Question about Lexmark Office Equipment & Supplies
Trying to install a new printer, Lesmark X2500m Color All-in-one but no disc and it is not listed on the options of which printer to set up
  • clapic Sep 30, 2008
    Thank you so much, that did the trick.
  • 268 Answers
To install this printer you need the driver (software which lets the computer communicate with the printer). You can download the software for the printer at this website:
After you download it , simply open the file and it will launch a setup for your printer. That's all you have to do!
Posted on Sep 30, 2008
I need to download the setup disc for my Lesmark P4350 granddaughter misplaced it put new refills in and it wont recognize have been using it only as a copier printer not hooked tyo computor
You can download and install the Lexmark P4350 driver by visiting the Lexmark website at Select your operating system, download and then execute the file. However, if your main problem is the printer not recognizing your cartridges, make sure you are using the correct cartridges for your model (Mono: 32, 34 and Color: 33, 35). You could try to re-seat your cartridges by removing it from your printer. Unplug and replug your printer into the power source to reset it. When the printer turns on, reinsert the cartridges properly. Hope this helps.
Apr 14, 2011 | Lexmark P4350 All-In-One InkJet Printer
How do I make a CD label?
There is a user manual on the install disc, pdf-format. To get to the manual, insert the install disc and wait for the small window to appear. At the bottom are some options, one being "View User's Guide". Click that. Or you could access the pdf-file itself manually and copy it to your hard drive: After inserting the install disc, go to "My Computer", right-click on your writer drive, choose "Explore", double-click on the folder named "SE1", and look for a file called "SE1 Guide.pdf". Open it, or copy it and paste somewhere on your computer for future reference. Read Chapter 4 of the user guide - it is titled "CD&DVD LabelMaker". Here follows the chapter, illustrations excluded:
Chapter 4
CD&DVD LabelMaker makes designing and printing disc labels
and CD/DVD inserts fast, simple, and fun. Customize labels with
your own photos, text, video stills, and music playlists. Hundreds of
professionally-designed themes are included inside. Supports
label paper templates by Avery®, Memorex®, Neato®, CD
Stomper®, and Direct to CD/DVD Printing with supported printers.
Getting Started
When you first start the program, you're prompted to select the type of
project you want to design and print: Disc Label, Jewel Case Insert,
and DVD Case Insert.
Once you've selected the type of project, you'll be prompted to select
the paper to which you'll be printing. Select your template from the list,
and then click OK. (You can also change your project type by selecting
a new one from the top pull-down.)
Designing your label
You can customize various sections of your label/insert depending
on the selected paper type/template. The main workspace in the
Design Label tab starts by focusing on one section of the label/
insert. For example, if you're using paper that has two disc labels, the
focus will be zoomed onto one of those labels.
Adjusting your view
Notice the two up/down arrows on the left side of the screen. When
applicable, you can click either arrow to shift the focus to the top/
bottom of the page. Click the Paper View button in the lower left
corner to see a small thumbnail of the page. Click the section that
you'd like to edit, and it will appear in the main workspace.
Changing the Background
The right side of the screen lets you change the paper background,
either by applying a color (Use Color) or graphic design (Use
To change the background color, select Use Color. A color palette will
appear. Click the color you want. The color will then appear on the
label/insert in the main workspace. The palette is fairly robust. If you
select a new color that doesn't appear on the grid, you can add it to
your My Favorite Colors.
To delete a custom color, select the color, then click the - icon.
To add a design, select Use Theme. A pull-down at the top lets you
select from a variety of categories. Each category offers a variety of
designs. To select a design to apply to your project, simply click it.
Click the button to the right of the pull-down to search for additional
designs online.
Printing your project
A print preview displays your project.
If there are certain sections/components that you'd prefer to exclude
when printing, simply click that object (it will appear dulled in color).
If you change your mind and decide to print the object, simply click the
object again and it will become active for printing.
Print with Mask: This option is only applicable when printing disc
labels. If you notice that your prints aren't aligning properly with your
labels, uncheck this box. Instead of printing over the circular area of the
label only, a square version of each photo will print to cover more area
and fill the disc label.
Select Your Printer: From the Printer pull-down, choose your
Modify Your Printer Settings: Click the Printer Setup button to
view/modify your printer settings.
Set the Number of Copies: Use the arrow buttons to increase/
decrease the number of copies you'd like to print, or key in the value in
the available box.
(To be continued - ran out of space) From: 11407336
Dec 01, 2010 | Individual SlideShow Expressions
Canon imageRunner C5180i Color Copier will not allow multi tray
XP? or similar then go to printers list and double click on the Canon 5180. Then click "Printer" then "Properties" then "Accessories"
Make sure on the options listing that the tray 3 and tray 4 are "installed" or their boxes are checked. This is the only thing I have ever seen cause you not to be able to access certain trays or other options.
Good Luck
Nov 17, 2009 | Canon imageRUNNER C5180i Color Copier
Lexmark x2500m printer do not communicate with Gateway laptop
GAteway..not surprised. phone or email Gateway get some help..its the computer problem.
Nov 21, 2008 | Lexmark X2500 All-In-One Printer
check it on device manager whether the printer is detecting or not, or put usb cable on some different port then check, also uninstall the drivers, then install it again
Oct 21, 2008 | Gateway MX6920 Notebook
Bought Lexmark X2500m can't install says my driver not able to support. My computer is windows Mullenium
the driver of printer support only win xp
so try this driver win 2000
try to email ronaldsuboc
Sep 19, 2008 | Computers & Internet
I purchased a BJC-85 color bubble jet printer in 2002. I have lost my disc to set up printer; I just received a new labtop for work and I dont want to buy another printer. Is there anyway you can take my...
The drivers that were on the CD probably won't work on your new laptop anyway. You can download the latest drivers here (use the box to select your Operating System -- Windows XP, etc.).
You can purchase ink online here. The BC-10 is a black ink only cartridge, and the BCI-10 is the replacement ink tank. The BC-11 is a cartridge with both black and color ink, and the replacement ink tanks are the BCI-11bk and BCI-11clr.
Jul 26, 2008 | Canon Office Equipment & Supplies
Color Printing Problem
If a document displays in color on the screen but prints in black and white, try the following solutions. Print a test page to determine if the color cartridge is working
  1. Turn on the printer.
  2. If you have an HP Deskjet 710c, 712c, 720c, 722c, or 820c series printer, follow the instructions below:
    1. Turn the printer on.
    2. Press and hold down the Power button while pressing the Resume button four times.
    3. Release the Power button.
  3. If you have any other HP Deskjet printers, click here for instructions on how to print an internal test .
  4. If the printout is black and white, with no color, follow the instructions below:
    1. Open the top cover of the printer and remove the cartridges.
    2. Verify that the correct cartridges are installed in the printer. Click here to see if you have the correct cartridges . If the correct cartridges are installed, make sure that the tape has been removed from the cartridge nozzles.
    3. Insert the cartridges firmly back in their cradles and close the latches.
    4. Close the printer door.
Verify the correct printer is selected as the default printer
  1. In the software application that you are using to print, click File .
  2. Click Print .
  3. In the Print dialog box, verify that the name of the HP printer you are using is listed in the Name box.
  4. If the printer is not listed in the Name box, click the arrowhead to the right of the box.
  5. Click the name of the HP printer.
  6. Click OK .
Check that the printer settings are correct
  1. Close the software application that you are using to print.
  2. Click Start , click Settings , and then click Printers .
  3. Right-click the icon (picture) for the HP printer.
  4. In the menu that displays, use the left mouse button to click Properties .
  5. In the Properties dialog box, click the Details tab. (In Windows 2000, click the Advanced tab.)
  6. Check that the driver listed under Print using the following driver or Printer matches the HP printer you are using. The following setting may be in one of several places, depending on your printer driver and operating system.
  7. In the Details tab, click Setup . Under Printout, select one of the color options. (If other options have check marks, click in the check boxes to remove the check marks.) If there is no Setup button, click the Graphics tab, and then click Color . Under Color Control, choose a color option, and click OK . If there is no Graphics tab, click the Advanced tab and look for the text Print in Grayscale . If there is a check mark in the box by Print in Grayscale, click in the box to remove the check mark, and click OK . If you are using Windows 2000, in the Advanced tab, click Printing Defaults . Click the Advanced tab. The box by Print in Grayscale should not be checked.
  8. Click OK .
  9. Close the Printers window.
  10. Open the software application that you were using to print.
  11. Try printing again.
Install a new driver If none of the above options worked, the wrong driver might be installed on the computer. For the most current HP printer drivers, go to the HP Web site.
Jan 09, 2008 | HP DeskJet 882c InkJet Printer
Scanner can't be found & not printing black color clearly
If using windows, goto control panel from start button,double click on printers, if your printer is not listed, reinstall drivers from disc the printer came with. if it is listed, click once, then click on properties, select "drivers" look for "add new drivers" select this, and reload drivers from disc that came with printer.
If it still will not work, look in the printer maunufactor's website for downloads/updated drivers and FAQs....Hope it helps.
Nov 22, 2007 | Philips MF-Jet 450 All-In-One InkJet...
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
