Question about Lexmark Office Equipment & Supplies
I have a printer X3550 which I installed and it worked perfectly. Now Iget the message that the print spooler device is not running.. so its no longer working. I have a BIG problem- when I received this printer from you to replace my previous Lexmark 2200- which was still under warranty- I after installing it I made the misstake and threw out the disk with the old printer so all i have now is the old disk (2200) and can not re-install this new printer again. So right now is NOT working or connected to my computer at all........Is it possible for you to send me a new disk so Ican start all over again to install my X3550.. HELP please... thank you................
Soulvisitor
  • 1113 Answers
SOURCE: lexmark won't work with vista
Yes works with Vista but you will need to use Vista driver not XP
Rate this solution then Download here
Delete old install before reinstalling!!!!
Release Notes Attention: To prevent issues during the installation, please uninstall all previous versions of this driver prior to installing this web package. File Information File Name: cjr1200EN.exe null.gif Version: 1.0.11.3 null.gif Released On: MAR 05 2007 00:00:00 null.gif File Size: 42452912 KB null.gif Products: Lexmark X1240, Lexmark X1250, Lexmark X1270, Lexmark X1280, Lexmark X1290 null.gif Languages: null.gif Operating Systems: Windows Vista null.gif Application: n/a null.gif Owner Name: Lexmark null.gif Data Stream: Lexmark Host Based Solution, Lexmark Scan and Copy Control null.gif Security: null.gif Install Instructions:
Posted on Dec 25, 2007
Joed911
  • 4338 Answers
SOURCE: i have a lexmark x3550
Verify that that the Print Spooler service, and all the services that it depends on, are correctly installed and running.
  • Open the Services Management Console (click Start, Run and enter services.msc).
  • Double-click the Print Spooler service to open its Properties window.
  • On the General tab, check that Startup type is Automatic.
  • Select the Dependencies tab.
  • Note all of the dependent services listed, then close the Print Spooler Properties window.
  • Repeat the above steps for the dependent services noted.
If any of the dependent services are missing or cannot be started, try uninstalling all installed printer drivers and then reinstalling them.
If this method cannot be completed or does not resolve the problem, try Method 2.
Method 2
Remove all Print Spooler service dependencies other than the Remote Procedure Call service.
  • Click Start, Run and enter sc config spooler depend= RPCSS (there must be a space after "=" but not before it.)
By removing the other dependencies the Print Spooler service should be able to run, but the printer functionality may be affected, and it may be necessary to reinstall the printer drivers.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Dec 29, 2008
  • 9 Answers
SOURCE: Lexmark x3550 18C0032 ink cartrage set up.
The 34 and 35 cartridges will work. You can also buy a 23a or 24a from Lexmark.com and you can refill those.
Posted on Feb 12, 2009
SOURCE: HP print spooler problem and error 1068. Want my printer back!!!
Unplug HP 1022n printer.
In command line >> net stop "print spooler"
In command line >> net start "print spooler"
(Reason for command line: Service normally times out while stopping in services list)
Open regedit and go to HKEY_CURRENT_USER --> Software --> Microsoft --> Windows NT --> CurrentVersion --> PrinterPorts
Deleted HP 1022n printer there
Open regedit and went to HKEY_LOCAL_MACHINE--> Software --> Microsoft --> Windows NT --> CurrentVersion --> PrinterPorts
Went back to Printers and Faxes page. File --> Server Properties --> Drivers tab
Deleted HP 1022n print driver
Go to HP.com and downloaded the driver from website
Plugged printer back into docking station
In Printers and Faxes --> Add Printer --> Local Printer Attached to this computer --> Unchecked Automatically detect and install my Plug and Play printer
Name queue whatever you would like, share printer if you want. Loaded driver that you downloaded from HP. Finish install.
Posted on Apr 01, 2009
  • 1218 Answers
There are several ways to resolve printer spooler error, probably because there are many variations of this error. The error caused by faulty software can be resolved by deleting all the information found in the directory. Thereafter, navigate to the Control Panel, click on Administrative Tools and then services icon. Find the service labeled Print Spooler, highlight it and restart the process. If that doesn’t work, the program might be corrupted. Click on start, then Run. Search for the document labeled services.msc, and this will trigger the opening of another window. On this window, scroll down and click “Print Spooler”. Check its setting and turn on automatic mode. Click Okay, and restart the machine. If you’re lucky, this might be all you have to do. Still doesn’t work? Navigate to the Add/Remove Programs screen of the Control Panel. Find the all the software responsible for making the printer run including the drivers, and uninstall them. Be sure to be thorough about it, or the problem may not be solved. Download the latest copy of your printer’s software from the manufacturer and reinstall it. get more information for printer spooler error .Hope this helps you.
Posted on Sep 03, 2010
Operation could not br completed. The print spooler service is not running
Hi There,
If your print spooler service is not running, then follow the below steps to get it working :
Step 1 :
* Start > run > services.msc > ok
* Select the service name called print spooler from the list.
* Check the status on the print spooler service, if it is stopped, then right click and select start or restart.
* Then the spooler service will start working....
Step 2 : ( NOTE :USE THIS STEP ONLY WHEN YOUR STEP 1 DOESN'T WORK )
In this case, we assume that the print spooler service is gone bad and we would have to recreate the spooler service.
* Start > run > cmd > ok
* Type: sc delete spoolsv (this will delete the corrupted spooler for us to create a new print spooler)
* Reboot the system and after rebooting the computer back.
* Type: sc create spoolsv (this will create a new print spooler service)
* Reboot the system and this time the print spooler service is a new and fresh spooler and it should work normal and perfectly.
Enjoy printing !!
Oct 22, 2010 | Office Equipment & Supplies
Printer spooler keeps stopping
I would like to know the PC Operating System, is it XP or Vista ?
If this is XP there is a Print Spooler Reset which you can try
Uninstalling Printer s/w may not help here
On this website you will find the FIXIT - download and run the Fixit
http://support.microsoft.com/kb/324757
Follow the instructions and click on RESET PRINT SPOOLER and continue till it prompts you to restart the PC
Once the PC is restarted and you see the Desktop - Disconnect the Printer USB Cable from Printer or PC and connect it back. it will install the Printer Drivers or prompt you to insert the disk to install..
you will be able to print without problems.
Jun 24, 2010 | Dell 924 All-in-One InkJet Printer
Just go to your Server or Desktop PC and enable the RPC service (Remote Procedure Call)
Right click in "My computer" icon, from the manu select "Manage" then go to "Services and Applications" and expand that, after that select "Services" you will find that services in the right pane, just click in "Start"
May 08, 2009 | Sony Office Equipment & Supplies
I have a lexmark x3550 and it says there is no spooler, and now it says there is no printer.
Method 2
Thanks, Joe
Dec 29, 2008 | Lexmark X75 All-In-One InkJet Printer
to make spooling work its necessary to make it work
this is the procedure .if you do this it will work properly. till it is not done it will just ignore printing
1)click the start in the left sice of your computer screen
2)go to control pannel
3)click performance and maintainence
4)click system
5)click data execution prevention
6)turn on DEP for essential windows program and services only.
7)click the spooling services a tick mark sign will appear beside that means it has enabled.
now your printer will work properly.
Nov 23, 2008 | HP PSC 1610v All-in-One Printer
Printer Spooler service!
1) Click the Star>Run, type in "Services.msc" in the Run dialog box.
2) A services window popup, find the service name "Print Spooler", double it and change the Service Status to "Start".
Now u can use your printer now.
YBC (/\)
Aug 04, 2008 | HP LaserJet 1018 Printer
click on start ..RUN.....type cmd......type sc config spooler depend= RPCSS......click on start ..RUN......type services.msc.......look for ptrint spooler......it will be started if not then double click on print spooler and click on start.
Now try installing the printer.
May 31, 2008 | Lexmark X4270 All-In-One InkJet Printer
HP PSC 1400 series printer won't load
Hi Flame,
Please click on the web link given below and perform the steps as provided in the web page to fix the installation issue.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00625472&cc=us&lc=en&dlc=en&product=441115
Make sure that you have completed all the steps perfectly and carefully.
Please perform this additional step.
click on start >> Run
In Run box type services.msc /s and press enter.
You will see a services page.
Search for print spooler
Double click on print spooler.
Make sure that start up type is "AUTOMATIC"
CLick on stop and then start the service.
Then start installing the printer software, this should fix the issue.
Have a great day!
Mar 25, 2008 | HP PSC 2210 All-In-One InkJet Printer
Printers vanished and can't add printer
Your shell extensions have a software conflict. The offending piece of software will have to be determined and removed, or at least stopped, before re-booting the computer. You may be able to repair the problem using the System Restore option.
Oct 10, 2007 | Adobe Acrobat Distiller Server V6 for Win...
55 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
