Question about Baby Trend Expedition Double Jogger
Where and how much is a new front tire?
I have just bought on of these second hand and it needs a new front tire. I was just wondering where to get one and about how much $ it is Thanks
  • 3 Answers
Quickest solutions:
Bike shop or walmart
Posted on Feb 27, 2009
    Problem Solver:
  • 9 Answers
Bike shop around $5 or $10 and a small fee to install. It may just be the tube if it is flat which is a bit cheaper. Good Luck!
Posted on Oct 25, 2008
My 2002 honda shadow's front end wobbles badly when I take my hands off of the handle bars.
Hi, Anonymous and the usual suspects are:
1. Improperly loaded motorcycle. Non-standard equipment on the front end such as heavy radio receivers extra lighting equipment or luggage tends to cause unstable handling.
2. Incorrect air suspension pressure.
3. Damaged tires or improper front-rear tire combination.
4. Irregular or peaked front tire tread wear.
5. Incorrect tire pressure.
6. The shock absorber is not functioning normally.
7. Loose wheel axle nuts. Torque to recommended specifications.
8. Excessive wheel hub bearing end play.
9. Improperly vehicle alignment.
10. Steering head bearings improperly adjusted.
11. Tire and wheel unbalanced.
12. Rims and tires are out-of-round or eccentric with the hub.
13. Rims and tires are out-of-true sideways.
14. Loose spokes.
15. Shock absorber improperly adjusted.
16. Worn engine stabilizer links.
17. Damaged rear engine isolation mounts.
18. Swing arm pivot shaft improperly tightened or assembled.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Handlebars wobble when take my hands off Anyone know why motorcycles
Wobble
Honda shadow vt1100 Owners Workshop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VT1100C2 Owner Manual Page 3
Oct 24, 2013 | 2002 Honda VT 1100 C Shadow Spirit
My speedometer runs 5 miles to fast
need correct tire size......over or under sized tires will cause change in speed reading.....
Aug 17, 2012 | 1996 Jeep Grand Cherokee
I just purchased a second hand Quinny buzz 3 and I believe I need a new front tire. When I go to turn the tire bumps on the cement and prevents me from turning with ease. Where can I find a new spare tire?...
hi you can get a new wheel unit from quinny direct or eBay
the folding is something else turn the buzz over and check the groove on the middle tube to see if it is clean try an oil like wd40
if that doesn't work it may need a re gas which can done by quinny
Feb 16, 2011 | Quinny Buzz Three Wheel Stroller
I have a 1997 Ford Escort that I recently put (2) new tires on the front. After the tires the vehicle started pulling to the left very badly. I had the tires switched in the front left to right, right to...
Yes loosening the top strut/bracket is needed to adjust the alignment, the rear should be fine unless there is damage to rear suspension compontents that need replaced, however for that vehicle just the front.
Jan 26, 2011 | 1997 Ford Escort
Bought a razor pocket mod scooter second-hand-it needs a new inner tube in the rear tire. How do we get the tire off?
Use a wedge. Place the thin end between the tire and rim. Then push the tire off using the wedge and your other hand, work your way around the circumference of the tire until it is off. Use the same process to put the new tire on. But this time you will push the tire on the rim.
This is a pic of the ideal tool you should use:
Jul 08, 2010 | Electric Razor Pocket Mod Scooter
Want to buy new tyres, for gmc denali 2003, which onez??
There is a sticker inside your drivers door that lists the stock tire size. This is always the best bet. On line is a web sight from tirerack.com that has explanations of tire sizes, tread ratings and on....
Aug 04, 2009 | 2003 GMC Yukon Denali
What tires to replace first
Have the technician replacing the tires put the best 2 used tires on the rear of the cars and put the new ones on the front. You do your steering and braking with the front tires and if you were to have a blow-out, you want it to happen on the rear tires so that you can maintain maximum control with the good front tires.
Jul 24, 2009 | 1998 Ford Crown Victoria
How to change the front tire for a Yamaha Road Star Warrior
Hi, Omar_landero for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Putting new front tire and brake pads on Yamaha Wild Star Road Star
How to remove front wheel
Yamaha XV19SW Service Manual
OEM parts for Yamaha
Yamaha ROADLINER XV19SW Owner Manual
Apr 05, 2009 | 2002 Yamaha Road Star Warrior
Cant unlock songs.
You need to sing the songs on your own in front of the judges. Also if the wii hooks up to the internet you can download new songs.
Jan 02, 2009 | Konami American Idol Encore for Nintendo...
Buzzing sound
Needs new,fresh IHVT ( flyback transformer) = I have part #
if you want it........T.
Nov 19, 2007 | RCA F32450 32" TV
Baby Trend Expedition Double Jogger Logo
246 people viewed this question
Top Baby Trend Baby Gear Experts
Jennifer Rock
Jennifer Rock
Mike
Dennis Crouse
Are you a Baby Trend Baby Gear Expert? Answer questions, earn points and help others
