Question about HP LaserJet 3050 All-In-One Printer
Scanning when i scan, fax or copy a line comes up on the paper
  • 138 Answers
Open the top Auto Doc Feeder. (The area where you insert the original to copy) It lifts up when pulled up gently but firmly. You will see a strip of glass. Clean the glass strip with Windex or alcohol on a paper towel or rag. Put the cleaner on the rag, not sprayed on the machine so it doesn't get on unwanted areas. Carefully examine the glass as you have smudges of ball point pen or white-out on the glass.
It appears as a line because the paper is moving past the fixed scanner and it can scan through whatever you have on the glass.
Hope that helps you. :)
Posted on Oct 02, 2008
How do I get rid of the black line when I scan or make copy's
I had a professional to clean the scanner and copy machine. The line was gone. He had special tools to clean the machine parts.. Hope that helps.
Jul 17, 2014 | Brother MFC 8950DW
When scanning and copying get lines
clean the scan glass,it's usually a .5 to1 inch strip of glass that the paper runs over while it is scanned and it probably has white out or something similar on it
Nov 06, 2013 | Canon Pixma Mg6120 Wireless Inkjet Photo...
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
Straight thin line prints on copies from feeder
When the paper is fed through Automatic Document Feeder (ADF) it is scanned before copy or fax. The scanner is fixed type and is located just below the ADF.
The lines are due to dirty scanner mirror. The printer/ scanner design is based Sheet-Fed Scanner. Open/Lift the Control Panel (scanner top )(by pulling it up from front - the area from where the paper to scan comes out). Look out for the horizontal mirror and use a soft, damp, lint-free cloth to gently clean the scanner mirror, rollers etc. and enjoy clear scanning and copying! For example see the below picture: -
Inspect for any tron pieces of paper dirt etc.DONT USE PAPER, CHEMICALS OR ANY ABRASIVE CLOTH as it may damage the parts.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Oct 18, 2011 | HP OfficeJet J4580 All-In-One InkJet...
Black line 1 inch wide right side ,when copies are made and faxing
When the paper is fed through Automatic Document Feeder (ADF) is is scanned before copy or fax. The scanner is fixed type and is located just below the ADF.
Also note that your machine can scan an image only 8.15 inches wide, regardless of how wide the paper is.
CreativeTECH
May 31, 2011 | Brother 5750E Fax
Unwanted verticle line on fax copies
Most likely a fax has been sent or a page copied with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, scanning or sending a fax, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page. If this is the cause you will also find that faxes you send to other people will also have this line (although faxes you receive are not affected by this problem with your machine).
To fix the problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Feb 22, 2010 | Brother IntelliFAX 560 Plain Paper Fax
When you send a fax, the other person only gets lines on there copy, not the paper that i faxed
Make a copy with your fax machine. If your scanner is bad you should have a similar problem making copies. The same scanner is used to make a copy as is used to scan and send a fax. If the copy comes out bad your scanner is either dirty or bad. If you can see your copy but it just has a few lines running vertically up and down the page then you need to clean the scanner glass. This is a small strip of glass in the port where you feed it your originals.
Good Luck
Jan 25, 2010 | Panasonic KX-FP151 Plain Paper Thermal...
Black vertical lines on the sent copies when faxed on Sharp UX 510
Lift the document feeder cover, and clean the scanner glass.
Please rate solution
Mar 31, 2009 | Sharp UX 510 Plain Paper Thermal transfer...
FAXING SAYS CANT SCAN TROUBLESHOOT ROUTING , DONT HAVE A BOOK
usually something on scan glass..ord lamp is bad..try coping blank paper..if line shows up...check glass clean and try again..
Dec 26, 2008 | Brother DCP 7010 Multifunction Laser...
HP LaserJet 3050 All-In-One Printer Logo
117 people viewed this question
Seeker5211
Seeker5211
