Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Icemaker lever fell out
How do I re-install it?
I fixed the problem in two minutes with the help of a mirror. I removed the sliding basket that contains the ice collector and was able to re-install the lever into the slot at the correct angle by observing the slot with the mirror.
Posted on Oct 01, 2008
I was able to re-install the lever with the help of a mirror after I removed the sliding basket that contained the ice collector.. The mirror enabled me to see the configuration of the slotted hole where the near end of the lever had to be inserted. The job took about 2 minutes.
My lg refrigerator lsxs26326 is dispensing water but not filling ice tray up. What could be wrong?
the water solenoid valve for the water dispenser is separate from the icemaker water supply solenoid valve . get to the icemaker water supply solenoid and test it if it works alright . unplug the fridge from wall outlet do not close water supply valve. disconnect water tube connection on the water discharge side of the icemaker water supply solenoid valve . pull - out power supply connection of the solenoid coil . connect solenoid valve directly to wall outlet. a faint click should be audible and water should come out from where the tube was removed -- from the water supply discharge side. if no water is coming out with the solenoid plug in , then the solenoid is faulty. but if water comes while solenoid is powered -on , check the position of the icemaker lever. if it is on off position icemaker timer won't activate icemaker water supply valve..move icemaker lever to on and check for water pouring into the icemaker tray' if no water comes out . change the icemaker timer. thanks.
Mar 04, 2016 | LG Refrigerators
A pin fell onto my foot from the steering colum while I was driving my Ford 150 truck, 4.6 liter. I can't figure where it goes, the shifter is now slopy and closer and even touches the dash when putting it...
looks like the shift lever pivot pin. Your description indicates that you are currently using the shift lever slot (the hole which the shift lever passes through) to actuate your gear selection. The fact it fell out, suggests it was originally installed upside down (wide end towards floor). May have to remove the cowling from around the steering column to find the proper location for the pin.
Jan 27, 2015 | Ford Cars & Trucks
Ice maker shutoff bar fell off
This arm is called a "bale". There should be a small, round opening on the backside of the front of the ice maker. Use a mirror to look behind the square control box of the icemaker and you should see the opening. It is impossible to see it from the front when the icemaker is installed in the unit.
Oct 10, 2014 | Kenmore Refrigerators
Water flows into ice maker when water lever is pushed
Be sure that you have the water inlet valve wired correctly.
Nov 26, 2012 | Refrigerators
Obd p1537 p1538
P01537 intake manifold control runner one code for left one and one for the right one, if your are in front of the engine the front top area there is the intake control levers for left and right. guess what it fell out, both left and right levers.then the code, its held by a circlip. this is a very popular for code. find the lever for the right one and install it find the left lever and install it.
Apr 27, 2011 | Ford Windstar Cars & Trucks
Is there a shut off valve on the ice maker?
There should be a shut off valve at the beginning of the water line that the installer tapped into when installing your icemaker. Mine runs down through my kitchen floor into my laundry room and is tapped into a copper cold waterline with a small handle attached to it.
To stop icemaker from making ice simply raise the lever to the up position that is attached and hangs next to your icemaker tray. This works on most models.
Aug 24, 2010 | Kenmore 53642 / 53644 Side by Side...
Icemaker stops. lever to shut off icemaker frozen in place. used hair dryer to melt frozen gears and loosen lever, but water gets into gear housing again and freezes lever again
These icemakers are not repairiable.
The icemaker will need to be replaced with LG part#
AEQ36756901
This is an updated icemaker to correct the problems of past units.
Jan 17, 2010 | LG LFX25960 Bottom Freezer French Door...
Icemaker doesn't work
Icemaker seems to be working now.
I think that moving lever and switching on/of helped. I see and hear that it is producing ice now.
Jan 10, 2010 | GE PSS26SGRSS Stainless Steel Side by Side...
Icemaker lever
unplug the ice maker,remove the 3 screws that hold it to the wall,you will see 2 holes one on each end top inside icemaker ,and the lever just kind of slipes into place,put one end in at a time,test it make sure it clicks when you pull up on it and down on it,reinstall ,let me know how you do-mike
Sep 30, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kitchen Aid indoor ice maker
hi there,
i would recommend a technician to help you with this. this part that fell out is from the motor head off the icemaker. have the technician put it back together and make sure that there is nothing else loose.
Jun 14, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
57 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
