Question about Car Audio & Video
My car radio locked when i had too remove my battery
    New Friend:
  • 161 Answers
Call the manufacturer of the car or check your manual for the car....usually there is a separate book for the anti theft radio.
Posted on Sep 30, 2008
Suzuki radio not locked but lost code
The code could be on the rear of the radio or in some other location such as the rear of the glove box.
Jan 08, 2014 | Cars & Trucks
Changed battery on 2001 olds silhouette and now the instrument panel and radio don't work. Any suggestions?
NEED RADIO UNLOCK CODE TO RESTORE RADIO
IPC INOP. SOUNDS LIKE IP CLUSTER IT'S SELF, COMMON ISSUE
Dec 27, 2013 | 1999 Oldsmobile Silhouette
Factory stereo not working and needs replaced. how does dash come apart to do this
REMOVAL
  1. Disconnect and isolate the battery negative cable.
  2. Remove cup holder.
  3. Remove trim panel above cupholder by pulling straight out.
  4. Remove center instrument panel trim panel.
  5. Remove screws holding radio to instrument panel.
  6. Pull radio rearward to gain access to the back of radio (RADIO). CAUTION: Pulling the antenna cable straight out of the radio without pulling on the locking antenna connector could damage the cable or radio.
  7. Disconnect the antenna cable by pulling the locking antenna connector away from the radio (ANTENNA TO RADIO).
  8. Disconnect bolt holding ground strap to the radio (if equipped).
  9. Disconnect the wire connectors from the back of the radio.
Nov 19, 2013 | 2002 Dodge Grand Caravan
Midland walkietalkies -how do you put in new
You have to remove the belt clip, then the battery cover. There is a locking tab at the top of the belt clip.
To remove the belt clip, press the LOCK TAB down , then gently pull the belt clip up toward the top of the radio.
Then remove the battery cover, press near the seam and slide the cover down:
Replace the batteries, observing polarity.
Slide the cover back on until it locks in place.
To install the belt clip, slide the clip down into the slot on the back
of the radio until the belt clip lock clicks.
Hope this helps! If you need more help, please ask!
Oct 17, 2013 | Midland LXT310 2-Way Radio
Is there anything i should be wary of when removing my battery,will it mess any of the electrical settings up?bmw z4 3ltre thanks
Just make sure your radio is turned off before removing the battery. If the radio is on and the battery is removed and replaced, the radio may get locked out. This will prompt you to enter and reset code to your radio to have it work again. Good luck and after you battery has been replaced, just reset the radio stations setting and time.
Aug 22, 2009 | 2004 BMW Z4
Radio Locked Up, due to wrong code entered.....
Leave the radio on for one hour and the radio will reset. Works on all locked Mitsubishi radios. Dont go opening up the radio for no reason....
Jun 21, 2009 | 2001 Mitsubishi Montero
Car will not started radio and door locks dosent work
If the battery is good dissconect the ground and clean it until its silver in color on the battery and copper color on the terminal connector. If that doesn't do any good remover that ground wire again then check the battery positive cable running to the starter. It may be loose. If so remove it and clean it very good. Re-enstall with a star washer to lock in place for keeps & check
May 22, 2009 | 1995 Nissan Maxima
Radio locked on 94 geo prism
take the power off of the battery and leave for 5 min then plug back up also try removing the fuse for the radio located under the dash
May 19, 2009 | Car Audio & Video
Radio lock
in the under hood fusebox remove the "back up" fuse for 10 seconds with the key out of the ignition. or remove the neg (-) battery cable for 10 seconds. this will reset the radio.
Dec 28, 2008 | 1996 Honda Accord
Car radio lock
There is a reset button on the radio, you will have to remove the radio to get to it, or you can just remove the positive cable on your battery, wait a minute and then attach it again.
Oct 07, 2008 | Radio Communications
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
