Question about Acer Aspire L100 PC Desktop
Internal expansion socket
When viewing from the front - on the mother boards left hand side there is an expansion socket. What is this for?
That is a mini-PCI slot.
Posted on Mar 26, 2009
Want to upgrade mother board on a6700f. any suggestions?
Here are the specs for the motherboard for the HP Pavilion a6700f -
  • Manufacturer: ECS
  • Form factor: microATX - 24.4 cm (9.6 inches) x 24.4 cm (9.6 inches)
  • Chipset: NVIDIA GeForce 6150SE nForce 430
  • Memory sockets: 4 x DDR2
  • Front side bus speeds: 2000MT/s (2.0 GT/s)
  • Processor socket: AM2+
  • Expansion Slots:
    • 1 PCI Express x16 slot for graphics card
    • 2 PCI Express x1 slots
  • 1 PCI slot
If you can find something similar you should be ok.
I can assist if you need someone to "review" any replacements you might be considering.
Aug 17, 2013 | HP Pavilion a6700f PC Desktop
Tip
How to change an Am2 socket to a 939
<p>1. Connect the computer operating system and save up to five minutes waiting for the AM2. Unplug the power cord plugged into the computer and the cables for each of the other components of the computer case. <br /> <p><br /> <p>2. Put the computer case on its side on a flat surface. Unlocking the computer side panel by removing the case screws on the back wall. So remove the lid of the box that the motherboard is visible. <br /> <p><br /> <p>3. In the Annex, the power of large space in the upper left corner of the computer. Unplug the power from the motherboard. Find the positions of the rectangular, green RAM module on the right side of the fan on the motherboard. <br /> <p><br /> <p>4. Slide the plastic lock down on both sides of the RAM module and remove the module from the motherboard. Repeat the process if necessary, if the computer two or more RAM modules. Find the card with the lower left corner of the motherboard. <br /> <p><br /> <p>5. Remove the screw holding the end of the metal rod of the expansion card on the back of the computer. Pull the card and remove them from your computer. Repeat the process if you have two or more expansion cards on the motherboard. <br /> <p><br /> <p>6. Disconnect the cable from the plastic fan on the motherboard. Slide the side guides of the fan and remove fan and heatsink metal AM2. <br /> <p><br /> <p>7. Pull the handle to the right of the issued AM2 processor. Pull the CPU and the motherboard removed. Remove the screws in the corners of the plate and slide the motherboard, right. <br /> <p><br /> <p>8. Lift the motherboard of the computer case. Place the socket 939 motherboard inside the chassis and drive expansion ports and power with the holes on the back of the case. Press the board to stick to the left and the screws on the motherboard in place to replace. <br /> <p><br /> <p>9. Set the Socket 939 processor socket on the motherboard and reconnect all processor pins on the base contact. Slide the locking arm and spread a layer of thermal cooling of the processor with the applicator stick. <br /> <p><br /> <p>10. Connect the power cord and insert the RAM modules and expansion cards for the new motherboard. Put the lid side of the computer and reconnect all cables. <br />
on Jun 22, 2011 | Computers & Internet
How can i attach more usb hubs inmy mother board?
You can install an internal USB hub like in this picture >>>>>leecom72_8.jpg
They go in one of the expansion slot on the front of the computer and usually are powered by one of the white molex plugs that connect to the hard drives and optical drives.
Alternatively, you can get a wired USBhub like in this picture >>>>
Reagrds.
Jun 02, 2011 | Computers & Internet
I don't know what motherboard it is that i have to download the users manual can you please.....please help me
Turn off the PC. Remove the side panel from the case. Get a flashlight and inspect the mother board. You're looking for a number to identify the type of mother board. ASUS mother boards usually place this number just to the left of the memory slots. It's usually 5 or 6 digit long and made up of both letters and numbers. One of my computers with a ASUS mother board is a P5LD2. Once you know this number you can go to http://support.asus.com/ and download updated drivers for *********** board. You may need to identify what type of socket *********** has. If you have a fairly recent Intel microprocessor you probably have a socket 775 mother board. If it's an AMD microprocessor it's probably a SocketAM2 or AM3. You might have to do some searching if these choices don't work. I hope this advice helps you out.
Jan 28, 2011 | ASUS Computers & Internet
From where can i download free mother board / Sound / VGA / LAN drivers of D 915 GAG
Drivers for Intel Motherboard 915GAG can be downloaded from Intel Official Site
Select Operating System and 'Type of download' - Drivers
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Dec 24, 2010 | Intel Computers & Internet
How fix waire from mother board to graphics card
if it is an internal graphis gard it will be installed on the motherboard in the expansion slots( slots like RAM slot ,but horizontal)
Sep 28, 2010 | Computers & Internet
Expansion slota
eMachines Support > ET1331 desktop computer > Product Views > Rear View,
http://support.gateway.com/emachines/desktop/2009/emachines/et/ET1831/ET1831rv.shtml
The metal covers that have the Plus sign ( + ) holes, are Expansion Slot Covers.
Insert a flat tipped screwdriver blade in the + sign hole.
Insert the screwdriver blade horizontally, in the + sign hole, on the right side. ( ---- , not vertical I )
Gently bring the back of the screwdriver down.
This will make the metal slot cover, bend the small metal tab that is holding it.
Go to the + sign hole on the Left side. Do the same on the Left side as the above.
Bring the back of the screwdriver up.
Keep working the metal expansion slot cover back, and forth, until the two small metal tabs that are holding it in, break.
Remove the metal expansion slot cover.
Before you begin, ensure that the expansion slot cover you wish to remove, lines up with the wireless adapter card.
Have any questions concerning this, post in a Comment.
Jun 25, 2010 | E-Machines eMachines Refurbished EMA...
Will an Intel E7400 processor work with an MSI P965 Neo F V2?
Your processor "Intel E7400" is listed as a socket 775 Intell core 2 duo processor. Your motherboard "MSI P965 Neo F V2" is listed as an Intell board using a socket 775 processor socket. The front side buss (or fsb) speed capabilities of the mother board, and the buss speed of the processor are compatible They should play nice with each other.
Good Luck!
Jul 27, 2009 | Intel Computers & Internet
Motherboard
Are you trying to install the Dell Media Card Reader? If so then the other end of the ?FlexBay USB cable that plugs into the card reader goes into a small rectangular connector towards the back of the motherboard. Specifically orient as follows; place the computer on its side, the power supply to your left and the front of the computer facing towards you. Starting at the back of the motherboard next to the power supply follow the back edge of the motherboard till you come to the approximate center of the board. About an inch towards you there will be a rectangular connector the FlexBay USB cable end should fit into. If this isn?t the cable from the Dell Media Card Reader let us know and we?ll try to help, otherwise please don?t forget to rate this posting.
Feb 11, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
Acer Aspire L100 PC Desktop Logo
71 people viewed this question
Brian Sullivan
Brian Sullivan
