Question about Xerox Phaser 7400/DXF Laser Printer
Xerox 7400 toner superposition problems
Hi, I'm Patrascu Simona from Romania and I have a problem with my printer buyed 2 months ago...ex. if I print a colour made of 50% cyan and 50% yellow it has an eror of 1-2 mm of superposition. Txh a lot for your time.
  • exarte Jan 17, 2009
    Thx, I've done that a long time ago but it didn't help..and the service people don't know how to fix it..so I have a bad printer ..8 months til the guarantee expires and no one wants to replace my printer..because this is how they do it in Romania (please excuse my bad writting skils :))
    Have a nice year!
    Novelist:
  • Xerox Expert
  • 297 Answers
When the colors do not align properly you need to clean the LED printheads. Full instructions on how to do this are located at:
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=110,E=0000000001181486662,K=5398,Sxi=19,Case=obj(1219)
Posted on Jan 17, 2009
Why is my Phaser 7400 printing a solid pink page? The Transfer unit is half pink. Is this why?
This may be a high voltage problem.
Am not familiar with this machine but is a generic fault.
Ensure contacts to drum/cartridge are clean.
Next
If possible, unplug machine, open up and ensure all high voltage connections are good.
Good luck.
Jul 24, 2015 | Xerox Phaser 7400/DXF Laser Printer
Phaser 7400 error 929
Xerox Phaser 7400 error codes 929 - Please check your Waste Toner Auger Assembly if motor won't turn and when you done the sensor test and passed the Waste Toner Auger Assembly was jammed. I just fixed this problem here, just now!
Jan 13, 2012 | Xerox Office Equipment & Supplies
I have Xerox Phaser 7400 with an error 928 we changed the fuser 2 weeks ago now the error has come back
Error 928 refers to the fuser motor failing. Problem could be with fuser motor, motor drive board or engine board.
One other possible cause would be if you are sending too thick a card stock through the machine, this can cause drag on the fuser which the machine interprets as a motor failure.
Hope this helps.
Jan 05, 2011 | Xerox Phaser 7400/DXF Laser Printer
What is error code 941 on a Xerox Phaser 7400?
www.support.xerox.com -phaser 7400- support -fault code-941 says cyan or magenta toner failure, but the solution says to
1. remove & reinsert the cyan or magenta imaging units.
2. replace imaging units .
check out the site to see if helpful
Jul 01, 2010 | Xerox Phaser 7400DN Laser Printer
Xerox phaser 7400 replaced yellow toner, but still getting replace toner error. I've reseated it twice, reseated the imagining unit and tried turning it off.
You can try do a NVRAM reset. If after that you still have the error message then I would tell you to contact the Xerox team as you might have a wrong consumable (defected/wrong CRUM) information.
NVRAM reset: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=36,E=0000000002092637520,K=9394,Sxi=5,Case=obj(3085)
May 16, 2010 | Xerox Phaser 7400/N Printer
Xerox Paser 7400 is not recognizing black toner cartirdges after they are installed
Have you shaken it well and be sure you have all the tape removed from the cartridge? Most of the time with that problem the piece of tape that is over the opening of the cartridge does not come off completely.
Feb 09, 2010 | Xerox Phaser 7400/N Printer
We have a Phaser 7400. It continues to give us
If you've already changed out the toner cartridge and the problem persists, then it could be several other parts that are either defective, dirty or blocked.
You may want to contact a certified Xerox technician and have them look at the Imaging Unit Agitator Bar and the Low Toner Sensors for Cyan/Magenta. There could also be a faulty toner supply motor.
Sep 10, 2009 | Xerox Phaser 7400/DT Laser Printer
Printing
The Phaser 7400 starts at $2,799. see models and prices see cost per print Color: up to 36 ppm Black: up to 40 ppm First-page-out time as fast as 12 seconds 800 MHz PowerPC processor Maximum paper size: 12" x 18" All models come standard with 10/100Base-TX Ethernet connectivity Standard paper input capacity: 800 sheets Maximum paper input capacity: 3,000 sheets Finisher/stacker/stapler/hole puncher capable of handling up to 1,000 sheets Maximum duty cycle up to 150,000 pages per month What comes in the box show/hide contents Color toner cartridges (capacity: 9,000 pages each 1 ) Black toner cartridge (capacity: 15,000 pages 1 ) Imaging units (capacity: 30,000 pages per color 2 ) Waste cartridge (capacity: 30,000 pages 2 ) Fuser (capacity: 100,000 pages 2 ) Transfer unit (capacity: 100,000 pages 2 ) Finisher ships with 5,000 staples Power cord Software and documentation.
Aug 13, 2009 | Xerox Phaser 7400/N Printer
Phaser 7400
The closest I can find to your description is a U6-0 and the suggestion is to replace the transfer belt assembly,
Feb 11, 2008 | Xerox Phaser 7400/DXF Laser Printer
Xerox phaser 7400
Remove the tray, first look for a piece of paper that has come out of the tray inside the tray area.
Make sure the rolllers are snapped into place. The easiest way to verify that is to remove another tray and compare them.
Look to see if all the switches and actuators are in place.
Make sure you hear the tray up motor running when you close the tray.
Also inspect the paper tray itself for broken items. Compare it to another tray.
Feb 03, 2008 | Xerox Phaser 7400/DXF Laser Printer
Xerox Phaser 7400/DXF Laser Printer Logo
193 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
