Question about Dishwashers
Neff Dishwasher Hi, I read your solution to the dreaded '1 minute' light - exactly the same happening on my S5457. To help me out a bit, which side of the dishwasher did you have to remove? Regards Al
The offending parts are on the left hand side of the machine (viewed from the front). You need to remove a screw (or two?) at the back top edge of the side panel which will then lift upwards and come off.
Before I did my fixit I phoned Neff service (actually BSH appliance care) who quoted me £60.50 for the first half hour then £45/hour plus parts or £159 for 12 months parts and labour. A bit of a no brainer! Anyway, I provisionally booked a service call but said I would call back to confirm.
2 days later I still had the machine pulled out and the panel off because I was testing it. Phone rings - service engineer to say he's on his way. Thought he may as well look at it anyway. He said I'd done exactly what he would have done except he'd have used new part instead of cleaning out the original. He even cancelled the call off his system so no call out charge!! He also told me that 1 minute on the timer display is actually an error code not the actual time left.
Be warned - after the fix I ran the machine on a rinse cycle - completed ok. Put it on an auto wash cycle and it stuck with 1 minute to go! Much swearing and cursing!!
However all subsequent washes have been fine and it has now been working properly for several weeks.
I took some photos whilst I was doing the repair - I can email them to you if you want.
Hope the above makes sense - good luck.
Posted on Oct 01, 2008
Hi. My neff dishwasher has an illuminated tap sign and is making a humming noise but nothing is happening?
is tap to the dishwasher turned on
if it is
the water inlet solenoid needs to be replaced
Jan 22, 2017 | Neff Dishwashers
Dishwasher door will not close properly
usually d/w doors are fine for long time.
1. check if anything blocks it to close securely e.g. the cutlery basket or the dish racks not fully sliding in or may be off track/chanel.
2. try running a cycle empty and see if it closes after doing #1.
Jul 25, 2013 | Neff S51M53X0 24 in. Built-in Dishwasher
I have a s5443 neff dishwasher no lights coming on and nothing happening. fuses ok in scockets
could be your mains surpressor or main board on the appliance. check for continuity from the plug to the board if you have it then it is not the surpressor it will be the board. if it is the board you need to find what part has caused the board to blow
hope this helps
Nov 11, 2011 | Neff 24 in. S5443X2 Built-in Dishwasher
I have a Neff S54M45XOGB dishwasher and it has stopped working. It stopped 1/2 way through a programme. There was also a buzzing noise comming from around about the on/off button. I have tried to restart...
Thanks for using FixYa. This issue can be either due to a faulty door latch or door lock switch which is not engaging itself. And, if the door latch will not engage the dishwasher will sense it as open door and will not start the cycle. The light also blinks when the dishwasher detects a no-fill condition. You’ll need to get access to the fill valve by removing left panel, look at back to see where valve is when you get to it remove one of the wires and set meter to ohms setting and put a lead on each tag on valve. The reading you should be about 3.6k ohm if you don’t get a reading then the valve is at fault. I'll also suggest you to check the detergent dispenser solenoid for this issue. Please do accept the solution if the issue is resolved or else post a comment for further assistance.
Jul 11, 2010 | Neff Dishwashers
Our Neff S5454x1/21 dishwasher has occasionally stopped/stuck
Looks like the heater unit has packed up.
I cannot seem to find the actual model you have anywhere on the internet. But I am assuming you connect the dishwasher to cold water inlet and it is meant to have a heater.
Are you in UK or Europe. Bosch also makes parts for the NEFF dishwasher but I am not able to find spare parts for your exact model.
Please post a comment.
Jun 05, 2010 | Neff 24 in. S5453X1 Built-in Dishwasher
Hello. Have a Neff S5457 that is not working properly. It sounds as though it's working but on getting the crockery out, it is obsvious that it isn't. Have checked all the filters in the machine that are...
clean the nosels of the arm's, check if the tetergent is pumped (if you have an automatic detergent dispenser) check whit dishwasher unpluget!!! you can check and the pump but be carreful how you put it back. also you can check and the hoses to be clean.
Feb 21, 2010 | Neff 24 in. S5457X0GB Built-in Dishwasher
Neff dishwasher continually draining
Update to my problems. It is now working. I removed the T20 tork screw housing the pump cover which is situated underneath the filter. I used a sponge and siringe to remove all water. And started the dishwasher a few times to spin the pump and flickout any excess water. I noticed some small bits of food which were removed and I cleaned all filters and put it back together. It didnt work staright away but the pump was not comong on as soon as the door was shut anymore. I did a reset and then selected a rinse programme and voila it worked! Tried a full wash cycle last night and it all seemed to be working fine......
Feb 25, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Hi there.
Check salt and rinse-aid levels first. Often there is an indicator if either of these falls below a level.
When was the last time you filled them?
Top up rinse aid to mark, and add at least 1kg of salt.
Run M/c on a quick cycle and see if it's back to normal.
Hope this helps you.
Jun 14, 2008 | Dishwashers
Neff dishwasher water filling
there is a safety float in there to shut the water off most look like domes under the float is a safety switch take off the bottom kick and see if the float is on the switch if it is check to make sure the switch is good
Feb 18, 2008 | Neff 24 in. S5543X2 Built-in Dishwasher
Neff slimline dishwasher type S5946
hi there sounds like your wash pump has burnt out
Jan 11, 2008 | Neff 18 in. S5943 Slim-Line Built-in...
Dishwashers Logo
146 people viewed this question
Top Dishwashers Experts
