Question about HP Office Equipment & Supplies
Replace ink in copier - HP Office Equipment & Supplies
Thanks for your help,but found the original web site i was looking for to solve the problem with the copier.
regards charles.
Posted on Oct 01, 2008
I replaced the ink and tried to copy. The machine went right to "replace ink" and won't copy. What can I do?
Take out the ink and swith off and wait 30 seconds and on again, repeat for 5 times, this should reset the printer memory. Then put ink back in.
Oct 12, 2014 | Kodak ESP C315 Wireless Color Printer with...
What is the problem if ink out error is appearing always?
If you refilled and replaced the cartridge yourself and the printer doesn't accept that the cartridge is now full, here are the instructions how to reset the ink counter: http://www.fixya.com/support/r1598313-reset_epson_printer_ink_counter_ink
Mar 06, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Trying to change ink cartridge on epson nx515 printer. how do I move the container out from under the printer to change it?
If your printer is out of ink, it will display the ink that you need to replace. Just open the lid and press the OK button.
If you want to replace an ink before it runs out, press the Setup button then go to Maintenance and press the OK button. Select "Ink Cartridge Replacement" or "Change Ink Cartridge", then press OK. You can now lift the lid then replace the ink.
Nov 18, 2010 | Epson Stylus Multifunction Inkjet Printer/...
How to Change ink cartridge on Epson Stylus SX215
#1 Wait until you are out of ink. The warning light and ink-low notifications come on well before the ink cartridge is empty, and even if it runs out of ink in the middle of a print, you can replace it then and finish the print with no problem.
#2 Lift the lid of your Epson inkjet printer to expose the ink cartridge replacement button. Make sure you have plenty of light so you can see what you are doing.
#3 Press the ink cartridge replacement button. This will loosen the empty ink cartridges so they can be pulled up and out.
#4 Fill the empty cartridge at an ink-refilling location, or buy a new ink cartridge to replace the empty one.
#5 Insert the new or refilled ink cartridge into the holder with the same orientation as the previous one.
#6 Press the cartridge replacement button to charge the system and close the printer cover. Charging takes about one minute
Thanks
Sep 30, 2010 | Epson Stylus Multifunction Inkjet Printer/...
The ink cartridge in my Canon MultiPASS F50 ran out. I replaced the cartridge correctly, but now when I try to copy a document using either the laser copier or the fax part of the machine, the papers come...
...I try to copy a document using either the laser copier or the fax part of the machine...
These isnt laser copier, you probably refer to scaner assy... but never mind.. lets solve your problem!
First, new inks are reffiled or original?
Remove inks and look for small hole, ussually on top of crg. and blow in it verry hard.After that from crg. must start to drop ink. Put the ink back in and try to copy/print something.Also run head cleaning for few times.
If now it works that could mean two things:
1) the ink was for long time on warehouse, and nozzles are clodged.
2) your purge unit is faulty and it cant drain ink from crg.Replace purge unit, wich isnt cheap solution.
Or,... buy new LASER Canon multifunctional copier that uses TONER.
Hope that helped!
Aug 09, 2010 | Canon Office Equipment & Supplies
Ink replacement issue!!
have you bought genuine ink??? well if your answer is both yes or no, you can always opt to have it replaced from where you bought it, but please try to buy genuine inks, so as you will have no problems regarding ink cartridges.
Jun 03, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Trying to use the copier and it won't work
Hi there go in printer setting & select the B/W printout. I hope its will start work. If still he asking for replacing the yellow ink then you have to replaced. Because some printer have a single sensor for all color. If he find one of them is out or no ink then he stop working. Thanks & waiting for your feedback.
Apr 07, 2010 | Brother MFC 5100c InkJet Printer
I want to replace the ink cartridge, let me be informed about the procedure to instal the new ink cartridge
Press ink button once, the carriage should move to ink replacement position. When in position replace the ink cartridge, after replacing the cartridge push the ink button once again.
Jan 17, 2010 | Epson Stylus C20SX InkJet Printer
There's Not Enough Ink on the Drum, Wants me to add more
your ink fingers may need cleaning or replaced. your ink pump may be worn out. you should call a tech
Sep 21, 2009 | Gestetner Copier
Copier printer ink
Hi , replace the ink to ginuine ink cartridge canon brand.
Mar 09, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Seeker5211
Seeker5211
