Question about Brother LS-1217 Mechanical Sewing Machine
Tension I am not sure what model my brother machine is; I do find the numbers 885-412 if that helps. I am having a problem with the bottom thread either breaking or the thread gets all wadded up while sewing. the top thread does fine. This is a used machineband I do not have a manuel. Thanks PK
  • Verse1 Oct 17, 2008
    I have a Brother XL 3022. My problem is the tension is wrong but I cant adjust it with the nobbs. The top thread pretty much lies on the material and the bottom thread visably loops over it (it looks like braces). Is there a way to slove this without taking it in to get fixed?
    Scholar:
  • 65 Answers
Check out this site. There is pictures of each machine there. All the Q&A answers in simple language, as well as a GREAT cust. support. (its a Brother after all!)
I found download manuals there as well.
http://welcome.solutions.brother.com/bsc/public/Model_list.aspx?reg=us&c=us&lang=en&titleid=36
I hope this helps!
Happy sewing!
Posted on Jan 24, 2009
How to adjust bottom thread tension on my CE-5000 sewing machine
Unfortunately, the manual for your machine describes adjusting only the top thread tension.
Brother CE 5000PRW Operation Manual Troubleshooting
If you look closely at the area where the bobbin is installed and threaded, there is probably a little screw that adjusts the tension spring. That may be where the bobbin tension is adjusted. Beware though that a tiny adjustment could make a huge difference, so be sure to always mark where the screw was positioned before making any changes.
Another thing you can try is ALWAYS RAISE the presser foot when threading the top thread. Sometimes the top thread tension is an issue but appears on the bobbin side of the fabric.
Jul 11, 2017 | Sewing Machines
Brother SP55 Upper thread tension seems to be too tight and pulling lower threads up.
This is an indication of needle thread too tight. Loosen the needle thread tension by moving to a lower number.
you should be able too download the manual from Brother website, if not you will have to purchase from dealer.
Apr 02, 2017 | Brother Sewing Machines
I'm having a problem threading my brother sewing machine model XL 3010
1. Clean up any loose thread in the bobbin area.
2. Pull on the bobbin thread while it is out. It should give a tension that is equal to the top tension of three. You'll have to approximate. Adjust the screw tension on the bobbin. It is the screw nearest to the thread exit hole on the side.
3. Put it back in.
4. Now, the top tension should be at about three. If it still allows a little wad on the bottom of the fabric you can adjust the top tension by tightening a small amount and monitor each time you adjust. The wad should go away.
Oct 05, 2016 | Brother Sewing Machines
Adjusting machine tension
IS IT A BROTHER, SINGER, ETC? THE BOBBIN TENSION HAS A SMALL SCREW TO LOOSEN OR TIGHTEN. THE THREAD GOES UNDER THE METAL PLATE THAT APPLIES PRESSURE TO THE THREAD.
1. USUALLY, THREAD WILL TURN COUNTERCLOCKWISE.
2. PUT THREAD UNDER PLATE AND BOB FROM FINGER. IT SHOULD EXTEND ONE INCH WHEN FINISHED.
3. REINSTALL.
4. THE TOP TENSION HAS TO MATCH THE BOBBIN. START ON A SCRAP AT FOUR.
5. IF THE TOP THREAD CAN'T BE SEEN THEN INCREASE PRESSURE. DO THE OPPOSITE IF THE BOTTOM THREAD IS COMING THROUGH THE TOP OF THE FABRIC.
Jan 17, 2015 | Sewing Machines
Brother vx 860
First, make sure the upper thread is threaded correctly. I don't have this model but see if this helps. If the bobbin thread is visible from the right side of fabric, the upper thread is too tight. If the upper thread is visible from the wrong side of the fabric, the tension is too loose. Turn the thread tension dial to the right to tighten and left to loosen upper thread. Good luck. Loverly Lou
Jul 17, 2014 | Brother Sewing Machines
How to thread the bobbin on a brother vx-810
The sewing on the bottom is loose because you don't have enough tension on the TOP thread. First, make absolutely sure you are threading the machine correctly. Next, while using 2 different colours of thread, tighten the top tension dial one number at a time and then checking the stitching, continue tightening the top tension until the sewing is even on the top and bottom of your cloth.
Apr 02, 2013 | Brother Sewing Machines
The stitches on my brother 3125 sewing machines are loose. On the top and bottom. Ive tried to redo my stitching and nothing has worked . Please help !!!
Make sure presser foot UP position. Rethread making sure thread is taut so it can locate tension slots. Rethread needle making sure its up in the needle bar shaft--flat side BACK--thread goes through needle eye front to back. Tension: 4 Jimmy
Apr 04, 2012 | Brother LX3125 Sewing Machine
I'm having troubles with my brother sewing machine
Your tension is loose on top. Adjust your tension dial up a little at a time until you have a desirable stitch. Before adjusting the tension, you may want to look into the tension and see if there are any threads caught between the disc. If so remove them. Another common problem is that your machine is not threaded properly, make sure the pressure foot is in the up position when threading and if needed consult your manual for the proper threading diagram.
Jan 16, 2009 | Brother LS-2125 Mechanical Sewing Machine
Treading the machine
all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT.
sewman7
Jun 25, 2008 | Brother LS-1217 Mechanical Sewing Machine
Brother LS-1217 Mechanical Sewing Machine Logo
179 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
