high silver content in the legs of the transistors allows for "growth" between legs and internal connections of the transistor. Check for "black death" on the legs of transistors driving the STK. . . I tend to replace them if in doubt. If you need expert advice, comment me back. I am an audio specialist.
Feb 03, 2008 | Audio Players & Recorders
Kenwood KR V8080 receiver
if you sent 110v down the speaker wires & into the amp you most likely have damaged the audio outputs or the output ic. Look for a big aluminum heatsing & on one side you may find 1 or 2 ic's or numerous transistors, the ic's are hard to check, the transistors are easier to check, if transistors replace in pairs. also check for burnt /open resistors near outputs
Aug 18, 2006 | Kenwood KR-V8080 Receiver
171 people viewed this question
 Grubhead
Grubhead
