Question about Canon CanoScan LiDE 600F Flatbed Scanner
No option to scan Film Negatives
Just yesterday I purchased this handy little scanner with the intent of sharing and organizing a shoeboxfull of 35mm film slides. However, when I "select source" there is not an option to Scan Negatives.
In an effort to solve this, I reinstalled the CD-ROM that came with it, downloaded the latest drivers from the Canon website, tried to un-plug and replug the film scanner attatchment, before and after attatching the scanner to my PC. Nothing seems to work.
Running XP on a system that exceeds all the required stats.
  • 1 more comment
  • sluggosalina Oct 01, 2008
    Old Marine,
    Thanks for the help. After your suggestion I started to play around with all the cords. Turns out, I had been plugging the FAU in upside down (I can hear the eye-rolling from here, lol) In my defense, the FAU plugs in very easily upside down, but to plug it in 'correctly', I had to really play with the angles and push up and in. A little bit of a design flaw IMHO.
    A little heads up for anone that has this problem in the future: if the scanner flatbed light turns on when you plug in the FAU, you've got it in upside down :)
  • Kurt_Y Oct 22, 2008
    I'm facing the same problem here as well, after followed all the instrctions in the manual, i still couldn't find the device without the name "WIA" from the "select source" menu, therefore I got no way to get in the "advance film scanning mode". But the scanner surely works well expect the film scanning part. Running on Vista Home and all drivers were installed correctly(after heaps of times of re-installing), any gurus could fix this for me? Thx.
  • shaleenford Nov 20, 2008
    I can't get the fau cord to plug in correctly. It never gives me an option to scan a negative.
  • 2,237 Answers
In order to see these options, you must have the Film Adapter Unit (FAU) attached to the scanner. The FAU is designed to scan in 35mm film, either positive or negative. The scanner has no options to scan in mounted 35mm slides.
Does the scanner work for scanning at all? If not, you may have a communication problem between the computer and the scanner, i.e., the computer doesn't know how the scanner is configured so it doesn't show the options. If it's a communication problem, check for any other USB devices that might interfere with communication. Especially, some printers seem to take over communications. Try disconnecting all other USB devices (except keyboard, mouse, etc.), reboot, and see if the situation corrects itself.
Also, try the online troubleshooting database for this model at this link.
Posted on Sep 30, 2008
SOURCE:
How can I find out if there are digital scanners available for 2.25 square negatives.
Given the popularity of these films (Kodak 120 or 620, dependent upon size of hole in the spool) there are scanners available.
However, the negative is large enough that ordinary flat-bed scanners with a film attachment will be sufficient for scanning.
http://photo.net/medium-format-photography-forum/00cN3y refers.
Jan 29, 2015 | Photography
How to scan negatives?
You will need to check your Canon software that came with your Pixma MX310. I have a stand alone Canon Canoscan 8800F scanner that have the capability to scan 35mm film strip and 35mm mounted slide, the software included the feature for it.
Nov 07, 2013 | Canon PIXMA MX310 All-In-One Printer
Can HP psc 1410 PRINTER SCAN NEGATIVE AND SLIDES
Chances are that somewhere in your family photo collections you have a bunch of slides and negatives that you wish you could do more with. You may want to include them in your family history, to publish them on the Web, or simply to make digital copies so you can share them with the family.
If you've ever tried to scan a negative or slide on a regular flatbed scanner, you'll know that it doesn't work, and you end up with a pure black scan. In this article we'll show you how you get your negatives and slides into digital format, and what issues you may face along the way.
pixblue.gif Benefits Of Scanning Film
There are some key benefits to scanning film (we'll use the term to include slides and negatives) in comparison to scanning a photo. When you scan film, you can use the full area of the slide or negative, whereas a photo will generally only display a cropped portion of the original. You are also scanning the original source image rather than the color corrected and tweaked version of it that the photo processor has provided you with. The process of turning a negative image into a positive one involves inverting the colors in the image and removing the orange cast from the negative. This would be a complicated process if you were doing it by hand; however, your scanner will provide you with software to do this automatically, or you can purchase standalone software to do it.
Most cheaper flatbed scanners are designed to scan photos and other images that reflect light when it is shone onto them. The problem is that film is transparent and light passes through it rather than being reflected off it. Many flatbed scanners have an optional transparency adapter, which replaces the scanner lid with a larger box shaped ob....
Jun 09, 2010 | HP PSC 1410 All-In-One InkJet Printer
EPSON Perfection 4490 - Ireflective media scans, film doesn't
There are two lamps with this model. One in the base for reflective and one in the lid for negatives and slides. If the base one is going out then it will be trying to use the one in the lid. You must remove the white document mat from underneath the lid to expose this lamp so it can scan your negatives.
Jul 01, 2009 | Epson Perfection 4490 Office Flatbed...
I am tring to scan my 35mm negatives
Select scan. When the window pops up look in the upper right hand corner of the window. You will see select source: drop down menu give you choices which includes negative film. Just select it. Then drop negatives into holder. Oh, make sure you remove the cover sheet that slides in and out of the cover.
Mar 19, 2009 | Canon CanoScan 5000F Flatbed Scanner
By scanning my negetive film 35mm,allways cuts a horizontal part.
Try lower resolution while scanning & do set it at color settings. After preview then set color or monochrome......sodeep
Mar 19, 2009 | HP Scanjet 4370
How do I scan a 35mm film negative with my HP PhotoSmart C6180?
I regret to inform that hp Photosmart C6180 does not support scanning negatives.
Regards,
Sagarjd
Nov 19, 2008 | HP Photosmart C6180 All-In-One InkJet...
I cannot get clear scans from my photo negatives
If you are seeing pixelation, the issue is either insufficient resolution during the scanning process or a problem with the output device. If it's a focus issue, which will NOT cause pixelation, the problem may be the height of the negative holder. The Epson Perfection V series scanners have a fixed focus point which only adjusts between two settings depending on whether you select the film holders (which raise the film off the glass) or the film guide (which scans film directly on the glass) in the software options. If you are going to scan transparencies or negatives, familiarize yourself with the holder height adjustment issue and be willing to experiment with different height settings until you are getting optimum results. This is not documented much at all in the Epson user manual but there is a little bit about it, including some examples of results at different settings, here: http://www.photo-i.co.uk/Reviews/interactive/Epson%20V700/page_13.htm Apparently every scanner is slightly different so even though the lowest holder foot setting (default) is working best for some, other settings work better for others. On my V700, I have the feet on the film holders set to the highest setting plus I shimmed them with a 1mm piece of styrene before I could get the scans in focus. Once I found the right height though, I've been able to get beautiful scans from this machine. BTW, scanning negs directly on the glass will almost always result in Newton Rings.
Sep 08, 2008 | Epson Perfection V700 PHOTO Flatbed...
Huge difference in film scanning quality
For ARCHIVAL quality scans, there is no comparison. The Nikon wins hands-down. For making small prints and web sharing, either will work fine.
Apr 16, 2008 | Nikon LS5000 Film Scanner
Scanning 110 negatives
You should be able to do about 12 at a time using the 35mm film strip film guide. What Kind of trouble are you having?
Mar 09, 2008 | Canon CanoScan 8600F Flatbed Scanner
Canon CanoScan  LiDE 600F Flatbed Scanner Logo
634 people viewed this question
Clive
Clive
old marine
old marine
