Question about Estate TAWX700JQ Top Load Washer
My water has been smelling of sulfur. The clothes I was end up smelling of BO after being worn for only a short time. It isnt that the person is smell it is the clothing. Is there something to be added to the water system. We do have a water sofener.
  • Anonymous Oct 01, 2008
    same problem.clothes smell fine at first,then after 2 hours of wearing,they smell foul.bosch nexxt 100 series front load washer
  • 3 Answers
I found that WasherFresh worked better then the Affresh.  What I really did not like is you cannot touch the Affresh tablets, WasherFresh is contained in a pouch and is not harmful to touch, because of the disolving pouch containing the chemicals.  Also after reading the package the chemicals are not harmful to the environment.
WasherFresh removed the odor causing buildup and I now use it monthly as a preventive maintenance.
Posted on Feb 13, 2009
  • 1,031 Answers
Affresh™ Washer Cleaner stops HE washer odor and leaves your front load washing machine clean and fresh. This is the innovative solution for HE Washer Smells. With all of the water and energy savings that HE washers provide, they still require special care. After normal use, mold, mildew, and odor-causing residue may form in hard-to-reach areas of HE washers. Many times people will notice that their basement or laundry room has become stinky. Often this is caused by their washing machine developing a musty smell that comes from the mildew in their washer sump.
Affresh™ Washer Cleaner will get your washing machine clean, so you can enjoy a fresh smell in your laundry area or cellar. Oxygenated cleaning action lifts away the Odor and the Residue that causes it in your HE Washing Machine. Affresh™ Washer Cleaner is the only product proven to penetrate, dissolve, and remove odor-causing residue from your HE washer. It doesn't cover up the odor - it's oxygenating action lifts the residue from the surfaces in your washer, allowing it to be rinsed away.
Affresh™ Washer Cleaner removes and prevents odor-causing residue that can occur in all brands of HE washers. While bleach only kills odor-causing bacteria, leaving behind the detergent residue; Affresh™ Washer Cleaner uses surfactant chemistry to remove the root problem. Affresh™ Washer Cleaner is aspecially formulated, slow-dissolving, foaming tablet that gets under residue, breaks it up, and washes it away leaving the washer smelling fresh and clean.
Using Affresh™ Washer Cleaner is fast and simple. Simply add the tablet to your washer tub and run a Normal Cycle (hot option) or Clean Washer Cycle once a month. This routine maintenance will keep the inside of your washer sparkling, clean, and fresh smelling. Affresh™ Washer Cleaner is environmentally friendly, safe on septic tanks, and safe for all washer components. Package includes three tablets.
[Back to Common Questions about Washers] [Back to Beginning]
Why does my Washer agitate but it won't fill? This can be caused by a water level pressure switch failing. You can reset the switch and try it again. If that doesn't work, you can put the washer in a spin cycle for a few minutes and then try to fill it again.
Posted on Sep 30, 2008
  • Starnley Johnwells
    Starnley Johnwells Sep 30, 2008
    AFFRESH water cleaner
    hope the above infformation helps pls appreciate by rating it
What could be the problem causing the rotten egg smell in the water? We have changed the anode rod.shocked the well.no sulfur. We have kinetico softener. Use iron out salt. Water heater 2 yrs old.
Some water softeners you can increase the back wash time on the unit to clear out a smell or bad taste , rotten egg smell can be sulfur. You may need a well flush but seek a well company on that for there advice as its not cheap .
May 16, 2017 | Water Water Heaters
I have a Chrysler pt cruiser 2003 , when starting it's mis firing, it has no power when driving and it produces rotten egg smell
you have a clogged up catalytic converter there are some ways to unclog on youtube if you can get to it you can put a piece of wire in a drill and spin it inside to break up the carbon build up its hard to get out best to change good luck with it some people drill holes in it to relieve presure
Mar 19, 2015 | 2003 Chrysler PT Cruiser
Top load washer smells like rotten eggs when water is draining into tub
As someone who has had a deep well drilled and found water, but water contaminated with iron and sulfur, I can tell you first hand about the rotten egg smell. The water softener will remove the iron that can turn clothes orange, but doesn't do anything to remove the rotten egg odor. You will need a charcoal (carbon) water filter to eliminate the sulfur smell.
Sep 19, 2014 | Whirlpool WTW8600YW: 4.6 cu. ft. Cabrio...
We have a one year old home with PEX pipe and one year old hot water heater fed by a water softener. In one of the bathroom sinks, and only there it seems, there is a sulfur smell when we first open the...
i would check the softener before the water heater, when was the last time you did a back flush of the system? water sitting at the bottom of a water softener tank can get moldy and begin to rot, which causes H2S gas which smells like sulfur , its a breakdown of decay,, this will also happen if your home is using well water,, so check that first , empty the tank and clean it our ,, then back flush the system
Jul 03, 2011 | Water Heaters
Our Maytag washer emit a rotten egg smell and the wet clothes also come out with this smell. What is causing this and how do we fix this issue?
Sounds like a sulfur-eating bacteria, you're smelling hydrogen sulfide. Are you on city water or do you have a well? Sulfur-eating bacteria can live in a well (as can iron-eating bacteria) and it might find a happy home in a washing machine too.
Since they live in an acidic environment (the hydrogen sulfide, dissolved in water, makes an acid) I would try a caustic first- bleach would be a good first bet.
If you have a well and the bacteria came from it then it'll come back. Consult with a local well drilling operation, they can tell you if you have bacteria in your well and how to deal with it in a locally acceptable fashion.
lp
Dec 29, 2010 | Maytag Atlantis MAV6451 Top Load Washer
How to fix a sulfur smell from hot water side of faucet.This started when we replaced an old faucet with a new one.
Probably coincidence, but that sulfur smell is likely from your water heater.You'll either have to shut-off power, or gas, to water heater, and drain it down, then re-fill it, or leave hot taps on, and let it flush itself out. If you have a way of introducing bleach to line coming in to house, such as a pump or something , you can do that to help flush that smell out of water heater, otherwise, flushing or draining may be your only option.
Jan 07, 2010 | Delta Victorian 2155-SSLHP Bar Two Handle...
My dryer smells like sulfur . The clothes smell
Run a couple of hot washes with no clothes in the machine
Before you do dissolve some Soda Crystals in 2 liters of hot water and put them into the machine by hand.
Your machine smells because new powders wash at lower settings and do not contain bleaches and soda to kill off the grease which is washed off the clothes
Jun 16, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Kenmore front load HE washer odor
How old is your machine? Mine is 5 years old, and I just started to get a "sewage" smell in my laundry room this weekend. I disconnected the water return to the sewer line and discovered lots of gunk in the hose, and the connector to the machine was completely dark green. I'm going to replace the hose, and trying to figure out if there is some sort of filter.
We only use He detergents too, so I guess this is something that just happens over time.
Oct 09, 2008 | Kenmore Elite 45986 Front Load Washer
I have a sulfur smell from my water. I have a privet well. I also notice a bo smell on my clothing its not a smell person its the clothes. Is there something that could be added to the well such as a...
Find a well water person in your area that can help you with the sulfur problem.
They may recommend a filter system, or they may suggest a air rader for your well, what this does is it mixes air with the water before your system gets its and the sulfur fouls out and drops out in your well.
Get a guarantee and give it some time, with a money back guarantee, or a couple year warranty.
THey may not be able to solve your problem, a Friend had to dig a new well deeper.
Sep 30, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Fisher/Paykel Refrigerators
The problem of a sulfur smell is not likely to be coming from the refrigeration system itself. Near the bottom front is a removable kick plate. when this plate is removed you can access the drain pan for collection and evaporation of the water from defrosts. remove and clean the drain pan and then reinstall it. On the lower back of the refrigerator there is generally a fiber panel that is removable. remove this panel and inspect the underside for something that should not be there. Such as a dead rodent. Sorry but I've seen it many times. After clearing do not forget to replace the panel . It has to be in place for proper air circulation and heat removal from the refrigeration system.
Apr 28, 2008 | Refrigerators
Estate TAWX700JQ Top Load Washer Logo
400 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
