Question about Sony KP-65WS510 65" Rear Projection HDTV-Ready Television
The picture is distorted. It appears as the picture is being drawn to the center of the screen.
I sent my D-Board to PTS and had it tested and rebuilt. They did find some problems with it but it didn't seem to fix the problem with the TV. The picture is distorted and appears to be drawn towards the center of the screen.
  • 2 more comments
  • dthomas802 Sep 30, 2008
    Sorry the TV is a Sony KP-65WS510 Serial #9707024
  • broken65in Oct 13, 2008
    I have same issue... Replaced both ICs 2 times, all pico fuses replaced, and HV wires replaced.... still not working correctly. Im at my wits end, but dont want to scrap an otherwise great TV. Any ideas? No new complete boards are available for my TV either.
  • dthomas802 Oct 14, 2008
    I sent the D board back to PTS. They tested it again. It tested fine so they installed it in the same set they have and could not duplicate the problem.
    I haven't done any convergence adjustments other then the flash focus. When I turned it on one day this is what I got.
  • 4,234 Answers
This is a convergence problem. This can be either bad solder connections at the convergence ICs or defective ICs. If you can solder, you can fix this yourself. Try resoldering the pins on the convergence ICs. If that fails, replace the ICs. These are large black ICs attached to a heatsink.These should be marked STKxxx.
Keep me posted.
Dan
Posted on Sep 30, 2008
  • ABRsvcs Oct 14, 2008
    Based upon the pictures, this convergence is way out. Did you attempt to do any physical adjustments on the CRTs? This unit needs a complete alignment, both mechanical and electronic.
    Dan
Lines and distortion across screen
Check and replace the smoothing capacitor used at it video output voltage This capacitor can be located at the neck board of picture tube.To get more details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Nov 29, 2013 | Philips Magnavox 20MT133S 20" TV
When I turn on the set, the right half of the screen is distorted. It flickers, different colors move from center to far right of screen, double images that appear as negitives and sometimes that half of...
Symptom shows problem with lcd panel (screen) however, t-con board that is part of lcd panel could be defective and cause of these symptoms.
T-Con board is located at top center of cld panel at rear and would be covered with metal shield. There are three type of t-con board utilized according to lcd panel and are available in shopjimmy.com
Please check what t- con board is similar with your tv board to order it. If you are not handy with electronics stuff repair then local tv repairman will help you to replace t-con board that might solve your tv picture problem.
Thanks.
Jan 29, 2011 | Samsung LN46A550 LCD TV
Hitachi model 50v71discolorization on the screen
You have a small signal board that needs reworked. Also known as the convergence board. Send off to PTS Electronics.
Sep 15, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Distored picture on top half of the screen
This is one of the sets with bad HYPER boards. If it clears up after a while this is your trouble;I just checked a site in LA--the only way to get the board is to go to PTS electronics and send them the original board for repair--part alone is over 200 and is soldered in--a lot of these sets are having this problem.
I know I am not giving you good news but I am pretty sure this is what is wrong with your set--seen dozens of them.
if you think I helped you in some way--give me a vote here I do this for free. IF YOU HAVE QUESTIONS OR NEED MORE HELP contact me by responding to this post.
SD TECH (SAN DIEGO)
Aug 29, 2009 | Toshiba 55H70 55" Rear Projection...
Picture is distorted from center on my 65
You do have a failure in the convergence circuit of your set. If you are good at soldering you can replace the IC's yourself. They are on the large circuit board on the left side of the set looking from the back, and attached to a large aluminum heat sink. If you don't feel comfortable doing that, I reccomend removing the board and sending it to PTS corp in Indiana. They are pretty reasonable repairing boards, and a lot less than buying a new one.
May 31, 2009 | Sony Grand WEGA KDP-65WS550 65" Rear...
Insignia 27" lcd tv vertical colored lines across screen.
This television, appears to have had a failure in the mainboard. This is the board that controls the video functions and sound functions. The unit should be taken or sent in to a service center for testing and servicing. The service center will have all the correct service information to determine the problem for you. You can call Insignia customer support at this telephone number 1-877-467-4289. You can also got to the customer support website at www.insignia-products.com. Go to the support section and ask them for help on how to get service for your television. I hope this information helps you with your problem.
May 14, 2009 | Insignia IS-LCDTV32 32 in. Television
Picture is distorted on my Sony Grand WEGA KDP-65WS550 65 in. Rear Projection HDTV Television
Can you paste snap of distorted picture of tv here to understand what kind of distortion is this.
Thank you.
Sep 09, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
Distorted picture
You need to re-solder the circuit board that contains the STK convergence modules. They're on the center circuit board attached to an aluminum heat sink that's about 8" long and 6" tall, about dead center in the circuit board. You may be able to recreate the problem (hour glass effect) by gently moving the heat sink (which the modules are connected to). This gives the hour glass effect on the picture and the advanced convergence screen. This is an indication that the modules pins aren't solidly connected (meaning soldered) properly. Remove the circuit board and clean the old solder off & resolder the modules pins to the circuit board reconnected the board and then retest by again pushing on the heat sink. This is a caused by a minimum effort (a.k.a. minimum cost) solder job, probably done in some 3rd world sweat shop. The "factory" job was good enough for 3-4 years but the heat (and these modules do create a lot of heat) and stress created from repeated use eventually takes it's toll, weakens the pin connections and our problem occurs. take the appropriate cautions working around the high voltage of the set & use a non-conduting piece of wood to push the heat sink when doing tests. Best of luck, hope ya fix it.
Jan 24, 2008 | Sony KP-57WS500 57" Rear Projection...
Distorted picture
The T.V. has a problem on the convergence panel Bd. Check each of the resistors near each regulator transistor. You can send the panel to P.T.S. Electronics in Indiana for repair. Call 1-800-844-7871 and they can repair it for you.
Jan 03, 2008 | RCA P60921 60" Rear Projection Television
WS-55809 - Video pinched in center, distorted, yellow/blue/red glow
This doesn't sound like a programming issue. I had a very similar problem about 6 months ago and I fixed problem. I had cold solder joint on the video power board. It was the board in the middle. The power supply was to the right. The video board had a driver with a bunch of legs. About 7 solder joint where cold or loose. I solder the board and my mitsu wide screen was fixed. Hope this helps.
Andy
Aug 22, 2006 | Mitsubishi WS-55809 55" Rear Projection...
Sony KP-65WS510 65" Rear Projection HDTV-Ready Television Logo
353 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
