Pcb/board We have replaced a bulb 265866 type OSR B on Thomson rear projection and now we need the bulb/lamp drive board/pcb. I don't know where I can find one. Numbers on the board/pcb are:ZNN1881530 38169102DG 75l3609001B 071422 P0446 2AD12 OFFO (B) 01302CBA Any clues who would stock this as I have been trying to contact Thomson but the phone is not connecting. Thank you and regards, Anj Jai Electronics
  • gaggo May 11, 2010
    I haven't solved the problem I had but I know what I need and I am just looking for that part and I am just trying to locate that part.
    Thanks for your concern
    Anj
    Jai Electronics
You really need PT VIP 2AC/380 01 PART FROM OSRAM
Posted on Mar 09, 2011
NS Rear Fog light not working Please Help. Done a few tests and can't find cause. Renault Megane 2003 1.9 dti 5 door hatch dymonique
You car uses a single filament Osram 7506, P21W lamp as Original Equipment. Replace the lamp. You may have a bad socket.
May 13, 2015 | Cars & Trucks
Thomson 50DSZ644. Just replaced the Lamp great picture but burned smell.. after few house it smelled verry bad..and i turned off. now when i turn on the tv the picture in middle is dark and still thi
should have unplugged it when you noticed the smell.
UNPLUG and remove and look at lamp you installed--is something in the housing where lamp goes melted? I hope you did not touch the face of the bulb with your hand or fingers.
What ever is wrong find it before trying to use set again.
Dec 22, 2012 | Thomson 50DSZ644 50" DLP Rear Projection...
Burned out lamp RCA DLP TV Mod # HD50LPW165YX4 lamp type B
you can get the replacement lamp cartridge from the following link which also has installation instructions. Your model uses the 265866 lamp assembly.
http://www.tvrepairworld.com/rca_dlp_lamps
Aug 04, 2012 | RCA Televison & Video
Hi, I'm looking for supplier> 1 projection lamp
50DSZ644 is an LCD Flat Panel TV, there is no replacement lamp. Here is a link to RCA TV Lamps and associated model numbers.
easyab@hotmail.com
Feb 10, 2011 | Thomson 50DSZ644 50" DLP Rear Projection...
I have a rca hd50lpw62a and its slow to turn on and dim when on.
If your tv is around 2-4 yrs or used 6000-8000 hrs,never replaced the lamp before it could be time to replace it.If you hear strange noises like buzzing or humming noises it could be the color wheel which is a little disc that has a gamma of colors and spins at high rpms.When the light of the lamp goes through it creates the colors on your tv.The other most common failure is the board that powers the lamp,which is called the ballast.When its bad it will make a clicking sound or like wanting to turn on.Your part # for the lamp is 265866 and you can find it here: http://www.discount-merchant.com/RCA-265866-265919-269343-271326-270414-Lamp-p/rca-lamp-265866-26591-269343-r.htm Good luck and blessing for your house!
Feb 10, 2010 | Televison & Video
Rca model m61wh74syx1 is turning on with no pitcure and blinking 5 times then trying to restart
Hi,If your tv is around 1-2 yrs and haven't replaced the lamp it might be time to replace it.But if you hear clicking or continually trying to restart it could be your ballast ,which is the board that powers the lamp.The lamp you will need is the 270414 Found the lam pyou need here: http://www.discount-merchant.com/RCA-HD50LPW164-Original-OEM-Lamp-P-N-265866-p/rca-hd50lpw164-265866.htm?Click=48173 Good luck and God bless you!
Jan 05, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
Replacement Lamps/Bulbs for Philips 50P8341 Rear Projection TV
These are both CRT type TV's(3 picture tubes drive the image) with different screen sizes and the CRT's are not interchangeable
Oct 24, 2009 | Philips 50P8341 50" Rear Projection...
Replacement lamp for rear projection tv
go to mcm electronics.
good luck
please mark the post with a fixya
Feb 19, 2008 | Televison & Video
Sony sxrd bulb doesnt last 9blinks
IF SET HAS ERROR 9 THEN THE S1 and S2 board ARE PROBABLY THE REASON. DID YOU USE ORIGINAL SONY LAMPS ? GENERIC LAMPS (ESPECIALLY IN SONY) DON'T LAST. AND IS THE SET IN A CABINET ? I HAVE ALSO SEEN PROBLEMS WITH THE FANS GETTING DUSTY AND THE VENTS ON THE SIDE OF THE SET FILLED WITH DUST.
DON..
Jan 29, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
WD-62327 Lamp
OSRAM VS. PHILLIPS
This is about buying replacement bulbs for the WD62327 TVs.I dont know about the other models but I purchased a PHILLIPS replacement bulb and it worked for about a week and then those dumb flashing lights and no TV. I did some research and others were saying that you had to replace some condensers. Shop would do it for 600 dollars..Well i sent the bulb back and bought an OSRAM replaement bulb. The TV is now working perfect.
Sep 17, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Televison & Video Logo
129 people viewed this question
Top Televison & Video Experts
