Question about Olympus Cameras
E410 Appearance of fine horizontal and vertical mesh in uniform ly toned areas particularly mist scenes - although also in darker areas as well
    Sergeant:
    Champion:
  • Olympus Expert
  • 479 Answers
Try to reset the camera back to default using the menu
Posted on Oct 01, 2008
What is the difference between horizontal and vertical bamboo flooring?
Horizontal strips are glued together horizontally and show the bamboo's nodes in the flooring. Vertical strips are stacked vertically and glued together, giving the floor a more uniform appearance without any nodes.
Feb 06, 2013 | Building Materials
My ne u22v is not making mist
You should check if the battery is working fine. I don;t think Omron U2 nebulizer can have any other problem as it works really good for me. Also it is important to clean the Nebulizer properly and please check out the manual for more info. which you would have received while purchasing the Nebulizer.
Aug 06, 2012 | Omron Ne U22V Microair Vibrating Mesh...
Television is a Tosiba DLP 72HM195
your tv needs a y-load board its like a grafix card as computers have due to overheating the board components are affected this is a manufacturing fault it tends to happen with samsung aswell
Feb 22, 2012 | Toshiba 72HM195 72" HDTV
I have the same problem with a Toshiba RGZA 46RV535U purchased 2/2009. My picture gets darker in the center 1/3rd of the screen intermittently. I have removed and reconnected all cable connections on the...
The tubes are horizontal but require disassembling the cover and the inverter
board completelyfrom the chassis. There were 17 of these flourescent tubes stretching the ful length horizontally. They are so fragile.
Jan 01, 2011 | Toshiba Regza 46RV535U 46 in. LCD HDTV
I just installed the right head light on a 2000 f250. I'm trying to find the specifications on distance and height of the light beams, L &R when adjusting the lights.
Headlamp Adjustment —Screen Method Aiming NOTE: Horizontal aim is not necessary for this vehicle and is not adjustable.
NOTE: Consult your state's vehicle inspection manual for recommended tolerance ranges for visual aiming.
  1. NOTE: The sight shield may need to be positioned or removed for access to the adjusters.
    Before starting headlamp assembly adjustment:
    • Check the tire inflation.
    • Check that no other load is in the vehicle other than a half tank of gas.
    • Check that the headlamps are clean.
    • Check for correct headlamp operation.
    • Check that the vehicle is on level ground.
    • If the vehicle is equipped with air suspension, make sure the switch is on.
    • NOTE: The vertical wall or screen must be a minimum of 2.4 meters (8 feet) wide.
  2. Park the vehicle on a level surface approximately 7.6 meters (25 feet) from the vertical wall or screen directly in front of it.
    NOTE: The center of the lamp is marked by a 3 mm (0.12 in) circle on the headlamp lens.
    Mark a horizontal reference line on the vertical wall or screen.
    1. Measure the center of the headlamp height to ground and record.
    1. Make a 2.4 meters (8 feet) horizontal mark (masking tape) on the vertical wall or screen at the same distance from the ground as previously recorded.
  1. NOTE: This procedure should be done in a dark environment to effectively see the headlamp beam pattern.
    Turn on the low beam headlamps to illuminate the wall or screen and open the hood.
  1. NOTE: The appearance of the beam pattern may vary between vehicles.
    On the wall or screen, locate the high intensity area of the beam pattern.
7ced4e6.gif NOTE: The appearance of the beam pattern may vary between vehicles.
Identify at the top edge of this high intensity area a distinct horizontal cutoff in the beam pattern. If the top edge of this cutoff is not even with the horizontal reference line, the headlamp beam will need to be adjusted.
Apr 06, 2010 | 2000 Ford F250 Super Duty Crew Cabs
Top 2'' has tiny horizontal lines
Your symptom sounds like a faulty capacitor in the vertical deflection circuit.
What you are seeing is called vertical fold-over.
If you want to fix this yourself and are handy with a soldering iron, it is not that difficult. Just look for a 1uf capacitor near the vertical IC. The vertical IC will be a black IC with straight legs mounted to a heat sink, generally in the center of the circuit board.
Note: Be careful when working on a television as the CRT and other capacitors can hold a charge that can be very dangerous.
I would recommend that you contact a local service center and see if you can get a quote for the repair. I would normally charge between $120.00-130.00 for this type of repair. The cost may vary depending on where you are located.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Aug 02, 2009 | Toshiba Televison & Video
Monitor appearance is short and fat
set the resolution to its native resolution 1440 x 900 this should correct things.
Oct 07, 2008 | Gateway FPD1975W 19" LCD Monitor
Why do two pictures of the same scene, taken at about the same time have different exposures?
Your camera light meter uses the concept of multi-spot exposure metering, which is sensitive to subtle differences in scene composition. To determine the overall shutter speed for a scene, the meter takes readings from three zones within the frame. With Portrait orientations, the zones remain in the same place (vertical) on the CCD imager. With landscape orientations, however, the zones are more spread out (horizontal) and the dominant (2 dark and 1 light or 2 light and 1 dark) zones determine the shutter speed. This may cause some areas of the picture to be overexposed or underexposed.
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
Cameras Logo
57 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
