Question about HP LaserJet P2015n Printer
Ink blots deposit onto feed rollers which in turn transfers to all new prints
I have cleaned ink blot deposits on the visible internal rollers that feed the paper through the machine. However, the ink blots just reappear onto the roller and I get a series of blots on all printed pages as the pages feed through the roller mechanism.
Can anybody advise how I can stop this probelm at source? I s it a fault with the catridge that is causing the deposit onto the rollers. Could it be a deposit on an internal roller that I cannot see and therefore cannot clean easily?
Many thanks.
    Novelist:
  • HP Expert
  • 297 Answers
Most likely you have a leaking print cartridge (toner cartridge). Does it have the same problem if you use the Manual Bypass tray?
It could also be a worn fuser sleeve that is causing the print defect...the fuser would need replaced in that case.
Posted on Jan 17, 2009
Just bought new ink for my printer epson cx4200...it does not print anything ,,i thing the old ink dry out ..how i clean that thank you
Ink may be new, but their nozzles may be blocked; depending on manner of storage. To be sure apply a folded tissue paper to the ink nuzzle and press firmly. If the tissue comes off well blotted with ink it means you still have a good amount of ink in it and the nozzle is not blocked. If not blotted or scantily blotted, it means ink is really low or nozzle is blocked. To be very sure of this, place nuzzle in a plate/saucer with a bit water so that the nozzle is soaked. Leave for about 10 minutes. Then apply the tissue again. If still not well blotted it means ink is really low or empty. If new you should return it for a replacement. In the case of blocked nozzles, the procedure may be repeated over to get results.
Jul 30, 2011 | Office Equipment & Supplies
My Dell cn3110 color laser printer is making faint gray bands down the left and right margins of each page. They are wider on the left side, and irregular, but mostly in the form of diagonal streaks. ...
This is caused by partially blocked ink nozzle. So Apply a folded tissue paper to the ink nuzzle and press firmly. If the tissue comes off well blotted with ink it means you still have a good amount of ink in it and the nozzle is not blocked; ink is flowing well. If not blotted or scantily blotted, it means ink is really low or nozzle is blocked or partially blocked. To be very sure of this, place nuzzle in a plate/saucer with a bit water so that the nozzle is soaked. Leave for about 10 minutes. Then apply the tissue again. If still not well blotted it means ink is really low or empty. If new you should return it for a replacement. In the case of blocked nozzles, the procedure may be repeated over to get results.
Good luck & God bless!
Mar 03, 2011 | Dell 3110cn Laser Printer
Won't print. worked 1 day and not the next. cleaned head and reinserted. prints bad quality photos but no text. What can I do next?
Mar 02, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Epson cx8400. I've put in new black ink cartridge, but when I conduct a nozzle pattern check, the black will not print. I've run head cleaning 4 times & it still won't print black.
For some cases the automatic head cleaning dosen't resolve blocked nozzle issues. For such you simply need to go manual; so please try the procedure below. If you are not at all a technical person get a brother, sister, husband, wife etc who is to help.
Mar 25, 2010 | Epson CX8400 All-In-One InkJet Printer
I put a new black inf cartridge in my 5500
A lot times running clean print heads is not enough to resolve this issue. You need to do a little bit more.
Pleae give this procedure a try.
Ink may be new, but their nuzzles may be blocked; depending on manner of storage. To be sure apply a folded tissue paper to the ink nuzzle and press firmly. If the tissue comes off well blotted with ink it means you still have a good amount of ink in it and the nuzzle is not blocked. If not blotted or scantily blotted, it means ink is really low or nuzzle is blocked. To be very sure of this, place nuzzle in a plate/saucer with a bit water so that the nuzzle is soaked. Leave for about 10 minutes. Then apply the tissue again. If still not well blotted it means ink is really low or empty. If new you should return it for a replacement. In the case of blocked nuzzles, the procedure may be repeated over to get results.
Dec 08, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Installed new ink - not printing blurry in black
Ink may be new, but their nuzzles may be blocked; depending on manner of storage. To be sure apply a folded tissue paper to the ink nuzzle and press firmly. If the tissue comes off well blotted with ink it means you still have a good amount of ink in it the nuzzle is not blocked. If not blotted or scantily blotted, it means ink is really low or nuzzle is blocked. To be very sure of this, place nuzzle in a place/saucer with a bit water so that the nuzzle is soaked. Leave for about 10 minutes. Then apply the tissue again. If still not well blotted it means ink is really low or empty. If new you should return it for a replacement. In the case of blocked nuzzles however, the procedure may be repeated over to get results.
Dec 06, 2009 | Office Equipment & Supplies
My printer will not print at all. All new ink cartridges in it. Faxes won't even print. When I do the cleaning, only blue and red will come out. Can u help
Ink may be new but their nuzzles may be blocked. To be sure apply a folded tissue paper to the ink nuzzle and press firmly. If the tissue comes off well blotted with ink it means you still have a good amount of ink in it. If not blotted or scantily blotted, it means ink really low or nuzzle is blocked. To be very sure of this place nuzzle in a place/saucer with a bit water so that the nuzzle is soaked. Leave for about 10 minutes. Then apply the tissue again. If still not well blotted it means ink is really low or empty. If new you should return it for a replacement. In the case of blocked nuzzles, the procedure may be repeated over to get results.
Dec 04, 2009 | Brother MFC-665CW All-In-One InkJet...
Ink spots on paper
yikes...calibration worked too? there may be some deposits on the head carriers, underneath the cartridges..
cue tip, with denatured alcohol(not Coors or Becks) might reveal some nasty crud in there.
Feb 27, 2008 | Epson Stylus C44UX InkJet Printer
Ink smudging
Run a cleaning sheet through the printer- absorbant papaer- blotting paper. If this machine has had a lot of service it may be your waste tank is filling up and leaking out - have you had a service warning yet?
Sep 16, 2007 | Epson Stylus RX500 All-In-One InkJet...
Printed font
Have you tried running the cleaning utility and alignment utility? Look in the "properties" section of the printer, under "advanced". you should see it.
Jul 16, 2007 | Epson LX-300 Matrix Printer
HP LaserJet P2015n Printer Logo
183 people viewed this question
Ben Johnson
