Question about HP PSC 2355 All-In-One InkJet Printer
HP PSC 2355xi printer error code
After the printer is on for a few minutes it comes up with an error code of 0xb9000013 and also says 165:hw_interrupt_hwv2.c
If I hit reset, it will print and work for a while then go right back to this error screen.
Printer worked fine for 2 years. Still on the same computer.
  • 1 more comment
  • rdadiomoff Sep 30, 2008
    Thanks. I was on line with HP and they had me do a variety of resets. As soon as I hung up, it came back. Looks like it'll be easier to replace the printer.
    thanks for your time and effort.
  • Anonymous May 14, 2009
    it craps out when scanning and printing...
  • 1,689 Answers
Temporarily, you may be able to make the unit work again but the error will re-appear some other time. this will be up to HP if they can or will repair this kind of error.
1) unplug the power supply
2) hold the # and 6 key down while plugging it back in
3) then try to reconnect to the device and do a test operation to see if it will work
hope this helps...
Posted on Sep 30, 2008
  • marlon john madrid
    marlon john madrid Sep 30, 2008
    yeah, and it will be cheaper and more reasonable than getting one repaired, well most the time.
    but like i said, if you have other questions just lemme know okay...
  1. error: ox84111ad
Posted on Dec 28, 2009
How do i fix sharp copy machine AR5520N with error code H5?
H5 error is protection against big damage of the fuser caused by multiple paper jams in the fuser area. First clean and check paper way, check sensor operation and then reset the error. Reset with key operation # - INTERRUPT - CLEAR - INTERRUPT - 1 - 4 - START
Aug 14, 2016 | Sharp AR-5520N
Diagram Sharp SIM14?
Type # - interrupt - C - interrupt and clear the code with simulation 14 and then hit CA to exit. If the code comes back there is a problem with your fuser (dirty thermistors cloged with toner, or one of the lamps are out)
Apr 06, 2014 | Sharp AR-M237 Copier
Code error h2
Error code H2 means fusing unit temperature error. This error occurs due to a bad fuser temperature thermistor or due to fusing lamp. To resolve this error try and reset the unit by entering the service mode--
If this resolves your issue then try restarting the printer and try the reset again. However, if reset is not helping you then you
Oct 09, 2010 | Sharp AR-5316 Advanced Digital Imager...
Porfavor ayudenme necesito su ayuda urgentemente. este problema ya lleva 2 semanas asi y no me permite ni scanear ni imprimir ni nada.
Aug 06, 2009 | Sharp AR-275 Copier
Error H-4
H4-00 on Sharp means that the temperature inside the printer is too low. That is usually the fuser lamp, and sometimes the temp sensor jammed.
Only when the problem is a jammed temp sensor or a jammed control board you can reset the machine by doing a reset.
You try reset from simulation mode by following procedure below:
Clear key >>Interrupt key >> "0" key >> Interrupt key >> Main code >>Start key >> Sub code >> Start key
If the error remains, that means that the fuser is really bad and must be replaced.
When this happen you need to have the fuser unit replaced, if that does not fix the problem the technician will replace the temperature sensor.
Mar 01, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Ar-5132 sharp copier
H3-XX codes involve the fusing unit temperature being too low or too high.
Try resetting the error.
Type in 1 4
Turn power off then on if it doesn't do it automatically.
If error doesn't reset then you have other trouble
I hope you ran the developer setup and reset all of the parts counters for the items you replaced. Not setting the developer reference can cause a host of problems.
Sim 25-02 adjusts developer.
Sim 42 clears DV counter
Jun 05, 2008 | Office Equipment & Supplies
Technical Support
the h3 code means the fuser isn't heating up. You can try and clear the code by pressing in order clear then interrupt then zero key, then interrupt again. The display should go balnk. Enter 14 and hit start. Then hit CA. This should reset the code and allow the machine to try and warm up again. If the code comes back you will need parts replaced.
Apr 08, 2008 | Office Equipment & Supplies
Sharp Copier Service Code
You had 5 jams in the fuser the hotarea on the left side of your machine.
Feb 15, 2008 | Sharp AR-M237 Copier
H4 error code
H4 codes are related to the fusing unit. Specifically a low heat condition. Follow the reset procedure below. If that doesn't work further diagnosis of the fusing unit an peripherial circuits may be warranted.
Error code reset:
Perform the following key procedure
"#" key, Interrupt key, "C" key, Interrupt key
"1" key, "4"key
Start key, "CA" key.
See if unit cycles and comes back up. If not turn off and then back on the main power.
If error reappears on site technical service may be required.
Jan 06, 2008 | Sharp AR-5320 Black and White Copier
HP PSC 2355 All-In-One InkJet Printer Logo
1,404 people viewed this question
Ben Johnson
