Question about Akai LCT2785TA 27 in. LCD Television
Resistor Values In regards to those parts, they have been removed off the power board.... they are not burned, they just don't exist. Looks like the solder was loose around them and a couple were simply nipped with wire cutters. Any suggestions, if you have the same TV I can send you a picture or give the # of power supply board, if that helps. Thanks
  • Jones1234 Oct 04, 2008
    I know there are a lot of people who have this board MLT168A..... would somebody be kind and tell me what the colors are on resistors R107, R106 and R104. Also the nubers on C17 ....
    Please, somebody....e-mail is
    Thank you in advance.
    Problem Solver:
  • 8 Answers
Bottom to top color bands = red, black, brown, gold
Posted on Dec 31, 2008
Jvc subwoofer will not power up
you can get the value from this link..
Nov 01, 2008 | JBL LC-S960 Car Speaker
Will not power on
This symptom caused by shorted (HOT) Horizontal Output Transistor,change this transistor,so it will power on again..
hope this may help;
Jul 30, 2008 | Zenith B13A02D 13" TV
Motor Joy
Hey boss. Just follow this guide and replace with a resistor that matches the value and tolerance. You have a 5 Band resistor, follow the guild and you should be good. Click here for a chart to help you identify the values.
Jul 06, 2013 | Car Audio & Video
Radio Shack Multimeter, 22-168a, shunt resistor value????
Go to the Radio Shack site and you may with the model number find a schematic or you can email/contact them for the value of the resistor.
I predict it is a precision value and type you will have to get from them if available.
PS: you posted in wrong catagory as this is TV section.
Mar 12, 2012 | Televison & Video
Hi I want to save our Daewoo DWF 450 full automatic washing machine. It was broken. I opened,removed and checked the control board then a I found out one of the parts or maybe 3 parts were burned. The...
hello, this is a guess but it sound like resistors or diodes you would need a circuit diagram to tell you the value of the resistor and diodes it would be better to buy a new control board hope it helps
Mar 13, 2011 | Washing Machines
I have two Panasonic PT-LB10VU projectors doing the same thing. They project find with RGB, but when trying to project a VHS tape through video, the image rolls or has multiple lines running through it. ...
first of all you replace the present video driver VHS tape and try any other dvd driver or any other video device if problem exist then the main board of you projector is faulty.
Solution: open the upper over remove 5 screw back side of projector.
disconnect the panel ribbon cable.Remove lamp cover with 3 screw remove main board with 4 screw and 8 connector. put it face down on a table and use a table lamp for more light.
check very carefully the area I show in the picture with red arrow there is a resistor no.R041(on resistor 750) is burn out or black replace witch 75ohm resistor and check around the resistor if burn any other component replace with the same after repair of main board fix the all part of projector as you open. Power on and use any video device other than your VHS tape maybe the high voltage comes on video output.
Dec 20, 2010 | Panasonic PT-LB10VU Multimedia Projector
Power supply board component out
Hi goikem
I would replace the capacitor first and check the resistor with an ohms meter to see if it has changed in value(gone high). remounting the resistor (you may have to replace it also to do this with longer leads) to be clear the Pcb and also the capacitor to be as far away from the resistor as a heat source also may help. Darkening of the board is not uncommon where there are power components. Having said that, it should not generally happen in the first place... but it often does. Power supply failures in modern gear relates to heat stress so often. Capacitors failing from this overheating is the biggest problem of all. In the workshop, where we suspect that caps have failed, we generally replace them all, and always use good brand name 105deg rated devices(Rubycon or Nichicon brands i prefer) to help minimise the recurrence of failure. You can order them from Farnell in most countries of the world. If you cannot identify the values of the components, I am happy to try and help you here. Please feel free to ask any questions you may have. FixYa rating is the best way to thank me for helping you out. Cheers
Oct 17, 2008 | Audio Players & Recorders
P4004 - Blown Components
if burned components are on output stage or amplifier section on board..Then look at the oposite side of amp..Both amplifier section should be a mirror image oof componentc from other..that way you can know the values of parts.If they are on power supply section ..Then you might need manual if available..
Dec 23, 2007 | Rockford Fosgate Punch P4004 Car Audio...
Akai LCT2785TA 27 in. LCD Television Logo
165 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
