Question about HP OfficeJet Pro k550 Printer
Yellow Light on HP K550 indicating open panel will not turn off.
I have tried to unplugging the printer from the power for several minutes and have resecured every panel but the yellow light will not turn off. In fact, the printer makes no sound at all and of course it will not print.
  • Reed1 Feb 01, 2009
    My solution was to buy an HP K5400 printer for $75 which
    replaced the K550. It works MUCH better than the K550
    and I could even use my old ink carts and print heads.
Cartridge out of ink wont print K550. I reinserted the cartridge unplugged the power, it ran through cycles then it ran 1 paper blank then ran OK. Worked for me. Out of ink worked OK still but still shows out off ink but works mult. prints too fine. I refill my cartridges.
Posted on Feb 01, 2009
If the printer is connected to your computer - check to see if there is a blinking Red exclamation point / printer icon in the system tray. Sometimes mousing over this icon to see the tooltip is the only way to figure out what error message the printer is trying to tell you.
For us - when this happens, the printer is complaining about an "incompatible" ink cartridge - even though 99% of the time it will print from that cartridge without problems. So try removing and re-inserting all of your ink cartridges too.
Posted on Oct 07, 2008
How do I fix a television that has no audio nor picture when turned on without having to purchase another?
The only thing you can do is look for television repairers in Yellow Pages and take it in for service, or take to the shop where you purchased it.
You can try pressing the button on the Remote for 'Source', just to make sure you aren't on a black screen with no signal input?
Sep 30, 2016 | Insignia Televison & Video
Canon inkjet PIXMA ip3000 wont print and has 5 blinking yellow lights
Canceled the jobs on PC and verify the inks.If you use the refill inks perform the head cleaning in the mantenance mode.
Feb 13, 2013 | Canon PIXMA iP3000 InkJet Photo Printer
The power light is constantly blinking in yellow. before this happened the yellow light was on without blinking I turned it off, once I turned it back on the light turned green but the screen...
try unplugging your t.v for 10-20 seconds. plug it back in. if your power light continues to flash your t.v is the issue. you should be able to google your issue or check your owners manual about the problem. unplugging the t.v is the last ditch effort. Good Luck!
May 18, 2011 | Akai LCT2715 27 in. LCD Television
I have a Canon Pixma iP4000 with a baffling problem. When I turn it on, the lights flash in this pattern: 4 green, 5 yellow, 1 green, 5 yellow, the yellow light stays on for a moment, then the printer goes...
Follow these steps to reset the printer:
1. Turn the printer off with the Power button (if available).
2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
4.
Jan 27, 2011 | Canon PIXMA iP4000 InkJet Photo Printer
Yellow light flashing saying replace cartridge that is flashing when I replace it the yellow light is still flashing
Issue: Alarm / Power light flashes orange 5 times consecutively (Print Head / Cartridge Error)
Solution: Install the print head and ink tanks correctly iP4500
Reseat the Print Head and ink tanks iP4500
  4. Turn the printer back on.
Jan 17, 2011 | Canon Pixma iP4500 InkJet Printer
Flashing yellow light on power button
It sounds like the seine board. I replaced several of these. Exteded warranty would be nice in this situation. Hope you have one.
Oct 13, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Printer wont go online - light continually flashing green to yellow...
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
May 24, 2009 | Office Equipment & Supplies
Brother Printer HL 1240
OK figured out the sequence to resolve this error:
power off unit
unplug power cable for 1 minute
reset the power cable
open front door
press and hold the reset button under the lights
turn the power on
printer should then be reset
Feb 21, 2008 | Brother HL 1240 Printer
Xerox 8200 will not boot
If it takes a long time to cycle, then shuts down. I suspect the drum heaters are defective.
Best way to find that out is, turn off yout room lights, then turn the machine on.
There is a fan exaust on the right side of the printer where there are sloted openings.
When you turn the machine, look in that fan slot and see if you see lights inside the printer. There should be a candesent type of glow you see about 20 seconds to a minute after you turn on the machine. Leave it on for a couple of minutes, but if you see no lights the heater or heaters are bad. They are standard 120 volt 150 watt halogen lamps. Tricky to change. But it can be done.
Dec 28, 2007 | Xerox 8200/DP Thermal Printer
HP OfficeJet Pro k550 Printer Logo
735 people viewed this question
Ben Johnson
