Question about Kenmore 24422 Top Load Washer
Series 70 Top Loading
Washer drains, but does not spin.
  • 5,911 Answers
The symptoms you describe are typical of a broken motor coupling. The coupling is located between the drive motor and gearcase (transmission). The following link explains how to replace one:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The part number, along with where you can order one are also provided in the link. It is common for motor couplings to wear out and they aren't very expensive (less than $20). The coupler or bushing usually wears out and breaks, or the center hole of the coupler rounds out and begins to slip on the motor and gearcase shafts. The part number I provided is for a new improved coupler that is more durable than the original. If you do not wish to order online, take the part number provided and go to your nearest appliance parts retailer. This is a common part that they will carry. I hope you find this information helpful. If I'm wrong with my assessment, or if you require additional assistance, please let me know.
Posted on Oct 01, 2008
Kenmore Series 70 Top Loading Washing Machine Model # 110.20722991 Serial# CL 1134809 Hello, Our washing machine is leaving our clothes soaking wet when finished. What could the problem be?
2 things are possible. Can you tell if the spin cycle is engaging? If the spin cycle is not engaging properly or very fast, then the water will not leave the clothes. less likely is that the machine is not draining the water away properly or fast enough.
Jun 09, 2016 | Kenmore Washing Machines
Kenmore Series 70 Washing Machine - won't drain water
WHAT IS WRONG WITH YOUR WASHING MACHINE?
small_11_21.jpg For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Hope this may help;
DON'T FORGET TO RATE:
Aug 10, 2008 | Washing Machines
Spin cycle does not drain water. The washer just stops when it gets to the spin cycle. The washer is a 70 series heavy duty.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 30, 2010 | Kenmore 24032\24036 Top Load Washer
I have a top loading kenmore 70 series washer. It
The drain line is probably clogged. Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. In this case it may then get into the drain hose that's attached to the pump.Remove the hoses from the pump and pull the item out. In case it clean there, check the outer tub port- open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then,try to remove the clothing through the port.
Sep 13, 2009 | Bosch Axxis WFL 2060 Front Load Washer
My Kenmore series 70, top loading, washer has a mold smell.
thaty have this one stuff called affresh its used for frontloaders but you can use it for toploaders too it works great
Mar 24, 2009 | Kenmore 22422 Top Load Washer
Why My Kenmore 70 Series Washer Won't Drain Or Spin?
You need to replace the lid switch. This is located under the case. you have to take the case off to change this part. This is done by taking the 2 screws out of the front of the control panel. Then flip the panel back and remove the 2 brass clips that hold on the case. Then you can remove the whole washer case to get acces to the lid switch. This is a very common problem and an easy problem to fix.
Feb 13, 2009 | Kenmore 24932 Top Load Washer
Kenmore top loading washer 70 series
Hi I have a kenmore that is moving when it spins....some water left when spin is completed. We recently moved the machine to clearn behind it and this issue started. movement is about an inch per cycle.....can you help? thankse ,pde 22422
Dec 10, 2007 | Kenmore 22422 Top Load Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Kenmore 24422 Top Load Washer Logo
59 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
